Too many miles to get TSB covered?
Discussion in '2nd Gen Tundras (2007-2013)' started by TAXMAN2020, Jun 5, 2020.
  1. Jun 5, 2020 at 8:19 AM
    TAXMAN2020
    TAXMAN2020 [OP] New Member
    My 2011 Tundra dash showed the traction control light on, the check engine light on and the 4 Lo light blinking. Took truck to my mechanic. He says it's got a P2442 code. Truck has 116,242 for mileage. I've found a TSB posted on the forum that says Toyota will repair the air injection system on 2007 to 2010 pickups under extended warranty coverage. Looks like I'm out of luck since my truck is a 2011. I do have an extended warranty but I THINK it expires at 100k. Am I reading the TSB correctly?
  2. Jun 5, 2020 at 9:10 AM
    Jon1979
    Jon1979 New Member
    Jon
    Upstate NY
    2011 Gray Tundra SR5 4.6L V8
    I had the exact same thing happen this winter in my 2011. I called and I was passed the warranty mileage and year. I got the bypass module from Hewitt and it fixed everything just fine.
    snivilous and Filthyphil like this.
  3. Jun 5, 2020 at 9:18 AM
    Jon1979
    Jon1979 New Member
    Jon
    Upstate NY
    FYI I was stubborn at first and decided I was going to just replace the valve on bank 1. Two days after I installed it the valve on bank 2 to started throwing a code. Luckily Rock Auto took the valve back and I ordered the module.
  4. Sep 27, 2020 at 5:29 PM
    BHC
    BHC New Member
    Under TSB wouldn't Toyota be ordered to fix it regardless of mileage or how old the truck is?
    Elduder likes this.
  5. Sep 27, 2020 at 5:30 PM
    Nope
    GODZILLA and Sierramare’ like this.
  6. Sep 13, 2021 at 1:46 PM
    Sierramare’
    Sierramare’ New Member
    Ted
    Alaska
    2007 SR5 DC 4wd
    Thats for “recalls”. TSB’s apply only within warranty period/mileage.
    GODZILLA likes this.
  7. Sep 13, 2021 at 1:51 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I beg to differ.... i got my 07 with 180k miles back then and was serviced under s TSB.. that was in 2015... you can always ask...
  8. Sep 13, 2021 at 2:01 PM
    Sierramare’
    Ted
    Alaska
    2007 SR5 DC 4wd
  9. Sep 13, 2021 at 2:25 PM
    blackdemon_tt
    Yup, I know the difference, but I didnt't pay for the TSB service and my truck was waaay out of warranty.... all my windows froze open because the master switch under a TSB took a dump... stealership replaced the whole switch and did it for free 99... the recall on my ECU, mat and accelerator still have not been performed and are still open...
  10. Sep 13, 2021 at 10:01 PM
    Sierramare’
    Ted
    Alaska
    2007 SR5 DC 4wd
    Actually your issue sounds like it was resolved under a RECALL, 12V491000, not a TSB. https://www.vindecoderz.com/EN/Toyota/TUNDRA/2007/visibility%3Apower%20window%20devices%20and%20controls/recall/12V491000
  11. Sep 13, 2021 at 11:11 PM
    blackdemon_tt
    I guess... it did say TSB on the sheet, since it wasn't on the recall list, i printed it out and took it in... I have posted that sheet a few times on here... i may still have the sheet with the dealership receipt..
  12. Sep 13, 2021 at 11:15 PM
    IgotSR5onit
    IgotSR5onit New Member
    My 14 Camry had a recall on the torque converter and it was covered until 125k. I found out late at 127,xxx and my dealership still replaced it. This is without any warranty. Would be worth inquiring about it with your dealer.
    Elduder likes this.
  13. Sep 13, 2021 at 11:38 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    My sisters 14 Camry got this too but we were told it was covered to 150k
  14. Sep 13, 2021 at 11:52 PM
    IgotSR5onit
    Youre right. 8year/150k. Guess I forgot within the year of it being replaced.
  15. Sep 14, 2021 at 9:40 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    The air injection system has several different failure modes. You can spin your wheels now and try to get the dealership to fix the problem you have, but be aware that it's likely to break again in the future. You could get the bypass kit and be done with it now and forever.
