General Supercharger Thread
  1. Sep 6, 2021 at 1:38 PM
    #181
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Go stage 2
    don’t look back
  2. Sep 6, 2021 at 1:47 PM
    #182
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    This looks like a heck of a system, great job by Harrop delivering that without a tune.
    nobodyintexas and Platinum714 like this.
  3. Sep 7, 2021 at 3:58 AM
    #183
    nobodyintexas
    nobodyintexas What?
    South of Houston
    i like knowing the stock tune is protecting me. yes, I can feel it cutting back at certain times. that's good for me. this is my daily driver.
    As I mentioned earlier...it is awesome that an inter-cooled blower can be bolted to a stock pickup and function flawlessly. Kudos to Toyota ECU designers to build in enough headroom to accommodate a ~40% increase in airflow. Reading Harrop's white paper convinced me to pull the trigger. i.e. it ran less on the knock sensors with a stage 1 blower using 93 octane, than a stock truck using 87 octane.
    yes, I could add another 50-100 HP with a tune, but ~120hp boost is fine for now. I'm only confessing to this because the ECU is presently locked.
    and...if you get a blower (and you don't articulate off road), get the damn traction bars. look at videos with trucks that don't have them & watch how much the differential moves under load. very hard on u-joint.
    and thank you to whomever posted the tutorial on how to shut off the nannies. I can put down two black streaks as long as I stay straight.
    Platinum714 and Saltyhero13 like this.
  4. Sep 7, 2021 at 4:08 AM
    #184
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Probably thanks to the E85 support built into the fuel pump and injector capacity. The same applied (at least to the previous generation) to the GM’s 5.3 naturally aspirated engine. One could either convert it to run on E85 (which I did) or install a blower without doing anything to the fuel system.
  5. Sep 7, 2021 at 4:11 AM
    #185
    nobodyintexas
    nobodyintexas What?
    South of Houston
    true. however, mine is not Flex fuel. Harrop added a larger fuel pump to the pkg. Injectors are the same and are able to handle the 6-7lbs of boost.
  6. Sep 7, 2021 at 4:33 AM
    #186
    sd172
    sd172 New Member
    South Dakota
    Ah. Pardon my ignorance.
    The only thing that differentiated a FlexFuel and a non-FlexFuel GM truck was the ethanol sensor and the ECU tune.
  7. Sep 7, 2021 at 5:53 AM
    #187
    nobodyintexas
    nobodyintexas What?
    South of Houston
    You just reminded me of a conversation I had with the installers...they were not used to having to install a larger fuel pump, as all of the other Tundras they have done were flex fuel. those tundras had mondo fuel pumps that could handle the extra flow.
    the conversation started because they need a special wrench to get the fuel pump out of the tank. which they had to get at Toyota.
    I don't know much about methanol, so pardon if I sounded short. was not my intention.
    Saltyhero13 and omgboost like this.
  8. Sep 14, 2021 at 9:14 PM
    #188
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    You guys have me beyond tempted. I’ve sent in my inquiry to Harrop and am subbing to this thread. Thanks for all the information in this thread guys! If I missed it, what have you guys paid to have this installed? I’d DIY, but I wanna make sure it’s done right and has the full warranty on the install and parts.
    Platinum714 likes this.
  9. Sep 15, 2021 at 3:50 AM
    #189
    nobodyintexas
    nobodyintexas What?
    South of Houston
    budget $10k -all in. yes, have a shop do it. Harrop can recommend. get a before and after dyno. have then monitor the A/F ratio. this will set you at ease.
    As I mentioned earlier - get a code reader/OBD thing...one that can reset codes. I had to clear a lean code a couple times. I guess the ECU has "learned" and has yet to throw another lean code. don't freak out...the lean code happens when you come OFF the throttle, so not critical. getting on the throttle...the ECU is overly protective - well, mine is an un-tunable ECU. So I'm running stock tuning. and it is fun.
    I'm a grown-ass man & I still act a fool in it nearly every day.
  10. Sep 15, 2021 at 7:06 AM
    #190
    Saltyhero13
    Saltyhero13 Throbbing Member
    Concur with all of the above. Especially the code reader to read and clear codes.
    For the Harrop I think you'll be hard pressed to find an installer lower than $9K. Harrop has the blower listed for $7.8K. If a shop does it you get a warranty, I think it is one year or x miles (cant remember the exact mileage but its probably between 12K to 16K). If you get on Harrop's or your installer's emailing list they send you discounted specials occasionally but I've not seen anything lower than $1300 off (for a Maggie install), Harrop was $800 off.
