Rear Main Seal
Discussion in '1st Gen Tundras (2000-2006)' started by 2006Tundra, Sep 13, 2021.
  1. Sep 13, 2021 at 7:50 PM
    2006Tundra
    2006Tundra [OP] Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Hey Guys,
    My mechanic replaced my rear main seal on 3/20/2020 and today, I think it blew again. I'm trying to figure out what may have caused this to blow prematurely. Any suggestions and ideas to make sure this wont happen again.
    My mechanic says he uses only Toyota parts. The more I read about this it maybe be a faulty crankshaft? I won't know until he tears the truck down tomorrow.
    Thanks
    jowillstin likes this.
  2. Sep 13, 2021 at 10:15 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Any photos of the leak? Or did you just have a puddle of oil on the floor?
  3. Sep 13, 2021 at 10:46 PM
    Chip_Tundra
    Chip_Tundra New Member
    Check all things that can create excessive pressure. I also had new rear main installed and it started leaking. Little did I know, my catalytic converter was done, and all the elements inside were restricting airflow.
  4. Sep 14, 2021 at 5:11 AM
    Could a clogged PCV valve cause this? Let's too much pressure build in the crankcase?
  5. Sep 14, 2021 at 5:59 AM
    2006Tundra
    Lou
    Long Beach, CA
    @jerryallday No pics, just a few drops in the drive way/
    @Chip_Tundra and @bmf4069 I'll call my mechanic. He's going to look it over today and I'm going to stop by to check it out after work .
  6. Sep 14, 2021 at 6:30 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Is he 100% sure it's the rear main leaking and not the valve covers? It wouldn't be the first time someone has found valve cover bolts finger tight, they seem to loosen over time.
  7. Sep 14, 2021 at 6:33 AM
    2006Tundra
    Lou
    Long Beach, CA
    Yea, he lifted the truck in the air and we saw oil coming where the rear main is. I also tighten the valve covers a few months ago because I saw oil being built up around the top. I should know more today.
  8. Sep 15, 2021 at 6:03 AM
    2006Tundra
    Lou
    Long Beach, CA
    Got my truck back yesterday. A new rear main seal was installed and new PCV valve. My mechanic says he doesn't know why it failed. The rear main looked fine and it was a Toyota part. I'm thinking it may have been a poor install OR the PCV valve wasn't working properly. He said the original PCV valve didn't look clogged but it was original so we replaced it. IDK, I'm going to drive it and monitor. Hopefully it holds.
    bmf4069 and jerryallday like this.
  9. Sep 15, 2021 at 6:25 AM
    Did he charge you again? That's typically a really expensive repair.
  10. Sep 15, 2021 at 6:27 AM
    2006Tundra
    Lou
    Long Beach, CA
    He did. I was hoping he would at least cut me a deal but since it was out of warranty, I couldn't really argue with him. Cost me $400.
  11. Sep 15, 2021 at 10:18 AM
    $400 ain't bad to drop a trans, pull a flex plate, then replace a seal.
  12. Sep 15, 2021 at 10:40 AM
    I was thinking the same thing. When the rear main was leaking on the Rav4 the Stealer quoted me almost $2,000 to replace it. :rolleyes:
    bmf4069[QUOTED] likes this.
  13. Sep 15, 2021 at 10:43 AM
  14. Sep 15, 2021 at 10:59 AM
    2006Tundra
    Lou
    Long Beach, CA
    I'm not sure why prices differ from vehicle to vehicle but I assume it must be an easier job to do on our trucks. I just hope I don't see oil again.
    What are your thoughts about switching back to conventional oil? A buddy mention, since my truck does call out for 5w-30 conventional, that I should go back because it's thicker, and full syn is thinner and will find a way to leak out.
  15. Sep 15, 2021 at 4:16 PM
    Not buying that. Oil weight is oil weight. Not related to type of oil.
  16. Sep 15, 2021 at 6:03 PM
    10 blue trucks
    10 blue trucks New Member
    04 4WD RCLB
    Agreed, if 5-30 conventional was thicker than 5-30 syn it would be labeled 10-40.
    N84434 likes this.
  17. Sep 16, 2021 at 3:07 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
  18. Sep 16, 2021 at 6:46 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Fully synthetic oil in my Tundra, no leak, and it will be old enough to drink beer next year.
    bmf4069 and 2006Tundra[OP] like this.
  19. Oct 8, 2021 at 9:01 AM
    2006Tundra
    Lou
    Long Beach, CA
    Update
    I had the rear main seal replaced a few weeks ago. After the replacement, I cleaned the area with simple green, drove it to work for a week and noticed oil is still coming from the rear main seal area. It's not a lot, doesn't drip on to my driveway but it's still a leak.
    It's back in the shop and my mechanic isn't sure why it's still leaking. He says there some bolts on fly wheel that connect to the crank shaft that may be where it's leaking from. He's going to put some sealer in that area.
    He says he's seen it leak from there before and he's put sealer on and it fixes the issue.
    He says it's not the rear main seal. Nothing is coming from the valve covers. He's pretty confident it'll work.
    Thoughts?
  20. Oct 8, 2021 at 11:43 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Some Toyota crankshafts are drilled all the way through and you need to use a thread sealant (blue loctite) on the crank bolts or oil will leak past them.
  21. Oct 8, 2021 at 12:21 PM
    2006Tundra
    Lou
    Long Beach, CA
    Fingers crossed it fixes the issue. Thanks for the reply.
  22. Oct 20, 2021 at 6:59 AM
    2006Tundra
    Lou
    Long Beach, CA
    Still leaks. Not sure where it's coming from. Hoping it's not a bigger issue.
  23. Feb 11, 2023 at 10:31 AM
    jowillstin
    jowillstin New Member
    j
    2005 toyota tundra sr5 v6 access cab
    Hey, if you don’t mind me asking, where’d you go for the rear main seal
    Repair?
    It was only $400 ?
  24. Feb 11, 2023 at 11:41 AM
    2006Tundra
    Lou
    Long Beach, CA
    Woah, I totally forgot to update. The shop is Montero’s Auto Services in Bellflower, CA. He does a good job but isn’t the cleanest mechanic.
    The leaked did stop but only after I took the inspection plate off and degreased the area. There was left over oil and that was what I thought was the leak.
    dbittle, bmf4069 and shifty` like this.
  25. Aug 4, 2023 at 7:55 PM
    ajdeez
    ajdeez New Member
    albert
    Is your truck 4wd?
  26. Aug 5, 2023 at 8:38 AM
    2006Tundra
    Lou
    Long Beach, CA
    No, it's not.
