  1. Sep 16, 2021 at 6:47 AM
    Nic146
    Nic146 New Member
    Probably stuck somewhere
    2016 Barcelona Red TRD CM
    I didn’t realize that came stock on the newer trucks.
    Can you run fogs + highs from the factory? I was under the impression that wasn’t legal (therefore no manufacturers did it)?
  2. Sep 16, 2021 at 7:02 AM
    infidel
    infidel New Member
    Jesse
    SE Wisconsin
    2016 Silver SR5 Crewmax
    Procomp 3/1 Method 307 18x9 +25 Falken Wildpeak AT3W 295/70r18
    In the state of Wisconsin it's not legal, but fuck um'
    mgm16trdpro and Nic146[QUOTED] like this.
  3. Sep 16, 2021 at 7:04 AM
    Nic146
    Nic146 New Member
    Same with CO. That’s why I was thinking manufacturers don’t do it.
    …and why it should everyone’s first ‘mod’ :D
    mgm16trdpro likes this.
  4. Sep 16, 2021 at 7:12 AM
    1/68AR Ventre A Terra
    1/68AR Ventre A Terra New Member
    2019 Platinum
    Viking Heaven Cat Shields and SR5 Rims
    Did not realize how much I would like the look of the AJT Black vent ring covers. No weird sun reflections and they just look cool. 40D1663D-7462-431B-A067-4A1A0C852253.jpg
    GAknight, GELCW, jeffw6236 and 8 others like this.
  5. Sep 16, 2021 at 7:18 AM
    Taco-Spike
    Two Trucks
    nhw544 and Sean492 like this.
  6. Sep 16, 2021 at 7:23 AM
    Kenro83
    Kenro83 New Member
    2018 Blck Tundra TSS
    where’d you buy these?
  7. Sep 16, 2021 at 7:46 AM
    AJT designs
  8. Sep 16, 2021 at 7:47 AM
    2019 Platinum
  9. Sep 16, 2021 at 9:18 AM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    "but fuck um'"... uhhhhherrrrr....
  10. Sep 16, 2021 at 9:57 AM
    VTYOTER
    VTYOTER Rock
    Torrey
    Vermont
    2021 TRD Pro LR
    35" KO2, METHOD 701, WESTCOTT COLLAR, CB+3, BUMPER SHIMS, CALIRAISED ROCK SLIDERS STEP EDITION, DIAMONDBACK HD
  11. Sep 16, 2021 at 10:17 AM
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    :eek2: GORGEOUS!
    VTYOTER[QUOTED] likes this.
  12. Sep 16, 2021 at 10:21 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    No, the 2020+ functions the exact same way. Fogs go off when Highs come on.
    I'm gonna do this mod this weekend actually.
    And yes, most states have a limit of only two sets of forward-facing lights active at one time (the high beams have high and low both on at once). But the way I see it, I'm only running my high beams when I don't have someone in front of me.
  13. Sep 16, 2021 at 10:33 AM
    TheBlackPearl
    La Gulf Coast
    Went ahead and picked up the Yakima Loadwarrior while evacuated in Sugar Land, just got the extension in yesterday and put it all together! Things are slowly coming together.
  14. Sep 16, 2021 at 10:35 AM
    SAGE63
    San Diego County
    What is the mod.... or wait to install the amber fogs and connect thru the switchpro...
  15. Sep 16, 2021 at 10:44 AM
    AZBoatHauler
    So.Arizona
    These are the directions I followed to do this mod on my 2017.
    Nic146 and 1794TX like this.
  16. Sep 16, 2021 at 11:39 AM
    RainMan_PNW
    Casey
    Clark County, WA
    What this guy said:
    I did it on my 2008 originally. A couple weeks ago driving through MT in the middle of the night in a bug storm (literally - looked like a snow storm of bugs) while trying to scope for deer on the sides of the roads I was REALLY wishing I had my fogs on with the high beams. I was also wishing I had a few hundred thousand worth of lumens in ditch lights and chase lights as well because there were a few stretches where it was like a game of frogger but with deer.
    Hightide and Nic146 like this.
  17. Sep 16, 2021 at 11:40 AM
    The wiring is different in the 2020 and newer models.
    AZBoatHauler[QUOTED] and SAGE63 like this.