    On a 2019 the only tuner available at this time is OVs VF Tuner. Personally I would avoid them like the plague. Ultimately your shop would have to deal with them; my shop vehemently recommended I wait for another vendor to crack the ECUs (originally thought I would purchase a CPOed 2018). Also note the OV vendor was banned from these forums and the Taco forums for their excellent customer service.
    Untuned the blower will put you around 450HP, tuned will get you near 550HP safely without engine upgrades. Memebers here and elsewhere have pushed these trucks much higher with the right tune and upgrades.
    Edit: 600 seems to be were issues start without upgraded internals etc. but 1000HP Tundras exist.
    sbxx312, sd172, snivilous[OP] and 5 others like this.
  11. Sep 18, 2021 at 4:33 AM
    #191
    Puba
    Puba Not New Anymore
    Blue Bell, PA
    MGM 2019 Crewmax LTD OffRoad
    RCI skid plates Curtis front hitch TracRac Ladder racks Truxedo Tonneau Cover BedRug bed liner Console Vault Tech 12volts complete audio system upgrade Bilstein 6112/5100 Coachbuilder Shackles Fuel Vector 18x9 Falkan Wildpeak 295/70/18 DirtyDeeds 8" Standard Husky XAct floor liners Color matched Bumper Shellz fronts Pop and Lock Tailgate SDHQ Hidden Winch Mount Smittybilt X20 Comp 12K RCI Rock Sliders Harrop SC - Stage 1
    I have the Harrop at stage 1. Maybe 10,000 miles so far. On a recent trip, towing about 4500# boat, I pulled off into a rest area (120 miles into the trip) and noticed smoke coming off the engine. Pulled dipstick and I was down a quart or so. Added oil and it bubbled back on me when pouring. Also, when I pull the dipstick out, excessive air escaped (crankcase pressurized) even when the truck is off. Labor Day weekend, no one could help diagnose. Drove home, trip over. Brought into the mechanics who installed the Harrop, they said it might be normal for a SC. Had them do a PM, got home, pulled dipstick again and oil shot out like a geyser. After some research and conversations with Chris at Harrop, I went ahead and changed the PCV valve. That did not work to solve the crankcase pressure issue. Also checked functionality of the bypass on the SC and that is working, confirmed with Chris at Harrop. He is out of ideas and so am I.
    Anyone with the Harrop SC have this experience? I'm ready to remove the SC and change back to OEM but I'm not sure that will solve the problem either.
    Any and all theories on why the crankcase is over pressurized are welcome. I am non flex fuel, 5.7 engine. 19,000 total miles, half with Harrop SC installed.
  12. Sep 18, 2021 at 4:41 AM
    #192
    nobodyintexas
    nobodyintexas What?
    South of Houston
    do a compression test on each cylinder. you may have a damaged ring allowing excess blowby.
    just a guess.
  13. Sep 18, 2021 at 4:50 AM
    #193
    Puba
    Blue Bell, PA
    Thanks. I'll go that route. Nothing else makes sense to me.
  14. Sep 18, 2021 at 5:15 AM
    #194
    nobodyintexas
    nobodyintexas What?
    South of Houston
    the simpleton in me says you have a clogged PCV system... but 19k miles does not lend itself to clogged PCV.
    ..but, it's never simple.
  15. Sep 18, 2021 at 6:58 AM
    #195
    snivilous
    SW UT
    300k+ Supercharged 2008
    There's multiple PCVs, valve cover and crank, did you inspect both? Are you sure your hoses are routed correctly? I would even be willing to disconnect the pcv hoses so you know they're venting to atmosphere, and run the truck and see if they have positive pressure. If they're not blowing any air out and the dip stick is still pressurized then you know there's an issue deeper down. I agree with dude above sounds like excess blowby, but the pcv should still be depressurizing the crank even if you had massive blowby. I don't think it's a supercharger issue, I think the issue is just brought to light from the extra pressures the engine is now experiencing.
  16. Sep 18, 2021 at 8:13 AM
    #196
    boostedtrdpro
    Jeremy
    Well obviously this makes me very nervous being about to pull the trigger on the exact same setup, so please keep us posted with your findings if you wouldn’t mind. I hope you don’t end up having to pull it off the truck! Thanks for sharing…
  17. Sep 18, 2021 at 8:20 AM
    #197
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Can you post pictures of how the PCV and Crankcase lines are routed? The PCV valve is under the SC and should feed back into the port on the bottom of the SC, and there is a Crankcase output on each valve cover that should go to a Tee and then feed back into the intake.
    Saltyhero13 likes this.
