  1. Sep 22, 2021 at 5:40 AM
    Hopefully, when they perfect the manufacturing process of a solid state lithium battery, that won't be an issue anymore. I'd be itching to invest if someone pulls it off.
    shifty`[QUOTED] likes this.
  2. Sep 22, 2021 at 6:34 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Ah but then they wouldn't be able to stroke themselves off by creating the "Thinnest, lightest Macbook EVER!!!!"
    FrenchToasty and shifty`[QUOTED] like this.
  3. Sep 22, 2021 at 6:44 AM
    daveeasa
    I’m going to see how far I can get trying to fit SSC2’s into the oval factory fog light location. We shall see how that goes. They seem like a decently similar form factor but I don’t have them yet.
  4. Sep 22, 2021 at 6:52 AM
    I'm, like, juse a thin plastic tray to house the batteries. Adds less than a half ounce of weight. Heaven forbid someone should actually be able to service a battery.
    I ended up having to go back to his house half an hour after I left because - Apple's awesome wisdom shining here once again - There's a thin non-stick metal shim they glue over the touchpad on this series, its the brown thing outlined in this picture. Turns out the battery was glued to that shim, and when the battery swole, it broke the adhesive holding it the non-stick shim to the chassis, so it came out with the battery. When I popped in the new battery, the adhesive was holding the touchpad into an always-clicked position because there was no non-stick shim between the battery and rear of touchpad. Had to pull the new batt again, reinstall the shim, reinstall the batt over it. Jeez man.
  5. Sep 22, 2021 at 7:05 AM
    For what it's worth, if anyone else is interested in these OEM First Aid kits (like, now @FirstGenVol and @lsaami mention first aid kits for upcoming trip) Toyota's current part number for the kit with OEM bag is PT42000220, it goes for around $17 total, and even comes with PPE now :D
    Direct link to the kit HERE so you can select your local participating dealership.
  6. Sep 22, 2021 at 7:14 AM
    I'm a bit skeptical of the quality on this type of kit though. It's hard to tell from the pictures. Ever used an off brand Band-Aid? They come off after a few hours.
    Personally, I like Adventure Medical Kits. That's what we keep in both vehicles.
  7. Sep 22, 2021 at 7:53 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    No, yes the run hotter, but no where near a temp dangerous
  8. Sep 22, 2021 at 8:17 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    None have as far as I have seen. TS never separated the face-lift, TT didn't either, infact TT never called it a second gen but just called it "Tundra". I'm curious if Tacoma will share the same fate soon.
    The pro vs everybody else split was really funny.
  9. Sep 22, 2021 at 9:05 AM
    Someone from work is going all out for Halloween.
    MS22, KarmaKannon and Lil Steve like this.
  10. Sep 22, 2021 at 3:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  11. Sep 22, 2021 at 3:57 PM
    What's the difference between an electrical engineering degree and a math degree?
    about two classes!
    bmf4069 likes this.
  12. Sep 22, 2021 at 4:26 PM
    daveeasa
    I thought it was going to be a subclass :)
  13. Sep 22, 2021 at 5:25 PM
    Sunnier
    Sunny
    San Diego, CA
    Hi, guys! I just read this, found it entertaining, and figured you regulars are more likely than most to know something that might get this guy pointed in the right direction:
  14. Sep 22, 2021 at 5:33 PM
    No but someone should have told me that when I was going for an engineering degree, I was really getting a math degree along with it.
  15. Sep 22, 2021 at 5:55 PM
    MATHS.
    https://vimeo.com/77451201
  16. Sep 22, 2021 at 6:08 PM
    Garry Gum...lol
  17. Sep 22, 2021 at 7:04 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  18. Sep 22, 2021 at 7:19 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  19. Sep 22, 2021 at 7:34 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    oh - not supposed to do that? :anonymous:
    FrenchToasty and CodyP like this.
  20. Sep 22, 2021 at 8:15 PM
    Leaving the type of batteries you find in very modern, thin form-factor mobile devices plugged in constantly even when at 100% charge is generally bad. They have a penchant for over-charge situations, despite most manufacturers' attempts to under-charge, trickle charge, etc.
    Ideal situation, if you're not familiar with the type of battery is in your mobile device at least, is to charge fully and disconnect. I spent the first 15 years of my tech career managing thousands of laptops for a global company. We didn't see this with the old plastic-encased batteries, It started with the thin form-factor devices.
    Really, it only seemed to happen with the thin "ultrabooks" that stayed docked 24/7/365 would be lucky to make it 18 months without the battery ballooning so bad the plastics would plump up and laptop wouldn't lay flat. We'd occasionally see it back in the day with Blackberries and other devices using the rectangle batteries.
    Happens with phones too, good example, this iPhone 6s Plus. 1 year of use. No battery swelling w/normal all-day discharge, charge once at night. I put it on a charging dock in my shop for audio, where it was always fed a trickle of power. This is what it looked like after about 12 weeks - battery so swollen the screen was busting off.
    24/7 charging is no bueno. PS - Apple replaced this phone. They wouldn't touch it. "Too dangerous to repair, risk of fire too high".
    NUDRAT[QUOTED][OP] likes this.
  21. Sep 22, 2021 at 8:59 PM
    I was in school to get my electrical engineering degree, then I tried to take cal II and physics the same semester. Then the rona hit. I haven't been back since.
  22. Sep 22, 2021 at 9:12 PM
    Burn it. Or take it back to the "mechanic" that did the work. Some people have no business taking other peoples money for work they know they can't handle. #hackjob
    I vote burn it. The mechanic will likely never be able to fix it. Trying to undo someone else's disaster is a futile activity sometimes. It's likely your original surmission that the wrong harness is on the truck is correct. Harness swaps are fun and easy. Not. Easier to do before the engine goes in. If the truck wouldn't drive, I would not have accepted back from the mechanic or paid him for his "work".
    Sunnier[QUOTED] likes this.
  23. Sep 22, 2021 at 9:46 PM
    empty_lord
    05 rollover special
    if anyone here doesnt mind, can they grab a photo of their driver side alignment bolts? im curious about something on mine.
  24. Sep 22, 2021 at 11:09 PM
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    Best I could do this time of night.
  25. Sep 22, 2021 at 11:15 PM
    Too bad. Physics is where you learn that calculus actually has a purpose rather than asking yourself what is the purpose of this learning this shit.
    bmf4069[QUOTED] likes this.
  26. Sep 22, 2021 at 11:18 PM
    empty_lord
    05 rollover special
    that actually shows what i needed, thanks!
    Lil Steve[QUOTED] likes this.
  27. Sep 22, 2021 at 11:21 PM
    Lil Steve
    Gilbert, AZ
    :hattip: It's the least I could do for all the help you throw our way.
    CodyP, shifty` and empty_lord[QUOTED] like this.
  28. Sep 22, 2021 at 11:34 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  29. Sep 22, 2021 at 11:48 PM
    empty_lord
    05 rollover special
    KarmaKannon, CodyP, shifty` and 3 others like this.
  30. Sep 22, 2021 at 11:52 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Missed that. Thanks.