  18. Sep 16, 2021 at 11:51 AM
    aark12
    aark12 AARK12 - Hello All
    New Mexico
    2020 Tundra Limited TRD
    Bilstein 6112, Pedal Commander, TRD Pro BBS Wheels, Gator Tonneau Cover, Bed Step, TRD Pro Grill, Mirror Caps, Grab Handle, Dirty Deeds 10in System, rear bumper step, dash cam
    I have the 10 inch system and it’s great. If you don’t want any drone in the cab install the resonator, it made a huge difference.
  19. Sep 16, 2021 at 12:02 PM
    aark12
    New Mexico
    Installed the Pro Clip. Very impressed with it so far.2FFC45E7-D9BE-4DBB-85AF-C79BDB1B3E16.jpg
    JTNic, GAknight, nhw544 and 3 others like this.
  20. Sep 16, 2021 at 12:07 PM
    Nic146
    Nic146 New Member
    I followed those directions as well for my 3rd gen + the below video. Those two things in combo were enough info to get it done.
    https://youtu.be/JUIbnVGmtZI
    pvn.beluga and 1794TX like this.
  21. Sep 16, 2021 at 12:09 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yes...sort of. Specifically, it changed in 2018.
    In comparing the 2008 EWD to the 2018-2021 EWD, the connectors and the colors of the wiring are different for 2018-2021 trucks. But the function of the headlight switch and how that signal is "processed" to activate the fog light relay are nearly the same. The ONE difference is that the Fog Light Relay coil in 2018+ no longer uses the Tail Light Relay to provide the power to the coil (which is controlled by the ECU). In the 2018+, the positive side of the Fog Light Relay coil is supplied power direct from the battery - so if you were to jumper the equivalent wires in the 2018+ trucks the way described in the "Fast Eddie v1" document, you would end up with your fog lights being on any time you had the fog light switch on (you are essentially hard-wiring your fog light wand as a dedicated switch).
    So, in order to have the same function that is in the 2007-2017 trucks using the "Fast Eddie v1" modification, you would need to replace the power feeding the fog light relay coil with power from the output of the tail light relay as well.
    2008 Fog Light Relay:
    2008 Fog Light Switch:
    (Fast Eddie V1 is jumpering the pink fog light switch wire to the grey fog light coil wire, which then relies on the power supply from the tail light relay controlled by the ECU to enable the coil).
    2018+ Fog Light Relay (power to the coil is provided by the front fog fuse):
    2018+ Fog Light Switch (different color wire, same function).
    2018+ Tail Light Relay/control/output
    Of course, the challenge here is that the power to the fog light relay and the fuse it comes from are both in the same box, so you'd have to do some creative surgery to modify that power source.
  22. Sep 16, 2021 at 12:15 PM
    Nic146
    Nic146 New Member
    Interesting, I misread the above posts. I didn’t realize that the newest trucks were different.
    Thank you for the solid info and good explanation. :bowdown:
    1794TX, Hightide and AZBoatHauler like this.
  23. Sep 16, 2021 at 12:19 PM
    AZBoatHauler
    So.Arizona
    :fistbump:
    1794TX and Nic146 like this.
  24. Sep 16, 2021 at 12:22 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Washed / waxed / prepped the beast today with Griots stuff.
    That crap is becoming expensive and really not worth the money.
    Lots of other choices available that work good.
    RainMan_PNW likes this.
  25. Sep 16, 2021 at 12:23 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yes, and to be clear - you CAN turn on the fog lights with the parking lights on the 2018+ trucks. That happens to be part of what changed with them providing power from a direct battery source.
    you CANNOT turn on the fogs with the high beams - the ECU still issues the "off" signal.
    1794TX, Hightide and Nic146[QUOTED] like this.
  26. Sep 16, 2021 at 1:55 PM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    Added the charging tray...very quick and easy install.
  27. Sep 16, 2021 at 2:04 PM
    RainMan_PNW
    Casey
    Clark County, WA
    does that one have a blue charging light - most I see are green. If so, care to share where you got it?
  28. Sep 16, 2021 at 2:38 PM
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    It's green if nothings charging, blue when there is.
  29. Sep 16, 2021 at 3:04 PM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    I’ve been using that for a few months and love it.
    aark12[QUOTED] likes this.
  30. Sep 16, 2021 at 3:33 PM
    justcuz
    justcuz 2.5 Gen Member
    Painted tow hooks inferno color to match truck 04878318-3707-4A3F-B718-96D8C8BC9535.jpg