  18. Sep 18, 2021 at 8:24 AM
    #198
    Puba
    Blue Bell, PA
    Yeah. I don't want to give it up but my preferred mechanic seems clueless. Performance shops nearby are all backlogged. Seems like I'm kinda screwed at the moment. I need my truck running again asap. I searched the dark web for anyone else with the HarropSC and this issue and nothing came up...as others have pointed out, it does not seem related to the SC. Harrop says "never" seen this problem with their 2650. I understand how the thing works but after that I'm in over my head. I may have a slightly used SC for sale soon with unused stage 2 parts as a bonus. Maybe once my mechanic gets under the SC he may see something else....who the hell knows. The forums here have been good to me. I'll be honest in my final analysis and it isn't fair to blame the SC until I know more.
    boostedtrdpro likes this.
  19. Sep 18, 2021 at 8:26 AM
    #199
    Puba
    Blue Bell, PA
    I can post pictures....I sent the same to Chris at Harrop and he says all is good. The truck ran like a champ for 10k, 1,000 of that with my boat behind me. I don't think it's set up related.
    armyoffoo and boostedtrdpro like this.
  20. Sep 18, 2021 at 12:24 PM
    #200
    Saltyhero13
    I'm sorry to hear you are having troubles, hopefully someone can get your situation sorted soon.
  21. Sep 18, 2021 at 3:20 PM
    #201
    Puba
    Blue Bell, PA
    I appreciate that. The blank stares from mechanics here tell me I better check with my broker and see how my crypto currency and bitcoin accounts are doing on Monday.
  22. Sep 18, 2021 at 3:39 PM
    #202
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Do the compression test like nobodyintx said and that will tell you lots.
    SnowyTundra likes this.
  23. Sep 18, 2021 at 4:04 PM
    #203
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll wager your compression test will be fine. but you need to do it.
    I'll bet half a dollar you got a clogged PCV pipe. or that one way PCV valve is now a zero way valve.
    then, do the @snivilous technique and open the pcv system to atmosphere.
    keep us up to date...my interest is piqued
  24. Sep 18, 2021 at 4:14 PM
    #204
    Puba
    Blue Bell, PA
    Thanks for all the advice gentlemen (and ladies if any replied). I did replace that small green stem pcv valve under the SC down in front. I wish I had a video of how I fished it out of the bottom after I dropped it below sea level trying to get the threads started. My Tekton deep socket was, well, too deep and I had to advance it 1/8 turn at a time with an open end that barely fit with all of the SC piping in front. If it only costs me a half dollar, I'll consider myself a lucky man and send 50 cents to all of you.
    boostedtrdpro and Saltyhero13 like this.
  25. Sep 18, 2021 at 4:33 PM
    #205
    Dr Doobie
    Talkeetna,Alaska
    I went back and reread everything and I'll have to agree, something has to be plugged up, should be no pressure left in the bottom end after shutdown.
  26. Sep 19, 2021 at 10:09 AM
    #206
    Puba
    Blue Bell, PA
    Update: So I drove my truck over to my mechanic to drop off - 10 miles. Pulled dipstick for the helluva it and had slight air exhaust, nothing like it was prior. Decided not to leave it and ran errands, punched it a couple times, got home, pulled dipstick again and no air escape. Oil pressure gauge in normal range the whole time pretty much.
    Conclusion: (I hope) Changing the pcv valve corrected the problem. I just didn't give it a chance to settle in I guess. Just a week of anxiety for the record books. Thanks for all the help gentlemen. If anything else pops up again I'll update.
    TX210Tundra, omgboost, sd172 and 8 others like this.
  27. Sep 19, 2021 at 10:12 AM
    #207
    boostedtrdpro
    Jeremy
    Sounds encouraging! Fingers crossed and hoping it’s fixed!
  28. Sep 19, 2021 at 8:11 PM
    #208
    Not a Hotdog
    Not a Hotdog 17' LC200
    Austin
    2017 Land Cruiser
    What you are saying is, there's not a lot of point in going with the Harrop stage 2 unless you are willing to start upgrading the internals and more.
    Stage 1 + tune and call it a day. (the vehicle is a 2017)
  29. Sep 20, 2021 at 12:31 AM
    #209
    Puba
    Blue Bell, PA
    Stage 1, press tow haul button. Laugh your ass off at the difference. Even with my "anomaly" of a bad pcv valve, the performance at stage 1 makes the Tundra a very different truck. Even if someone finally cracks the eco codes on 2019+, I don't think I'm interested in the extra hassle of "tuning" either but that's just me.
    Saltyhero13 and nobodyintexas like this.
  30. Sep 20, 2021 at 3:25 AM
    #210
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I'll concur...if tuning is not avail, Stage 1 meets the needs. Its hard for me to imagin it getting much meaner without tearing shit up in the drivetrain.
    However.....Dyno said I had 435 to the tires....I'd like 500 to the tires. I reckon Stage 2 would get me there.
    the "i do cars" youtube channel has a teardown of a 3UR...interesting stuff.
