Brake line help
Discussion in '1st Gen Tundras (2000-2006)' started by Drfarquad, Sep 9, 2021.
  1. Sep 9, 2021 at 5:29 AM
    Drfarquad
    Drfarquad [OP] New Member
    Bobby
    Milford
    2005 Tundra Limited DC
    OME 3 inch lift level, UCAs, Icon AAL
    No pics of my problem yet but I'll take some to further clarify if needed.
    05 double cab limited
    Anyway, need help figuring out exactly which brake line im trying to replace.
    So in the attached picture it's the line with the "zig zag" comes from the abs block down to the small block, almost directly under the driver's door. The one I need IIRC is the line that goes to the bottom fitting on that small block.
    Every time I search it up I find it with 47325 except when I go to search it up on mcgeorge toyota. When I look that part number up on that website it comes up with totally different brake line. Still involving the rear brakes but appears to be on the rear axle housing and not the one running from the abs.
    If anyone knows which part number I'm looking for or even the correct name for this line would be great help. Thanks.
  2. Sep 19, 2021 at 4:23 PM
    Drfarquad
    Bobby
    Milford
    Anyone have any insight on this?
  3. Sep 19, 2021 at 5:40 PM
    NetGnome
    NetGnome New Member
    NJ
    Removed lots of rust.
