Traction and ABS light
Discussion in '2nd Gen Tundras (2007-2013)' started by 82angelfan, Oct 9, 2019.
  1. Oct 9, 2019 at 6:24 AM
    82angelfan
    82angelfan [OP] New Member
    2012 tundra 4wd TRD 5.7
    traction and abs light on. No cruize control.
    I thought it was due to air bags. Used them this weekend at 75 pounds. Right bag leaks so leve was off by yesterday. Let the air out and lights went out. Back on this morning. Tried 4hi trick someone mentioned. ABS off but traction light still on.
    Recently replaced right rear calipers.
  2. Oct 10, 2019 at 5:13 AM
    82angelfan
    Anyone?
  3. Oct 10, 2019 at 5:20 AM
    15whtrd
    15whtrd Mr. Blonde
    Check for codes? Check the wiring to the ABS sensors.
  4. Oct 10, 2019 at 6:45 AM
    marinakorp
    marinakorp New Member
    2010 DC 5.7 SR5 TRD Mica Green
    Tow Mirrors, Tekonsha p3, 12 v Solutions remote Start,Weather Tech Mats, Truxedo Roll up Tonneau
    That combination is likely a wheel sensor - if you replaced the brakes...bet the sensor is bac or broken, etc...
  5. Oct 10, 2019 at 7:10 AM
    82angelfan
    I'll check em.
    Did the brakes a few months ago, just now having issues.
    Could be loose.
    Seemes to come on at same sharp, downhill, off camber, bad asphalt turn each morning. Turns off on drive home.
  6. Oct 10, 2019 at 9:04 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Check your wheel bearings for looseness / play.
  7. Oct 10, 2019 at 9:25 AM
    82angelfan
    Ugh, don't even wanna think about that. But will now.
  8. Oct 10, 2019 at 4:19 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Understandable. But if a bearing has play, the wheel speed sensor will not produce a good signal, especially in corners.
    15whtrd likes this.
  9. Oct 11, 2019 at 6:02 AM
    82angelfan
    Update. Seems to happen only in the morning? Temperature maybe? Seems unlikely. First clue of problem is cruise control wont work. I noticed it before the before mentioned turn. I have an ODDii scanner but it is 17 years old. Not sure it will read codes.
    Everything works driving home in the afternoon
  10. Oct 11, 2019 at 6:52 PM
    82angelfan
    Could low voltage cause this issue. I noticed that when I turned on my lights tonight my cruise turned off. Now traction and abs on. I have week battery
    landphil likes this.
  11. Oct 11, 2019 at 7:05 PM
    Jrharvey02
    Jrharvey02 New Member
    I’ve seen many xmas tree dash lights ending up being bad battery on this forum. Batteries do only hold half their capacity at freezing temps (mornings)...
    15whtrd likes this.
  12. Oct 11, 2019 at 7:56 PM
    82angelfan
    Ok, need new battery. Will change tomorrow, also check codes. Been driving on week battery for awhile. Radio drains it in ten minutes.
  13. Oct 11, 2019 at 10:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I wouldn’t be one bit surprised if a new battery cured it all.
    15whtrd and 08crewmax like this.
  14. Oct 12, 2019 at 3:29 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    Just got a new battery the other day, the old one died at the gas pump and the folks behind me weren't real happy but the guy said sh*t happens. The station manager jumped me and I drove off to get a new one. Funny part is with the new battery with a full tank I had 450 miles to the tank and was getting 25 MPG, darn that didn't last long.
  15. Oct 12, 2019 at 9:13 AM
    82angelfan
    Update.
    New Battery, no codes on Actron OBD2 CP9145 tester. Alternator indicator hovering at 14v. I will test with digital meter later. Drove it about 20 miles. Cruise control worked until I turned on lights. As soon as lights went on cruise shut off, however, no traction control or ABS issues unless I didn't leave lights on long enough to register problem.
    Any ideas?
  16. Oct 12, 2019 at 2:10 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    How clean and bright are those battery terminal clamps on the inside, and at the stud connection on the positive? Ground cable tight at the inner fender?
  17. Oct 12, 2019 at 2:12 PM
    82angelfan
    Terminals and battery connections good. I haven't checked the rest. I will though.
    You'd think a union certified electrician would check that first.
  18. Oct 12, 2019 at 5:30 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Thinking about this more, check your tail lights and brake lights. Make sure the tail lights work and then the brake lights come on brighter. A bad ground connection to the dual filament bulbs or within the bulb itself will backfeed power from the tail light circuit to the brake light circuit.
    It will cause cruise issues, and ABS /trac issues, as the brake signal is an input to both modules.
    LED bulb conversions can be the cause of this as well.
  19. Oct 12, 2019 at 5:54 PM
    82angelfan
    Will do. I do have a brake light out. I'll change it. The See what happens
  20. Oct 14, 2019 at 5:26 AM
    82angelfan
    Solved!! Brake light. Crazy. Thanks to everyone who posted.
    landphil and D4x4TRD like this.
  21. Oct 14, 2019 at 7:33 AM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    I'm glad you got it figured out. that's interesting how a brake light affected the electrical like that.
  22. Oct 14, 2019 at 7:37 AM
    82angelfan
    Thanks to landphil. Now I feel guilty dumping all my trash on him.
    Yeah, that is weird. But from an electronic view point, and electrical it makes sense.
    In the electrical industry we are just discovering that all these DC led drivers are effecting the AC voltages.
  23. Sep 16, 2021 at 5:58 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    I have a 03tundra v8, abs light came on yesteday. I noticed passanger belt is broken.
  24. Sep 16, 2021 at 7:13 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    First gen Tundra pages are here: https://www.tundras.com/forums/1st-gen-tundras-2000-2006.2/
    I would make a new post. Rehashing something that has been dead for years will lead to strange occurrences.
