Best Rear Floor Mat?
Discussion in 'General Tundra Discussion' started by digger21, Sep 22, 2021.
  1. Sep 22, 2021 at 6:23 AM
    digger21
    digger21 [OP] New Member
    Kane
    Tennessee
    2018 SR5 4x4 Crewmax
    LED interior and bed lights, steel off rd wheels with 285/55/20 Toyo Open Country ATIII. Tow mirrors, winnjet taillights, undercover ultra flex bedcover, chrome delete
    I’ve seen weather tech and husky along with off brands on the rear crew max flooring. Read reviews but I’m wondering from you fine people which is the best one? Husky’s looks like it doesn’t cover the flooring all the way to the door under the seat and I’ve read that weather techs slide. What’s y’all’s experiences with these?
  2. Sep 22, 2021 at 7:18 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I have husky, much better than weather tech that I have used before. My husky rear mats are full coverage, goes under the rear seat of my crewmax. They have two different ones, shorter that stops before the rear sear and then what I have that covers under the seat.
  3. Sep 30, 2021 at 2:05 PM
    LittleTundra
    LittleTundra New Member
    Oregon
    I also agree to Husky, but mainly their X-Act Contour floor mats over the weatherbeaters, since they are more flexible instead of being rigid like the Weathertech. Weathertech is pretty bad after a short while where the edge will curl and lost the shape that it is suppose to mold to.
  4. Sep 30, 2021 at 2:14 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Another one for Husky. My dog was on meds and threw up in the back. None of it leaked onto the carpet. Took it out and washed that sucker off.
    mcharfauros likes this.
  5. Sep 30, 2021 at 2:19 PM
    Husky X-Act
  6. Oct 1, 2021 at 12:47 PM
    WarEagle1
    WarEagle1 New Member
    FL
    2021 Cement Trail Edition
    Husky is great. Just put a set of the X-act in front and rear. No experience with the WeatherTech laser fit. I've got the WeatherTech all weather in our 4Runner and they're nice but not comparable. Here is a pic.
  7. Oct 1, 2021 at 12:51 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Husky x6
  8. Oct 1, 2021 at 12:57 PM
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    Haven’t installed them yet, but the original weather techs were a harder plastic and they caused a lot of people to choose the husky ones as they gripped better etc. The newer weather tech HP line is more like husky, rubber and bendable, I’ve used weather tech on several vehicles for the last 6-7 years so figured I’d give the Hp line a try and so far I like the feel, and will see the function and time soon.
    Cock-A-Doddle-Do likes this.
  9. Oct 1, 2021 at 1:09 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    My CM came with the factory rubber mats, and they don't cover nearly as well as those. Might be time to upgrade.
  10. Oct 1, 2021 at 1:44 PM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    Can you post pics after install?...thanks in advance-
  11. Oct 1, 2021 at 4:14 PM
    Enjoihavok
    Erik
    Chandler,AZ
    Just got home with the truck after a 2.5 month delivery hah, I’ll be throwing them in tonight or tomorrow so I’ll snap some for you.
  12. Oct 1, 2021 at 4:15 PM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    Appreciate it
  13. Oct 2, 2021 at 3:42 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Needs some pics!! That would be great. I’m on the fence which ones to go with.
  14. Oct 2, 2021 at 7:47 AM
    Enjoihavok
    Erik
    Chandler,AZ
    So my take away from the install: the driver side clips that hold it in place are a little tight to turn, at least on mine, I really had to push down to get them to turn, but they are not going anywhere and fit is great. The rear is wanting to fold up on the sides, but this was straight out of the box, and didn’t get time or sun, to try to let them mold back flat, I’m going to just use some 3m tape to help it lay flat to the door protector. Other then that coverage and fit is great and feels good to me, never had husky to compare too, but happy with my pick.
    D4C0A1C2-3DDC-4CFD-848F-6245198DD830.jpg ED9F9E56-D9E9-404C-B562-3EFE2E551CC8.jpg 3C8916F9-57B8-4952-90A9-D668D92976E3.jpg FFA9D8BB-B723-4310-B90D-54FA36045E4B.jpg
  15. Oct 2, 2021 at 8:03 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Tuck the rear in. Never have to worry about someone tripping on it and it never moves. I love it.
  16. Oct 2, 2021 at 8:04 AM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    Thanks for the pics, does the rear mat seem to be the same thickness as the fronts?
    Enjoihavok[QUOTED] likes this.
  17. Oct 2, 2021 at 8:14 AM
    Enjoihavok
    Erik
    Chandler,AZ
    I just left with the kids to the zoo, but in the mini van, I’m pretty sure they felt and bend the same so I’m going to say yes but I’ll check when I’m back.
  18. Oct 2, 2021 at 9:01 AM
    Limp Mode
    Limp Mode New Member
    I've gone through all of them... Weathertech, Weathertech HP, and Husky... I now use Husky front and Weathertech HP rear. Here's my takeaway:
    *The normal Weathertech I disliked due to how slippery it was. Hated that feeling under my feet.
    *The Weathertech HP I like and use for the rear. I simply didn't like how the Husky rear looked.
    *I use Husky for the fronts, since I too had an issue with the Weathertech HP front making the retention clip excessively hard to turn. Not that a dremel couldn't fix this.
    *I do like how water has more of a place to go on the Husky. If my shoes are wet they don't have to sit in a standing puddle.
  19. Oct 2, 2021 at 9:01 AM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Another vote for Husky. Still going strong after 4+ years.
  20. Oct 2, 2021 at 9:12 AM
    wakeboarder
    wakeboarder New Member
    13 Tundra
    Husky. I’ve had mine for a year and they still look new. I have the DC, so not an exact comparison, but with two kids that climb in and out of the back every day, no edges curling and all the mud from soccer/baseball games gets caught by the full coverage mat.
  21. Oct 2, 2021 at 10:12 AM
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    Mind sharing where you purchased the Weathertech HP for the rear and cost for such?
  22. Oct 2, 2021 at 11:34 AM
    Enjoihavok
    Erik
    Chandler,AZ
    Weather tech website is normally the best option, I spent a good month trying to find deals or discounts else where nothing really out there. On there website you can pick front, back or set.
  23. Oct 2, 2021 at 11:40 AM
    Willard
    Willard New Member
    2024 F250
    I use husky xact in front and weathertech in the rear. The rear weathertech covers way more of the sides below the seats where my children are always climbing in and out.
  24. Oct 2, 2021 at 11:49 AM
    smokey0810
    smokey0810 New Member
    '03 Tundra SR5 AC 4WD
    Using weathertech from a Tacoma in my Tundra. They fit pretty well and we’re free from a coworker that was upgrading to a newer Taco. I’m not too keen on them being such hard rubber/plastic, but they get the job done.
  25. Oct 5, 2021 at 6:05 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Husky all the way around for me. Very happy with them.
  26. Oct 5, 2021 at 7:51 AM
    SSPey
    SSPey .
    Oregon
    2021 DinoSR5
    Husky Weatherbeater (front) and Weathertech (rear). I keep my rear seats up a lot for tossing stuff on the rear floor, and appreciate the full coverage of the Weathertechs in the back. Personally am not a fan of soft squishy floor mats, this isn’t a luxury passenger car for me. I often wear studded wading boots and prefer a harder durable material underfoot.
  27. Oct 5, 2021 at 7:53 AM
    Black
    2014 Tundra Limited CrewMax
