Interior Scratches
Discussion in 'Detailing' started by TINY57L, Mar 3, 2019.
  1. Mar 3, 2019 at 12:45 PM
    TINY57L
    TINY57L [OP] Instagram: @TINY57L
    Raj
    Northern California - Bay Area
    2014 Platinum Tundra
    KMC XD SERIES WHEELS W/33" NITTO TRAIL GRAPPLERS DIRTY DEEDS/BAMUFFLERS 6" BUDGET EXHAUST SYSTEM AMP RESEARCH POWERSTEPS ROUGH COUNTRY FENDER FLARES 3" PROCOMP LEVELING KIT 18+ HEADLIGHT CONVERSION CA AUTO TAIL LIGHTS TRD PRO GRILLE BAKFLIP G2 TONNEAU COVER
    Does anyone else get surface scratches like this on their interior easily? If so, is there anyway to get rid of them?
  2. Mar 3, 2019 at 1:14 PM
    Blueknights75
    Ron
    Clayton, NC
  3. Mar 3, 2019 at 1:15 PM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
  4. Mar 3, 2019 at 1:28 PM
    15whtrd
    15whtrd Mr. Blonde
    Yup it scratches easily. It helps if you keep it lubed up with some type of protectant. I use 303 aerospace protectant.
    NewImprovedRon and TINY57L[OP] like this.
  5. Mar 3, 2019 at 2:05 PM
    TINY57L
    Raj
    Appreciate the tip @15whtrd. Thanks for not being the :popcorn: guys above, lol..
    15whtrd likes this.
  6. Mar 3, 2019 at 2:40 PM
    15whtrd
    15whtrd Mr. Blonde
    That’s their way of tagging the post because they have nothing to add but interested in the answer.
  7. Mar 3, 2019 at 2:48 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    Exhaust Dirty Deeds 8”SS, some led lights, Osram headlights, Pro Stop brakes, Pop Lock, AFE dry air filter with charcoal delete.
    I tried dark gray shoe polish. It’s a semi permanent fix. If it doesn’t match perfectly you can always remove it by using a mild spray cleaner like simple green.
    NewImprovedRon likes this.
  8. Mar 3, 2019 at 2:54 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    This, A protectant will lubricate/protect it and possibly diminish some of the ugliness.
    Wet sanding with very fine grit sandpaper may help get rid of them but also smooth out the given texture.
    Good Luck!
  9. Mar 3, 2019 at 3:00 PM
    15whtrd
    15whtrd Mr. Blonde
    Careful with the wet sanding. When I first bought my truck I got a few scuffs on the rear panel. I rubbed on it too hard and it started taking the color off of the panel on all the high spots. To where it started to look green or white. The dealer replaced it for me as a favor.
    duece292 and Trooper2[QUOTED] like this.
  10. Mar 3, 2019 at 3:02 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Sometimes they can be burnished with something like a #3 Philip's screwdriver. I've also used the edge of a spoon and being VERY careful, a warm/hot spoon. If you go the hot route find a piece of plastic to test first. You want just enough heat to help smooth the raised edge of the scratch.
    Trooper2 likes this.
  11. Mar 3, 2019 at 3:15 PM
    Trooper2
    JR
    Kind of reminds me of the heat gun trick for faded black exterior trim, hmmmm.
    duece292[QUOTED] likes this.
  12. Mar 3, 2019 at 3:16 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    The door panels are molded in color meaning they are black all the way through. The color will not sand off, but you will sand off the grain and increase the gloss in that area.
    Since they are PP material they are soft, flexible and can scratch easily. The white/green marks are stress marks from over bending the material.
    There are painted and film decorative garnishes on doors, but generally molded in color is used as is is more durable. Painting over plastic adds cost, process time, and potential for more defects (molding +paint)
    I have managed OEM interior door liner suppliers for several years.
    Here's a thread posted a few days ago with the same concern.
    https://www.tundras.com/threads/scratches-on-inside-interior.41043/#post-1044872
    duece292, Trooper2 and TINY57L[OP] like this.
  13. Mar 3, 2019 at 3:16 PM
    TINY57L
    Raj
    Sorry, I came off wrong there with mistyping. Meant to say “thanks for to the guys above”
    oops!
  14. Mar 3, 2019 at 3:20 PM
    TINY57L
    Raj
    @stuckinohio thanks for posting that thread, finding some great information there.
