1” Spacers - cutting studs required?
Discussion in 'Wheels & Tires' started by Tundra18overland, Sep 17, 2021.
  1. Sep 17, 2021 at 7:01 AM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Tried searching, couldn’t get a direct answer to this.
    Looking at 1” Bora spacers. Do these require cutting factory studs?
    Thank you, post pics if you’re running these.
  2. Sep 17, 2021 at 7:29 AM
    pandapro
    pandapro New Member
    Check the backside of your wheels. If there are voids in the spaces where the studs would pass through on the spacer, you’re good. I used 1” spacers on my BBS TRD Pro wheels without issue.
    DZ_ likes this.
  3. Sep 17, 2021 at 7:35 AM
    I would never cut a wheel stud to shorten it.
  4. Sep 17, 2021 at 8:33 AM
    TXTundra2722
    2015 Black Tundra
    Agree with the above statement... never cut your studs. If you run an aftermarket wheel, this probably won't work and I think only certain Toyota wheels have the "gap" mentioned previously, that's on the back side.
  5. Sep 17, 2021 at 9:07 AM
    TRDSPEC
    TRDSPEC New Member
  6. Sep 17, 2021 at 3:27 PM
    ronh
    ronh New Member
    Ron
    Mesa, Arizona
    2018 Tundra 4x4
    I measured my wheel studs on my 2018 and they were 1 1/16”, so just a hair long unless your wheels have a void on the backside. I have heard some say their studs are less than and inch and there is no issue.
  7. Sep 17, 2021 at 3:37 PM
    Tundra18overland
    Jesse
    GA
    thanks man!! are those 1" bora spacers?
  8. Sep 18, 2021 at 12:53 PM
    EZDoes It
    EZDoes It New Member
    Ed
    LSD (Lower Slower Delaware)
    2020 MGM CM SR5 TRD exhaust, TRD wheels
    Tint, tow mirrors, remote start, Razormotor taillights, Genuine trans cooler, tailgate light strip, Extang tonneau, TRD rear sway bar, trans cooler…(thanks TRD)
  9. Sep 18, 2021 at 3:09 PM
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I actually removed a tiny bit of aluminum from my wheels to clear the little bit of stud that sticks out.
  10. Sep 18, 2021 at 3:12 PM
    bigblue14
    Craig
    Pictures now
