Self built flares
Discussion in '2.5 Gen Tundras (2014-2021)' started by joeguam, May 8, 2017.
  1. May 8, 2017 at 8:47 PM
    joeguam
    joeguam [OP] New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    I got tired of the Fender Flares and rocks either scratching or chipping the paint. I decided functionality over look. I purchased (4) ABS Black sheets 0.090 in x 12 in x 96 in. Attached are pictures through out the placement, cutting, heating and drilling.
    Screw placement using clay but the inner trimming has to be conducted first so the sheets sit flat because of the OEM fender lining bulge.
    Trimming and Cutting station
    Before the shaping of the squared sheet with the cutter, dremel and chisel.
    After shaping example, same as the drivers side front.
    Rear placement and shaping
    Examples of the under side cuts of the sheets
    Finish product
    JC303, Law323, Newm and 6 others like this.
  2. May 8, 2017 at 8:50 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    This is fine work my friend!
    dragos28 and Jsena like this.
  3. May 8, 2017 at 8:52 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Not gonna lie, I was skeptical but that came out pretty awesome man. Nice out of the box thinking!!!
    Newm and Jsena like this.
  4. May 8, 2017 at 8:52 PM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    I've got to hand it to you ... that's pretty cool and doesn't look half bad. Thumbs up to you Brother :thumbsup:
  5. May 8, 2017 at 8:55 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    And thanks alot Joe.... I might hit you up for a set because I'll definitely be going with a -44 offset
    GNTundra likes this.
  6. May 8, 2017 at 9:00 PM
    joeguam
    JOE
    I had to get used to the look at first. After positive responses driving around town it became easy to accept. Some people asked where or if it is the Husky flares. The husky flares were my first choice but they were to short in length so now my Truck has a wider stance with the protection. Black paint scratches just looking at it, so I had nothing to loss. Why not build it and then if I wanted it off then I just remove the 52 screws. and attach the mud flaps.
    Law323, MakMurph and Jsena like this.
  7. May 8, 2017 at 9:03 PM
    joeguam
    JOE
    You have to hit me up quick as the truck leaves for overseas assignment. Easiest and cheapest is to trace the set I have on paper and send it your way. Then when you buy the ABS sheet you can just trace cut and drill. Easy peasy! o_O
  8. May 8, 2017 at 9:23 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    What wheel and offset you running?? Pretty creative flares bro.. nice job
  9. May 8, 2017 at 9:52 PM
    r4z0r51o
    Dave
    I know for a fact he's on Fuel Nutz (D251's :drool:) 20x12", but don't know what offset. See post #13 in the following link.
    https://www.tundras.com/threads/lets-see-those-black-rims.8303/
    A lot more aggressive than mine that's for sure :thumbsup:
    Jsena[QUOTED] likes this.
  10. May 8, 2017 at 11:03 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm not sure if I like the look but the craftsmanship is great! It's very creative and really well done.:thumbsup:
  11. May 8, 2017 at 11:29 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I'll be honest, when I read the title I was a little scare to open this thread in fear of this. 0c87f3100309f9784add5587614f2457_3f3b9fcef795e3541a7cf55c2908f64c67a68d52.jpg
    Pleasantly surprised by the turn out of them. Looks good man! :thumbsup:
  12. May 9, 2017 at 7:03 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  13. May 9, 2017 at 7:47 AM
    Newm
    Newm New Member
    KC
    Not going to lie....I was skeptical at first as well, but it turned out great man. Nice Job!
  14. May 9, 2017 at 7:50 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Huh...that doesn't look half bad!
    Great job buddy!
  15. May 9, 2017 at 7:54 AM
    CPsTundra
    CPsTundra 915
    Super White CM TRD Pro
    Impressive!!!! Looks like it belongs on the truck.
  16. May 9, 2017 at 8:59 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Nice work Joe. Does it make any noise from the wind at highway speeds?
  17. May 9, 2017 at 10:06 AM
    joeguam
    JOE
    Thanks and I have not noticed any noice. I tried to make it as aero dynamic as possible to allow the wind to flow through.
  18. May 9, 2017 at 10:24 AM
    joeguam
    JOE
    Kind of the look of the Jeep flares just ABS not metal
  19. May 9, 2017 at 10:45 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Looks great. Awesome workmanship. Now you need wheels with a larger offset.
    LOL, J/K. That will put you back where you were before.
  20. May 9, 2017 at 11:56 AM
    I thought they looked a lot like the JK fender flares.
    Nice work on being creative and thinking outside the box. That is all I have to say about that. (Forrest Gump voice)
  21. May 9, 2017 at 1:12 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    He's got a -44 offset I think. 35x12.5 nutz
  22. May 9, 2017 at 1:19 PM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    -44 offset with 4.75 back space and the fuel Nutz 2 piece.
  23. May 12, 2017 at 4:52 PM
    Mac25
    Mac25 New Member
    Looks nice. Good work
  24. May 13, 2017 at 12:14 AM
    Paulskie
    Paulskie New Member
    Paul
    2014 Attitude Black 1794
    SABM, TRD sway bar, interior LED swap, Husky's in front and WeatherTech in the back, TRD Pro Grill, Rigid Fod lights, Rigid 40" E-series, Rigid 32" hood light, BLHM with RX350/STI projectors, 4% tint, 50% windshield.
    looks great.