  15. Mar 3, 2019 at 3:53 PM
    Mr Swervlin
    Mr Swervlin "Yes....In Dee Face"
    O H I O
    2017 Silver Sky limited TRD Crewmax
    Line X bed liner Window tint AVS in channel vent visors Paint protection wrap Husky front & rear floor liner ESP Crewmax rear storage Console organizer and tray TRD shift knob TRD rear sway bar Thule exporter pro 500 Color matched door handles, side mirrors, and grill surround VLEDs interior/reverse/cargo Driver side grab handle 10" BAmuffler Trd pro headlights
    Yes...it kinda takes away from the beauty of owning an upgraded interior. Nice ass leather...junk ass plastic. I have a door that looks about the same. Not thinking about it, I reach down to grab my gloves from the door pocket and scratch the plastics with my wedding ring. EVERY TIME....no joke
    TINY57L[OP] likes this.
  16. Mar 4, 2019 at 8:24 AM
    War Machine
    War Machine SSEM # 5 3MW
    Matches the scratches our wives’ rings put in the paint under the passenger door handle.
  17. Jun 21, 2021 at 5:20 PM
    toyotasux
    toyotasux New Member
    Because Toyota interior is JUNK. I've had three Toyotas, a 2010 Prius, a 2018 Corolla and a 06 4Runner. Toyotas plastic sucks so hard. You even look at it wrong and it gets scratched!
    I am a truck driver and we had Kenworth semi trucks that used textured plastic panels and I could try to dig my fingernail into the plastic panels and never get a scratch. Trucks with 200k miles through slip seat drivers that treat the vehicles like trash still barely had any damage to the plastic panels.
    My 2018 Corolla at only 25K miles when I got rid of it (thank god) had the interior plastic panels that looked like hell and it was a lease I treated it very gently. There was also a lot of other little quirks and burned out lights the car went through in such a new car and low time. Thats when I knew it was my last Toyota, they are really going downhill.
    My Prius "premium" leather seats literally disintegrated in around 80k miles, touch screen died at 60k, when it gets less than 20 degrees outside, my entire dash won't even come on till it warms up(known issue), main hybrid battery died at 80k miles, engine was eating oil at 90k on the odo had to increase the weight of the oil so it doesn't (known issue, they issues a recall for the Camry but not the Prius even thought they use the same engine and have the same piston design flaw causing very excessive oil consumption!).
    My 4Runner's engine completely grenaded the engine at 65k miles which was covered under the extended warranty I got. What can I say, I'm done with Toyota, they just have burned me soo many times.
    THOR's likes this.
  18. Jun 21, 2021 at 5:45 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    I armor all
  19. Jun 21, 2021 at 6:42 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I always use Trim Shine it’s not like Armor All it doesn’t attract dust and it doesn’t gum up. It’s also not a high gloss either.
  20. Jun 21, 2021 at 9:42 PM
    Trooper2
    JR
    Thanks for playing :thumbsup:
  21. Sep 12, 2021 at 5:22 AM
    toyotasux
    Figured Toyota fan boys would come back with some one liner to which their fan boy n@t swingers come along thumbing them up. Still doesnt change the fact Toyota Sucks.
  22. Sep 12, 2021 at 5:31 AM
    18" TRD Off Road Wheels
    Hint: This is a Toyota Tundra Enthusiast Forum. We are all fans of, or at least interested in, the Tundra here. So expecting the brush off with your username and first post doesn't exactly make you Nostradamus.
    In other words:
  23. Sep 12, 2021 at 5:41 AM
    justcuz
    justcuz 2.5 Gen Member
  24. Sep 12, 2021 at 5:53 AM
    Still doesn't change the fact that you find this Toyota forum attractive......
    NewImprovedRon and GODZILLA like this.
  25. Sep 12, 2021 at 6:09 AM
    Kung
    KG, VA
    I mean, YOU came HERE. We didn't ask you to come here. And statistically, no they don't, so....as the gentleman above said, thanks for playing. :thumbsup:
  26. Sep 12, 2021 at 6:17 AM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    Was going to suggest "neutral" color shoe polish. Saw earlier post regarding gray color shoe polish as well. I have used the neutral on several places in interior finish with varying levels of success. (Love it on the soft door panel areas near interior grab handle. ) Definitely test a small area first. Buff it with soft bristle brush and finish with soft cloth. I sometimes follow up with a light wipe of protectant like Meguira's interior or similar. Only warning is that it does tend to "shine" most areas to some degree like the name suggests it should. Matte finish areas haven't always turned out as well as I hoped they would, but it is removable with some cleanser and elbow grease.
    Black Wolf likes this.
