2.5 Fox DSC Setting
Discussion in 'Suspension' started by matictundra, Sep 13, 2021.
  1. Sep 13, 2021 at 10:22 AM
    matictundra
    matictundra [OP] New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I will be installing 2.5 Fox DSC all around (P/N's 880-06-947 & 883-26-006) soon. I got the rears already and just waiting for the fronts. Anyone knows where to set the adjustments close to factory setting for my baseline?
  2. Sep 13, 2021 at 11:46 AM
    matictundra
    Franco
    AZ
  3. Sep 13, 2021 at 11:55 AM
    Are you buying them used? They should be set and you can adjust for your needs.
    You can always contact Fox and ask them this question.
  4. Sep 13, 2021 at 12:06 PM
    matictundra
    Franco
    AZ
    They are brand new units.
  5. Sep 13, 2021 at 12:32 PM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    ColoradoTJ and matictundra[OP] like this.
  6. Sep 13, 2021 at 1:37 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    I run mine wide open on both high speed and low speed compression until the truck is loaded up. Once I have gear in it, I’ll stiffen the low speed compression around 3-4 clicks which helps with body roll driving on the highway. The high speed compression is only touched once off road or on horrible back roads.
    keep in mind that low speed compression adjustment indirectly affects the high speed adjustment curve as well.
    Pro tip to save your fingers: get yourself a pin punch set at like harbor freight or something. You can use one of the smaller punches to adjust the high speed compression by inserting it in the hole of the blue dial. It’ll get stiff as hell if you want to crank it all the way closed. You can also use a larger punch set to adjust the front coil over height (with a cheater bar) instead of using a Fox adjustment tool. It was super easy cranking them up or down with a punch instead. I just keep them in the center console.
    JPB_VT and matictundra[OP] like this.
