Tire recommendation for TRD Pro wheels with 3" Toytec lift and JBA UCAs
Discussion in 'Wheels & Tires' started by IgotSR5onit, Sep 10, 2021.
  1. Sep 10, 2021 at 9:20 PM
    IgotSR5onit
    IgotSR5onit [OP] New Member
    Looking for recommendations on AT tire/tire size for TRD pro wheels with 3in Toytec suspension lift and JBA UCAs? Preferably without removing or modifying anything in the wheel well.
    Rica25 likes this.
  2. Sep 10, 2021 at 9:23 PM
    Kanobi13
    Kanobi13 New Member
    Michelin ltx at 275 65
    Saltyhero13 likes this.
  3. Sep 10, 2021 at 9:29 PM
    IgotSR5onit
    Isnt that stock tire size? I was hoping to get 275/70R18 atleast.
  4. Sep 10, 2021 at 10:23 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    285 70 and all you should have to remove is the little flap at the front.
    IgotSR5onit[OP] likes this.
  5. Sep 10, 2021 at 11:50 PM
    Mark73
    Mark73 New Member
    MGM 2020 Tundra TRD PRO
    ReadyLift SST 2” plus 2 Lift Kit, Coach builder +3 shackles & drop kit, Nitto RG 295/70/18
    Nitto Ridge Grapplers AT 295/70/18
  6. Sep 11, 2021 at 4:25 AM
    Tundrafan23
    Tundrafan23 New Member
    X2 295/70/18 was made for a 3inch lifted Tundra, no rubbing and fills up the wheel well perfectly
  7. Sep 11, 2021 at 6:00 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    295/70-18 or 285/75/18 would be perfect.
  8. Sep 11, 2021 at 6:20 AM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Heres my Pro with 295/70r18. I have CB shims up front for total of about 3” lift. Also have CB +2 shackles in the rear. This should give you an idea of what 295’s will look like. Only thing I had to do was remove the little flap in front of the tires on front bumper.
  9. Sep 11, 2021 at 9:52 AM
    IgotSR5onit
    my biggest concern was Ive seen some complaints about stock wheel offset and rubbing of the UCA arms. 297/70 good to go as far as width goes on aftermarket UCAs?
  10. Sep 11, 2021 at 9:59 AM
    FISHN43
    FISHN43 New Member
    Ohio
    I’m on stock UCA’s and I have about a half inch of clearance.
  11. Sep 11, 2021 at 10:10 AM
    IgotSR5onit
    I appreciate the information. You like those Falkens? they seem to be very reasonably priced when I looked at them last night.
  12. Sep 11, 2021 at 10:24 AM
    FISHN43
    FISHN43 New Member
    Ohio
    Love the Falkens. I had them in 275/70r18 and went through a winter with those. They are great in the snow and wet roads. Nice road manners and very quiet for an A/T. Stayed with the Falkens when I decided to go 295/70. Noticed slight power loss on acceleration for a couple days but now I’m used to it. Thats the only downside is that they are a heavy tire. Gotta pay to play! :thumbsup:
  13. Sep 11, 2021 at 1:29 PM
    Tundrafan23
    I run SPC uca and I have plenty of room
  14. Sep 11, 2021 at 9:48 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Mine fit after I trimmed up the skid plate, had just enough clearance at the upper control arm.
  15. Sep 11, 2021 at 9:53 PM
    IgotSR5onit
    Stock skid plate? I picked up an RCI duing the labor day sale. Not sure how it fits vs the stock though.
  16. Sep 11, 2021 at 9:55 PM
    Rodtheviking
    Vancouver, WA
    Sequoia
    Stock, RCI should be fine.
