SCS Ray10 wheels 18x9
Discussion in 'Marketplace - Wheels & Tires' started by SCSPerformance, May 25, 2018.
  1. Aug 7, 2021 at 3:16 PM
    #601
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
  2. Aug 17, 2021 at 8:17 PM
    #602
    StTundra
    StTundra New Member
    New Jersey
    20 Trd sport CM white
    Trigger pulled….. will post when mounted. Thanks for everyone’s pics
  3. Aug 18, 2021 at 12:57 PM
    #603
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    Same!
  4. Aug 22, 2021 at 7:37 AM
    #604
    mord4
    mord4 New Member
    2014 MGM Toyota Tundra SR5
    Thanks! I was able to get a set this last go around 8/17 and they should be here Tuesday!
  5. Aug 30, 2021 at 12:45 PM
    #605
    yekimikey
    yekimikey New Member
    Dang, out of stock
  6. Sep 4, 2021 at 6:05 AM
    #606
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    jr1016[QUOTED] likes this.
  7. Sep 4, 2021 at 7:55 AM
    #607
    Beer Man
    What size fits?
  8. Sep 4, 2021 at 9:05 AM
    #608
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    The M6*8 mm, you don't need the nut. You need about 80, I got the 100 pcs.
  9. Sep 5, 2021 at 11:36 PM
    #609
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Be super careful with those plastic screws, they are extremely weak and fragile. I tried to swap mine out with these and I broke the heads off of several of them and had to extract the remaining stud, which being plastic was harder than it needed to be. I was only using hand tools, not power tools and even after the first one broke I was being super careful and still managed to break a few more. I said screw it and removed the rest of them and put my stock bolts back in. Even removing the 20 or so I had already installed I broke the heads off of a few more. The upgrade in looks wasn't worth the headache of removing those damn plastic pieces. After all that I'm keeping them as is.
    JuanTon21, GELCW, kuokoa and 2 others like this.
  10. Sep 6, 2021 at 8:13 AM
    #610
    Beer Man
    Thanks for the heads up. I haven’t ordered them yet because I don’t have the wheels on at the moment. I might just dip the heads black while they’re off the truck.
  11. Sep 11, 2021 at 6:01 PM
    #611
    StTundra
    StTundra New Member
    New Jersey
    Thanks everyone for sharing info. 275/70/18 wildpeaks. Front flap removed. Rear flap rubs on full lock reverse. Will trim.
    upload_2021-9-11_20-59-47.jpgupload_2021-9-11_21-0-28.jpgupload_2021-9-11_21-0-59.jpgupload_2021-9-11_21-1-27.jpg
  12. Sep 11, 2021 at 6:05 PM
    #612
    Looking good!
  13. Sep 11, 2021 at 6:08 PM
    #613
    Lost in the East
    Lost in the East New Member
    Derek
    Voodoo Blue TRD Pro (Should’ve kept it) Mudbath TRD Pro
    iHacker[QUOTED] likes this.
  14. Sep 14, 2021 at 5:06 PM
    #614
    BruteForceBeWithYou
    BruteForceBeWithYou New Member
    Stephen
    2019 Cement Grey DC
    I have continually ended up empty handed trying to get these wheels but FINALLY found a great deal on a set of used ones. I read someone else say that most wheels just look like "wheels" and don't compliment the truck and I agree with that 100%. You've got one thing going on with the truck and the wheels kind of doing their own thing, so the highest compliment I can give the Ray10 is that its the only wheel I've had that looks like it belongs on the Tundra. (This will be the 4th set of wheels for me in the last 6 months) Then you add hub-centric on top and the lighter weight and its a no-brainer. I'll also say its very hard to photograph these properly, you really to do need to see them in person. I suppose all this makes sense when you consider they were designed specifically for the Tundra but regardless, I'm very glad to have them. Another happy customer!
    pvmike, GELCW, COTundra23 and 5 others like this.
  15. Sep 14, 2021 at 5:10 PM
    #615
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    The Ray 10’s are awesome. Almost pulled the trigger on a set. But waiting for the F5’s to come out. Had them on my 4runner Pro. There going to look bad on the tundra.
  16. Sep 15, 2021 at 1:28 AM
    #616
    kuokoa
    kuokoa New Member
    Kailua Kona, HI
    2015 Tundra Crewmax BRM
    anyone running 295/70 Yokohama Geolandar G003's on their Ray10's? thinking about upgrading from 275/70 Ridge Grapplers. I'm on 6112's @ 2.5 so I'm guessing I'll need to trim/cut/heat/smash some stuff to make it work.
  17. Sep 21, 2021 at 11:17 AM
    #617
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
  18. Sep 21, 2021 at 11:38 AM
    #618
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
  19. Sep 21, 2021 at 1:40 PM
    #619
    Lost in the East
    Derek
    Finally had mine mounted today.
    Rob's Inferno, pvmike, kuokoa and 3 others like this.
  20. Sep 21, 2021 at 2:04 PM
    #620
    RusPro21
    Don
    Pa.
    Are you running 285’s? Also any rubbing issues? Thanks.
  21. Sep 21, 2021 at 2:16 PM
    #621
    Lost in the East
    Derek
    295/70s. I removed the mud flaps, but still rubbing in reverse. Should be fine after tucking the liner in.
    RusPro21[QUOTED] likes this.
  22. Sep 21, 2021 at 4:21 PM
    #622
    Beer Man
    How did you black out the bolts? With the nylon bolts mentioned in this thread? Or something different?
  23. Sep 21, 2021 at 4:26 PM
    #623
    Lost in the East
    Derek
    I rattle canned it. I can post a close up tomorrow to compare.
  24. Sep 21, 2021 at 4:57 PM
    #624
    amjonesy27
    amjonesy27 New Member
    Atlanta, GA
    2020 CM Platinum
    Retrax Bed Cover
    Finally installed my SCS Ray 10s. 275/70/18 Cooper Discoverer AT3 XLT. SLIGHT rubbing on the front mud flaps that will require a small amount of trimming/molding.
    MightyTundraGA likes this.
  25. Sep 21, 2021 at 5:02 PM
    #625
    Beer Man
    Nice, so you took all 80 out? Lol
  26. Sep 21, 2021 at 5:02 PM
    #626
    Beer Man
    While we’re at it, how did you black out your bolts? Ha
  27. Sep 21, 2021 at 5:23 PM
    #627
    amjonesy27
    Atlanta, GA
    2020 CM Platinum
    Retrax Bed Cover
    Haha, I didn't count them when I was doing it, but yes. I took all 80 out and rattlecanned it. OCD kicking in. Black bolts came directly from SCS. Have some black wheel locks on order from Gorilla auto products
  28. Sep 21, 2021 at 5:27 PM
    #628
    Beer Man
    SCS sells the black bolts? I haven’t come across that yet.
    GODZILLA likes this.
  29. Sep 21, 2021 at 5:35 PM
    #629
    Lost in the East
    Derek
    Every single one. Sprayed it with Krylon Satin and put blue loctite on before putting them all back. I also order my black lugs from SCS.
    Beer Man[QUOTED] likes this.
  30. Sep 21, 2021 at 5:38 PM
    #630
    Beer Man
    I’m getting my wheels mounted on Friday. They’ve been sitting in my garage for over a month since I scored on the last drop. I somehow haven’t even opened a box yet! But I know as soon as I see those chrome bolt heads I’m gonna freak. I need to take them all out in the next couple days & just do it since they’ll be off the truck
