Frame Bracket Rust
Discussion in '1st Gen Tundras (2000-2006)' started by remington351, Sep 19, 2021.
  1. Sep 19, 2021 at 5:25 PM
    remington351
    remington351 [OP] New Member
    2006 SR5 DoubleCab
    Hi Guys,
    Has anyone dealt with this? This looks to be a reinforcement bracket that is riveted to the rear frame. Mine is a 2006 Doublecab. My concern is the IMG_6618.jpg pic shows the front leaf spring shackle mount. The divot you see is because rust all around the rivet holding the shackle has swelled. I'm worried the rivet may rust through or pop off. Thanks.
  2. Sep 19, 2021 at 5:54 PM
  3. Sep 19, 2021 at 6:16 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    it was a boatload of work, but it's held up fantastically. @remington351 yours looks very similar to how mine was when I got my truck. Nothing a few days with a cutting wheel and a welder can't fix...:thumbsup:
  4. Sep 19, 2021 at 6:18 PM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Doesn’t look as bad as some I’ve seen… probably got another 8 years before it falls apart… unless it lives in the salt. :notsure:
  5. Sep 20, 2021 at 11:12 AM
    remington351
    2006 SR5 DoubleCab
    Glad to know it's not catastrophic. Thanks guys.
  6. Dec 27, 2023 at 1:14 PM
    Ed M
    Ed M New Member
    Ed
    2006 Tundra Double Cab
    Those pictures could have come from my vehicle. It was worse next to the muffler where I assume the heat sped up the chemical reaction. I regularly get underneath my vehicle looking for rust, but these reinforced areas are obscured by the muffler on one side and fuel tank on the other.
    I just wish I had seen this sooner. I was not as vigilant as I could have been as I live in WA State which isn't considered a "rust belt" state. Unfortunately, in the last few years they have started to use de-icing agents that are clearly corrosive.
    I've hit the areas with Ospho/Phosphoric acid and once that dries will treat everything with Fluid Film.
  7. Dec 27, 2023 at 1:16 PM
    shifty` Ten EV 12's so you know I raise hell
    Sucks they never included '04+ in the rusty frame safety campaigns. :(
