Another won’t stay running post
Discussion in '1st Gen Tundras (2000-2006)' started by jake22si, Sep 11, 2021.
  1. Sep 11, 2021 at 1:38 PM
    jake22si
    jake22si [OP] New Member
    kevin
    2000 tundra 4.7
    2000 tundra 4.7 just quit on me at a stop light. Starts up for a few seconds and stalls out every time. Sometimes I can keep it running at a high rpm by feathering the throttle but it eventually stalls out. No cel was on or is currently on. I pulled the resistor wire and jumped them together doesn’t seem to be that. Is there a throttle position sensor or should I try cleaning the throttle body or something?
  2. Sep 11, 2021 at 1:40 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    SeanL likes this.
  3. Sep 11, 2021 at 2:12 PM
    jake22si
    kevin
    2000 tundra 4.7
    No it seems to be getting plenty of fuel, has a new tank and filter before this issue. Maybe fuel pump but it shoots fuel fairly well
  4. Sep 11, 2021 at 2:28 PM
    Toyoda Tundra
    Toyoda Tundra Boxing and Tundras
    2WD 2004 AC Tundra. V8 strong
    Always start with the easiest, clean throttle body and MAF sensor. Use appropriate cleaners.
    BubbaW likes this.
  5. Sep 11, 2021 at 2:35 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Drive by wire or cable?
  6. Sep 11, 2021 at 2:49 PM
    jake22si
    kevin
    2000 tundra 4.7
    Cable
  7. Sep 11, 2021 at 3:08 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    May have a bad idle air control valve.
  8. Sep 11, 2021 at 3:12 PM
    jake22si
    kevin
    2000 tundra 4.7
    This think is making a whine noise after it stalls out with the key in the on position, stops when I unplug this plug
  9. Sep 12, 2021 at 12:38 PM
    jake22si
    kevin
    2000 tundra 4.7
    Installed new fuel pump, I knew it needed one the truck sat previously for 4 years and I unfroze the one in it because I didn’t know if the truck was going to be any good.
    Starts and idles good, but acts like there is a rev limiter around 2500-3000 rpm or so.
    reading 3 p0100 codes maf a?
  10. Sep 12, 2021 at 1:11 PM
    artsr2002
    'Yonder
    Give the maf a good clean and clean the contacts on the connector as well.
    BubbaW likes this.
  11. Sep 12, 2021 at 1:25 PM
    artsr2002
    'Yonder
    Jake that item your pointing to on post 8 is the throttle body motor or actuator. Perhaps it is starting to go on ya. It's part of the throttle body assembly. The motor inside can be replaced. RockAuto has 2 different models but they are not cheap. I have found a video for a cleaning process that might get you by. Good luck.
    https://youtu.be/IDjzWydgfyc
    bmf4069, shifty` and BubbaW like this.
  12. Sep 12, 2021 at 2:11 PM
    jake22si
    kevin
    2000 tundra 4.7
    thanks, it doesn't make the noise anymore with the new fuel pump.
  13. Sep 12, 2021 at 3:05 PM
    jake22si
    kevin
    2000 tundra 4.7
    is there a limp or fail safe mode on these trucks?
  14. Sep 13, 2021 at 4:02 AM
    jake22si
    kevin
    2000 tundra 4.7
    Update
    I have a maf sensor on order. I can drive the truck even at highway speeds, but it starts bucking or limiting the revs around 2800-3000 rpm. P0100 and 0101 keep popping up. Cleaned the sensor and hoping the new one solves the issue. There was a small piece of filter stuck in the sensor to begin with. Mice..
  15. Sep 13, 2021 at 4:10 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    You may be on to something and in answer to your earlier question....yes there is such a thing as Limp mode on our trucks, which could be what you are experiencing in respect to your "limiting the revs around 2800-3000 rpm" comment !
    P0100 is defined as a Mass Air Flow Circuit Malfunction.
    P0101 means that the signal from the mass air flow sensor (MAF) is out of expected range
    bmf4069 likes this.
  16. Sep 13, 2021 at 4:40 AM
    With those codes I'd pull the maf out and clean it, the check the connectors for corrosion. Get yourself a can of maf cleaner from wallyworld. I think they sell a maf/tb cleaner combo kit.
    BubbaW likes this.
  17. Sep 13, 2021 at 11:15 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Don't cheap out on the MAF or you'll be right back in the same boat.
  18. Sep 23, 2021 at 2:24 AM
    jake22si
    kevin
    2000 tundra 4.7
    After a long wait, the sensor arrived and solved the issues I was having.
    des2mtn, shifty` and BubbaW like this.
