Nilight LED Bar Reliability?
Discussion in 'Lighting' started by kanger328, Sep 12, 2021.
  1. Sep 12, 2021 at 11:10 PM
    kanger328
    kanger328 [OP] New Member
    Anchorage, Alaska
    2012 DC 4x4
    For those you who have the Nighlight LED light bars, can you comment on how reliable they are? I see some people on here have tried this brand for the hood scoop or the fake grille vent insert.
    I'm thinking about a 30-sum inch bar to mount just behind the grille on my '12. Just wondering how reliable they are given they're so cheap.
    Here's what I'm looking at: https://www.amazon.com/dp/B01DNYCJQW/?coliid=I1N29SKKN4PM4N&colid=2VEOR69AYYH3&ref_=lv_ov_lig_dp_it
    If anyone has tips on install let me know. I eventually want to add some pods facing the rear. Hard to see when backing up with dark @$$ Alaskan winters.
  2. Sep 12, 2021 at 11:23 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    I haven't tried the nilights, but I've got several auxbeams. Good lights for the money. Also just got a 30 inch Swatow, seems very well made for the cost. All chinesium electronics come with a certain amount of risk, but its fairly low and if you know how to use a soldering iron you can generally fix them yourself. Think the biggest complaint I've seen on most China lights is water ingress, also easily fixed. If your rich, get the good bajas or DDs. Me, I'm about biggest bang for the buck, and a led light bar that is 75% as good for 10% of the cost is more my style, but I've also got background in electronics, so the risk is minimized. YMMV.
    ErikTRDTUNDRA and kanger328[OP] like this.
  3. Sep 12, 2021 at 11:27 PM
    kanger328
    Anchorage, Alaska
    2012 DC 4x4
    Thx, I'm going to check out the Auxbeams. Definitely not into the idea of spending $1K for the name brands.
    If anyone still has any info the Nilight, let me know!
  4. Sep 15, 2021 at 7:32 PM
    Rough Country would be a step up without being too expensive.
  5. Sep 15, 2021 at 8:26 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I’ve got the following Nilights and love how affordable and reliable they are:
    2 x 4”
    2 x 26”
    1 x 31”
    1 x 42”
    I also have Cali Raised and BD pods only because they have better amber lights than the Nilights
    The Nilights have handled the high speed, low speed rocky vibrations. I’ve had them on for hours at a time while at camp and on night runs. If/when they do fail it won’t cost me an arm and a leg to replace. My oldest lights are 2 years old and still going strong.
  6. Oct 13, 2021 at 12:17 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Anyone know if auxbeam makes a light bar that will fit in the hood bulge?
  7. Oct 17, 2021 at 5:06 PM
    Vang530
    Vang530 New Member
    I have a 30" Nilight in my bumper (near my winch) and as my reverse lights as well. No problems after a year so far. I've had another set as my reverse lights on my 2010 Raptor and after 2 years, one of them got moisture and they warrantied them with no issues. Definitely recommend for the price.
    FYI - Auxbeam is one of the inhouse brands for one of the chinese factories that rebox many light bars for resellers (like CaliRaised). Good brand as well. I have my lights wired up to their switch panel.
    mav7021234, DIYDad, toyofan87 and 2 others like this.
  8. Dec 9, 2021 at 6:50 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Looks good! Are those LP9s or a knockoff? How do you like them?
  9. Dec 9, 2021 at 7:01 AM
    Vang530
    Vang530 New Member
    They are LP9 knockoffs from snsdesigns.biz with a custom DRL - I don't think he is selling them anymore due to a cease and desist from Baja designs. I have all 4 hooked up to my auxbeam switch panel (switch pro knockoff) and I'm sure they aren't as bright as real LP9's, but man they are very bright.. almost unusable for me and my already bad eyesight lol.
  10. Dec 9, 2021 at 8:03 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I had Nilights on my Tacoma for several years. Started with 4 individual small lights behind the grill then changed out to a single light bar and took the 4 small lights and put them on a buddies tractor. they are still working and look fine.
    That being said, I went the rough country route for the tundra for the light inside the front bumper. the rough country light is substantially brighter.
    bulldog93 and Vang530 like this.
  11. Aug 22, 2022 at 8:12 AM
    king.cong.1119
    king.cong.1119 New Member
    I have no experience of the Nilight but the Auxbeam 5dpro light bar has been good to me.
