Tundra stops on highway “Trailer break error”
Discussion in '2.5 Gen Tundras (2014-2021)' started by Latitudes77, Sep 13, 2021.
  1. Sep 13, 2021 at 5:46 PM
    Latitudes77
    Latitudes77 [OP] New Member
    Columbus, Oh
    2020 black crewmax sx
    Ugh, long day on vacation, driving across panhandle, towing travel trailer. Around noon , after 3 hours of steady towing, engine started sputtering, wasn’t taking gas very well, would only go up to about 1500 rpm, hung around 45mph for about 20 minutes, then wouldn’t go at all. Dead. When I stopped the car, finally showed “trailer break error”. This cleared after sitting off engine for 20 minutes. Found an RV park, dropped off RV, went to Toyota dealer, everything working fine. Clean Bill of health. Re-hitched RV, 100 miles later, problems started again, tundra keeps stalling… back to trailer break error, any ideas?
  2. Sep 13, 2021 at 6:00 PM
    timsp8
    NY
  3. Sep 13, 2021 at 6:05 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  4. Sep 13, 2021 at 6:08 PM
    timsp8
    NY
    Yeah, it sounds like something else.
    When it happens again, pull off the road, disconnect the trailer and see if it immediately goes away. Sitting for 20 min shouldn’t do much unless you unhooked the battery to reset the ecu.
    mountainpete[QUOTED] likes this.
  5. Sep 13, 2021 at 6:10 PM
    mountainpete
    Did you have any other lights or messages while the engine was sputtering? Any transmission warning messages?
    How heavy of a trailer were you pulling?
    timsp8 likes this.
  6. Sep 13, 2021 at 6:10 PM
    Latitudes77
    Columbus, Oh
    I never unhooked the battery. Strange the problem went away for an hour or two and came back, much worse.
  7. Sep 13, 2021 at 6:15 PM
    Latitudes77
    Columbus, Oh
    6000 lbs dry. The screen behind the steering wheel showed “trailer break error” then “pre-collision system malfunction” rotating errors. The main display showed an error that contained a generic engine, throttle, or transmission problem, contact your Toyota dealer.
  8. Sep 13, 2021 at 6:19 PM
    mountainpete
    Ok - I don’t think it’s your trailer. The studdering and those messages might be pointing to the fuel pump. Knowing the exact codes from the computer should have told the dealer.
    Was your truck included in the fuel pump recall?
    https://www.toyota.com/recall
    HulkSmurf14 likes this.
  9. Sep 13, 2021 at 6:33 PM
    Latitudes77
    Columbus, Oh
    Looked up my vin and only showing something about halogen headlamps.
  10. Sep 13, 2021 at 6:37 PM
    mountainpete
    Ok - might not be recalled but it still smells like a fuel pump to me.
    Do you have an OBD scanner? If not, one that wirelessly connects to your smartphone with an app like OBD Fusion (iOS) or Torque Pro (Android) is money well spent.
  11. Sep 13, 2021 at 7:01 PM
    Latitudes77
    Columbus, Oh
    Nope. Can I pick that up at an autozone (or have Amazon link?)
  12. Sep 13, 2021 at 7:09 PM
    mountainpete
    You can get one at Autozone that is a scanner with a screen but many people here choose to go the smartphone route. Personally I use the Veepeak OBD BLE+ but there are lots on there. Search OBD on this site and you will see some good threads on the subject.
  13. Sep 13, 2021 at 7:15 PM
    BlacknWhite23
    BlacknWhite23 New Member
    2021 Black TRD Off Road
  14. Sep 15, 2021 at 9:46 AM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    ^^This. I had an MR2 once that did very similar things when the fuel pump died.
