Can front bumper caps be easily modified for sensors?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ne1tHeRe, Sep 14, 2021.
  1. Sep 14, 2021 at 1:25 PM
    Ne1tHeRe
    Ne1tHeRe [OP] New Member
    Virginia
    2021 Cement Tundra CrewMax Limited TRD Off-Road
    I tried searching but couldn't find anything on this. I am trying to acquire cement grey color matched front bumper caps w/ sensor holes.
    I got a ping from a member with standard cement grey front bumper caps for sale but they don’t have the sensor holes. Is modifying them doable and/or even worth it…or should I just look for caps with the holes already there?
    Let me know! Thanks!
  2. Sep 14, 2021 at 1:41 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    My guess is it's just a hole of a particular size. Try removing one of your existing sensors and see what is involved, my guess is its nothing that a hole saw and a dremel couldn't handle.
  3. Sep 14, 2021 at 3:16 PM
    timsp8
    NY
    The hole could be cut, but it isn't perfectly round. When looking for aftermarket bumpers I thought about getting one without sensor holes and cutting them out. Then I talked to a mfg and they said R&D goes in to making sure it’s in the right spot at the right angle or your sensors might not work right. Not sure how true that is.
    Ne1tHeRe[OP] likes this.
  4. Sep 14, 2021 at 3:27 PM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
  5. Sep 14, 2021 at 3:56 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    I did the Ecological bumper caps which turned out nicely. As far as the holes they are more oval shaped and my sensor kept bugging out until I rounded out the hole in the bumper caps which allowed them to sit snug in the original hole. What I would deduce from that is it does matter how much tension is on the sensor from the size of the hole in order to function correctly.
  6. Sep 14, 2021 at 4:14 PM
    Ne1tHeRe
    Virginia
    Ecological, it is! Thanks :)