    I also recently got the auxbeam's 9 inch driving pods and they are also very solid so far.
    bulldog93 likes this.
  12. Sep 12, 2022 at 12:35 AM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    what bumper is that??
  13. Sep 12, 2022 at 6:32 AM
    king.cong.1119
    IRONMAN 4x4 raid series.
    mav7021234 likes this.
  14. Sep 26, 2022 at 7:23 PM
    guinness77
    guinness77 New Member
    2024 Tundra SR5 CrewMax cab 5.5' bed.
    Are all of those on 1 truck? If so, what's the wattage total? And... any problems with the wattage load?
  15. Oct 14, 2022 at 6:22 AM
    tundramike23
    tundramike23 New Member
    Michael
    Tyler, Texas
    2015 Toyota Tundra Platinum
    BODY ARMOR: / Ironman 4x4 Raid F. Bumper w MONSTER WINCH/ RCI steel engine plate + midbody plate / CBI Toyota Tundra Overland Rock Sliders SUSPENSION/WHEELS: / Bilstein 5160 Series / POWERSTOP Brake Kit / 18 x 9.5 5-139.70/150.00 12 BKMTXX --- BLACK RHINO ARMORY WHEELS / LT295 /70 R18 129Q E1 BSW Nitto Ridge Grapplers ENGINE: / Volant Snorkel Intake / JS 3000w High Output Alternator + Big3 Kit + dual batt/ Pedal Commander BED: Syneticusa MR Retractable Hard Truck Bed Tonneau Cover (5'6" Bed Without/OE Track System) / POP & Lock - Toyota Tundra Heavy Duty Power Tailgate Lock / BELTTT 3000W Pure Sine Wave Inverter 12V DC to 120V AC LIGHTS: /Ironman 4x4 32" Saber Lightbar w (x4) 40w Light Cubes / SpeedTech Lights Raptor-X TIR Upper Windshield Interior Split LED Strobe / XRIDONSEN 35 inch Traffic Advisor Light Bar Rear Window w/Display Controller TINT: / 5% ceramic tint w/ {redacted} windshield {redacted} COMMS: / BTECH GMRS-50V2 50W Radio + Midland – MXTA26 MicroMobile® 6DB Gain Whip Antenna – Quadruple Signal Output – 32” Antenna /weBoost Drive Reach - Vehicle Cell Phone Signal Booster (model 470154) + weBoost Drive OTR antenna / Valentine One V2 Radar
    Just my personal experience...
    I got the curved 32" Nilight and ran it for about a year before two of the leds went out.
    It was still very bright and it's hard to beat the value at that low price
    kanger328[QUOTED][OP] likes this.
  16. Oct 14, 2022 at 6:56 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    I've had an Auxbeam light bar installed down on my front bumper for about 7 years now. I've never had any problems with it working and it throws a ton of light downrange.
    My only complaint about it is how much electrical noise it produces through the wiring. If I turn it on with the stereo on it produces a loud, steady, high-pitch squeal through the speakers.
    There are no quality seals from UL (Underwriters Laboratory) stamped in any of these bargain brand light bars. They couldn't pass the UL electrical quality inspection with all of the electromagnetic noise they produce through missing/inadequate electrical noise shielding in their circuits.
  17. Oct 14, 2022 at 7:04 AM
    careyrob
    Carey
    Massachusetts
    I added several "ferrite beads" to the power wire on mine to try and block the electrical noise it was producing, but it only made a very minor difference.
    Higher quality light bars have better circuit shielding and better circuit components that produce less electrical noise as a baseline.
  18. Oct 14, 2022 at 7:09 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Yes, on one truck. Total of 1600 watts but they’re not all on at the same time. I wouldn’t need the rear lights on if I’m driving on a trail with the front bars on. Haven’t had any issues with electrical interference either.
    edit:
    When the engine is running your voltage is around 13.5-14 volts. 1600/14 = 114 amps. The alternator can’t provide enough juice to fully power everything so you’ll notice, for example, headlights dimming. But I installed a 300amp alternator so I no longer have those problems.
    careyrob likes this.
  19. Oct 14, 2022 at 7:21 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    I have had a 20" Combo Nilight for a while before I replaced it with a Heise. It worked fine but that model did not have much distance to the driving beam. The Heise brand was a good compromise until covid and the prices shot up. Still cheaper than Baja by a lot. The side and rear lights are Baja's work scene.
    mav7021234 and careyrob like this.
