  1. Sep 19, 2021 at 2:25 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Unfortunately no. Lots of aftermarket ones do
    doggiecareman[QUOTED] likes this.
  2. Sep 19, 2021 at 3:02 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    Bought some replqcement valve caps as I was missing a couple. Got the longer 'tpms specific' ones, unfortunately only 1 goes on as the stems seem to be not out far enough? 2nd wheel pic is the valve that took the cap.
    They all seem tight. For now the others have regular schraeder bicycle type caps.
    GAknight and Fotnot like this.
  3. Sep 19, 2021 at 3:05 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Just ordered my new Faulken wildpeak AT3 tires and the bumper shim kit from coachbuilder. I’ll post pics in a few weeks when I get everything installed.
  4. Sep 19, 2021 at 3:35 PM
    aark12
    aark12 AARK12 - Hello All
    New Mexico
    2020 Tundra Limited TRD
    Bilstein 6112, Pedal Commander, TRD Pro BBS Wheels, Gator Tonneau Cover, Bed Step, TRD Pro Grill, Mirror Caps, Grab Handle, Dirty Deeds 10in System, rear bumper step, dash cam
    :amen:First time using it but impressed so far!
  5. Sep 19, 2021 at 3:53 PM
    jordoncloutier
    jordoncloutier New Member
    Jordon
    Alberta , Canada
    2019 Tundra CrewMax SR5 Plus 4x4
    Daily Driver / Tow Vehicle , Retrofitted Trans Cooler , 10 Ply tires , Raptor Lined Ranch Hand Grille Guard
    AggiePhil, 2018Tundra, nhw544 and 5 others like this.
  6. Sep 19, 2021 at 3:53 PM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
  7. Sep 19, 2021 at 3:56 PM
    Do the door seals and all the plastic on the bed rails, bumpers and if you have plastic overlays on the running boards.
  8. Sep 19, 2021 at 3:58 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I just upgraded mine recently too:rolleyes:
  9. Sep 19, 2021 at 4:00 PM
    Bergy24
    Bergy24 New Member
    Built a grocery box to keep everything from rolling around the bed. Only cost me about $23 to make, (paint and handles) Also had the front windows tinted (20% ceramic)
  10. Sep 19, 2021 at 4:03 PM
    :101010:
  11. Sep 19, 2021 at 4:19 PM
    TNTundra16
    TNTundra16 YOU BIG DUMMY!
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    Headed to the woods for the afternoon. Followed this rainbow most of the way home.
    GAknight, Cosmoblu, GODZILLA and 16 others like this.
  12. Sep 19, 2021 at 5:07 PM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Got me some AlphaRex headlights as of yesterday. No chances of installing it yet cause I spaced out on ordering a convertor. On a plus note, if anyone was interested in changing their halogens headlights into a brighter and cooler looking OEM LED Headlights, let me know.
  13. Sep 19, 2021 at 5:17 PM
    Yzed608
    Yzed608 New Member
    Wisconsin
    GAknight, GODZILLA, FishFlash and 5 others like this.
  14. Sep 19, 2021 at 5:31 PM
    406Michael
    406Michael New Member
    2014 Limited CM
    20210919_152211.jpgGot the aluminum skid installed today, as well as Rab Rubber fender liner engine splash guards(the stock one were ripped off when I bought the truck used).
    GAknight, Cosmoblu, FishFlash and 8 others like this.
  15. Sep 19, 2021 at 5:38 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I was about to buy these the other day, but I forgot to put 2 of the cheap black ones back on the last time I aired up. So this probably isn’t a product for me.
  16. Sep 19, 2021 at 7:02 PM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    Changed the oil at 2400 miles since I’m picking up my Escape 19 travel trailer in 10 days and wanted to get the break in debris out. The filter had a decent amount of metal in it. I’m sure the oil was fine and the filter was doing a good job, this was just more for peace of mind when towing. I used Valvoline 0w20 “Extended Performance” and an OE filter.
    GODZILLA, FishFlash, WILLINH and 2 others like this.
  17. Sep 20, 2021 at 6:36 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Mild lift with Bilstein 5100's on top setting. 1 inch ready lift rear block, was level before installing the rear blocks, I tow a boat about every weekend for 4 months a year and didn't want the back sagging too much. Front passenger side measures 39.25 inches, drivers side.25 lower. rear 40.25. pretty much exactly what height difference is advertised from the highest setting vs stock. I pulled off the black OEM shocks with 38k on them. I think the 5100's on the top setting are SLIGHTLY firmer. Just barely enough to notice, still rides very nice. Debating adding 5160's to the rear vs 5100's. Haven't pulled the trigger on either yet, I know I need to swap the OE with something made for the 1 inch lift.
    I'm not due for tires anytime soon but my intention is to run the largest all terrain (tallest) tires I can in the future. I doubt these have 7k miles on them. Anyone running TSS wheels on a similar setup that can recommend a tire size? 34 1/2ish equivalent I'm guessing? 295 60 R20? the factory TSS tires are just under a 32inch equivalent. I have an RCI front skid plate waiting to go on and I'm not afraid to heat up the wheel well liners and bend them out of the way etc. but i do NOT want to do a cab mount chop. Waiting on front and rear Valhalla shields to come in so I can get them all powder coated to match.
  18. Sep 20, 2021 at 6:43 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    You just need to order two sets :boink:
    Hightide and TRDFerguson[QUOTED] like this.
  19. Sep 20, 2021 at 8:09 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Beautiful!
    TNTundra16[QUOTED] likes this.
  20. Sep 20, 2021 at 9:04 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Didn’t feel like doing Monday things… so I went to the track :)
  21. Sep 20, 2021 at 9:05 AM
    COTundra23
    COTundra23 New Member
    What lugs did you buy and where from?
  22. Sep 20, 2021 at 9:08 AM
    French Avocado
    Utah / Wyo
    Change the look day. We start the day with:
    Then in the interim get a good look at the Falcons:
    And then the Falkens:
  23. Sep 20, 2021 at 9:17 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Man, I can. not. wait... I'm past the 8-week mark already since I got the invoice.
    Couple q's... Did you have a Platinum stock front sway, or TRD; and is it more rolly now compared to pre-level? Rear? Any other comments or things I should be looking for? I like the stock feel with stock front and no rear sways; but if I'll want to move to stiffer front and adding rear, I'll likely want to get the shop to install those while they have the truck up on the lift.
    Your truck looks really nice.
  24. Sep 20, 2021 at 9:18 AM
    RobertD
    Robert
    DFW, Texas
    Heck of an improvement!
  25. Sep 20, 2021 at 9:35 AM
    French Avocado
    Utah / Wyo
    Replaced stock front sway with TRD at same time as Falcons installed and then I added rear sway as well. It is now planted to the ground, a lot less roll (corners at 35 mph). I do not find it stiffer but much greater control.
    Fotnot, 1794TX[QUOTED] and RobertD like this.
  26. Sep 20, 2021 at 9:45 AM
    1794TX
    Steven
    N.TX
    '20 1794
    thank you sir. prolly the direction I'm headed.
  27. Sep 20, 2021 at 9:56 AM
    TNTundra16
    Cam
    Amish Country, TN
    2016 CM SR5 4x4 SSM
    :amen:
  28. Sep 20, 2021 at 9:57 AM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    What rotors and pads did you go with
  29. Sep 20, 2021 at 9:58 AM
    woods
    woods New Member
    2021 SR5 TRD Sport
    some fuels and toyo at3s. waited on methods for 3 months and they kept delaying, oh well.
  30. Sep 20, 2021 at 10:05 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Stoptech rotors and Stoptech Sport pads.
