Speedometer/odometer question
Discussion in 'General Tundra Discussion' started by Netmonkey, May 9, 2017.
  1. May 9, 2017 at 5:05 AM
    Netmonkey
    Netmonkey [OP] Don't be a Dumbass
    Georgetown, TX
    hey guys... question for ya...
    so, changing tire size affects the correct reading of the speedometer. the larger the tire, the faster you are going compared to what the speedometer shows. for me, i went about 3% larger on the tires and this brought my actual speed in line with what the speedometer shows (verified with GPS). for larger differences, i know there is the calibrator that you can buy to correct the speedometer reading.
    however, what about the odometer? for me, since the speedometer is now correct, would the odometer also be correct? or would i need to add in 3% additional miles to what the odometer shows?
    thanks,
  2. May 9, 2017 at 7:57 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    My DC did the same. According to GPS, I was going 2mph slower than what speedo was showing on stock tires. Bumped up to 33", now my speedo and GPS are spot on. Logically, I would assume the odo and speedo are calibrated to each other to prevent any discrepancies.
    That's a good question though..I'll have to check that out on the way home.
    15whtrd and Netmonkey[OP] like this.
  3. May 9, 2017 at 8:26 AM
    Should be the same
  4. May 9, 2017 at 8:32 AM
    Netmonkey
    Georgetown, TX
    so, are you saying that my odometer should be correct now?
  5. May 9, 2017 at 8:36 AM
    Should be, yes. My understanding it would be in line with the speedometer as new tire sizes are calculated in the calibrator.
  6. May 9, 2017 at 9:14 AM
    Netmonkey
    Georgetown, TX
    wait... in my example, i did not use a calibrator. with the larger tires, the speedo just happens to be correct now. would the odometer be correct as well?
    i guess a better question would be.. does the speedometer and the odometer use the same readings for their calculations? and if the calculations for one gauge changes, will the calculations for the other gauge change as well?
  7. May 9, 2017 at 9:25 AM
    If u use a calibrator, if should be in line. Speedo and odo
  8. May 9, 2017 at 12:23 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    Yes you're correct. They coincide with each other. If you're speedometer used to say 2 miles an hour slower than what gps said that means that in one hour going 60 mph you thought you went 60 miles in reality you only went 58. Your odometer will think the same way.
