Headlight recall
Discussion in 'Lighting' started by alwzdfiant, Sep 13, 2021.
  1. Sep 13, 2021 at 2:03 PM
    alwzdfiant
    alwzdfiant [OP] New Member
    2013 Tundra Crew Max
    9A668F11-EEEE-4268-B176-D099818F3C1B.jpg Just saw this and figured I would post it. Haven’t researched the details of it. If it has been posted already please delete:annoyed:
  2. Sep 13, 2021 at 2:10 PM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Toyota has not reported to the NHTSA that there's a remedy available yet, but they do know where the problem lies. So hopefully it'll get fixed soon, I have an affected VIN.
  3. Sep 13, 2021 at 2:13 PM
    NAIVIAN
    NAIVIAN This is the way....
    Doug
    Spring, TX
    2021 Black SR5
    Where do we go to check if we have been affected by vin number?
  4. Sep 13, 2021 at 2:15 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
  5. Sep 13, 2021 at 2:47 PM
    alwzdfiant
    I believe Kelley blue book at kbb.com let’s you look up recalls by VIN as well
  6. Sep 13, 2021 at 2:53 PM
    Toyota Owners site certainly does.
    Kratos likes this.
  7. Sep 13, 2021 at 3:08 PM
    LED headlights are good.:yes:
  8. Sep 15, 2021 at 7:29 AM
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    So... I am in the process of swapping out my 2019 halogens to the Pro LED headlamps using an iHacker plug-n-play harness.
    Does anyone know if this will fix the issue?
    From the information above it seems it is with a particular circuit that allows both the low and high halogen beams to be activated at the same time. Thus, the heat from dual halogen bulbs trigger the fire.
    Do the LED's run so much cooler that this would not be an issue?
    Is it even possible for the LED headlamps to have both on at once? Or is it simply a set of LEDs that varies in intensity (it acts as a combo high + low)?
    ETA - info from link above...
    The subject vehicles are equipped with halogen headlamps that allow the circuits for both the high and low beam bulb filaments to be energized at the same time when the high beams are switched on. Under some conditions, if the high beams are repeatedly left on for an extended period while the vehicle is idling or driving at low speed, there is a possibility that the bulb connector could overheat to a level that can result in an increased risk of a fire that can propagate to other parts of the vehicle.
  9. Sep 15, 2021 at 9:27 AM
    dknapp
    dknapp New Member
    I'm curious about this too. I have a 2015 Tundra that I upgraded with the Ihacker harness and 2018+ trd pro lights.
  10. Sep 15, 2021 at 5:26 PM
    Grey Goose
    Grey Goose New Member
    Scott
    2021 Cement Trail Edition
    color matched front bumper
    I just installed a set of OE LED pro lights in my 21 yes the lows are on when the highs are activated . I will stop into dealer and ask if the problem is fixed .
  11. Sep 15, 2021 at 5:50 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    I have an affected VIN but not worried. I never drive at low speeds or idle with highs on, plus I have LED bulbs with fans so overheating is not really a concern.
  12. Dec 12, 2021 at 3:56 PM
    coler2
    coler2 New Member
    2021 SR5
    Any word on if this was an adequate fix?
  13. Dec 12, 2021 at 4:39 PM
    Burdturger
    Burdturger New Member
    I got the recall notice in the mail but havent received any more info about the fix. I decided to go ahead and upgrade to oem led since the toyota sale goin on. 20% off and free shipping good time to upgrade. If toyota decides to uprgrade us to led, which i doubt will be the fix, ill keep my halogens and get them swapped out. But it will probably be some kind of bulb swap or harness swap or something else cheap. We'll see...
  14. Dec 15, 2021 at 4:36 PM
    Grey Goose
    Scott
    No fix as of yet
  15. Dec 21, 2021 at 6:42 PM
    TundraBrew
    TundraBrew New Member
    Who is having the 20% off sale? Do you have a link?
  16. Dec 22, 2021 at 3:13 AM
    Burdturger
    Toyota parts was having a three day sale but its over.
