285/65/20 On Stock Rims With No Lift?
Discussion in 'Wheels & Tires' started by plumber802, May 22, 2018.
  1. May 6, 2019 at 7:00 PM
    #91
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Looks good. Here is mine. As soon as my tires wear out, I'm going with 17's.
    KELZ84[QUOTED] likes this.
  2. May 7, 2019 at 5:06 AM
    #92
    LiftMeUp
    LiftMeUp New Member
    Yes, the tire shop said I would probably need spacers but seems like with them you may clear UCAs better but adds rubbing to the situation. I thought about buying a set just in case but think I'm going to hold off. Hopefully won't need them.
  3. May 7, 2019 at 3:14 PM
    #93
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    Yeah i heard With spacers you will rub closer to fender, but can easily modify it with heat gun & removing front flaps.
  4. May 9, 2019 at 8:57 AM
    #94
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    Old ride 13 RW BA budget, 3/2 lift JL W7
    so, to sum it up you can fit 285/65/20s on stock rims with no rubbing on metal or front sway bar?
    LiftMeUp likes this.
  5. May 10, 2019 at 6:06 AM
    #95
    LiftMeUp
    LiftMeUp New Member
    I've seen people say no, the tire shop was really only worried about rubbing on UCAs. One person said I should go with 275/65/20 to save on width. But you're talking less than .4 inches. From 10.83 to 11.22. And then, you figure only half is going on each side, so I'm not sure .2 will make a difference. I mean, I guess it can, but I'd rather gain that extra .6 inches in the height with the 285.
    Then again, I've seen a bunch on this forum post that they are running 285/65/20 on stock rims, without spacers and had no problems. Some only had to remove from splat.
  6. May 10, 2019 at 7:29 AM
    #96
    Wiscdave
    Wiscdave New Member
    Northern Wisconsin
    19 Tundra Sport
    NO lift as well..I think I will stick to 275/65/20s unless someone posts some pics of no lift and 285/65/20s
    LiftMeUp[QUOTED] likes this.
  7. May 10, 2019 at 9:34 AM
    #97
    LiftMeUp
    LiftMeUp New Member
    Well no, I'm lifting the front 3" so that may come into play with the angle of the UCAs. Guess best thing is install the lift, look and take measurements and then order tires.
  8. Aug 30, 2019 at 2:52 PM
    #98
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Question for guys running 20 inch wheels
    I’m looking at new wheels. +25 offset, Bilstein 6112 set at 1.9. I’m currently running +25 18 inch wheels with no rub.
    What tires can I run with this setup?
    Will 275/65/20 fit without issue?
  9. Aug 30, 2019 at 3:08 PM
    #99
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    I’m running 25offset with 275/65/20’s on stock suspension-waiting for my icons to ship!
    Skid plate trimmed, mud flaps removed, plastics trimmed
    NoRcptn likes this.
  10. Aug 30, 2019 at 3:30 PM
    #100
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    So, you’re rubbing?
  11. Aug 31, 2019 at 6:40 AM
    #101
    DexterL
    DexterL New Member
    No rubbing currently with minor trimming
  12. Dec 10, 2019 at 7:58 PM
    #102
    Jawill0217
    Jawill0217 New Member
    Josh
    2018 tundra limited 4x4
    3" front 1" rear
    So I used to ha e 2015 limited crewmax 4x4 with a 3" front and 1" rear leveling kit/lift and stock rims. I was running the ko2 bfg 285/65r20 with no issues. I did have to remove the spats and trim the skid plate but other than that it was great. I now have atrims. Limited crewmax 4x4 with 3/1 leveling kit and stock rims. I know the bfg ko2 will fit in 285/65r20 but no one can get the ko2 for some reason bfg is discontinuing the tires and replacing with ko2 dt. The dt is not a 4 season tire only a 3 season tire and I have read reviews it is slightly louder than the ko2. Because of this change from bfg I'm now torn as to what tire to go with. I have been considering the ridge grappler in 285/65r20 but from what I can see online it is slightly taller, .2-3" and wider, ..3-4". Does anyone have the ridge grapplers that has run bfg in the past? Did it change the fit at all?
  13. Mar 20, 2020 at 10:43 AM
    #103
    Balrz
    Balrz New Member
    Ryu
    New 2020 Tundra crewmax off-road premium
    Any lift on this?
  14. Oct 11, 2020 at 5:54 AM
    #104
    TOMMYBOY1
    TOMMYBOY1 New Member
    Tom
    2023 Toyota Tundra Trd Sport Crewmax
    What lift set up do you have ??
  15. Dec 27, 2020 at 6:36 PM
    #105
    ThundaTundra4
    ThundaTundra4 New Member
    2021 Tundra Limited
    So I have a new 2021 crew max limited with the factory 20 inch wheels 275/55/20. Can I run a size up in tires on these wheels, 275/60/20, without having to do any modifications? Thx
  16. Dec 27, 2020 at 6:49 PM
    #106
    bjohnson425
    bjohnson425 New Member
    Brandon
    Any pics of how much has to be trimmed off the skid plate ? I’m looking at 285/65 on factory 20s for my platinum not looking to change a bunch of other stuff just yet.
  17. Dec 28, 2020 at 6:11 AM
    #107
    ThundaTundra4
    2021 Tundra Limited
    This is a really helpful post. I just got a 2021 crew max limited in the nightshade edition with the black 20inch wheels. Want to size up the tire a bit but really don’t want to do any modifications etc. I was going to go up one size to 275/60/20 vs the 55/20 but may go up two and do what you did. Although other posts seem to suggest doing that will create some rub. Maybe it’s just the newer ones???? Does anybody know?
  18. Jan 4, 2021 at 6:51 AM
    #108
    skitch
    skitch New Member
    TBD
    Can you share some pics of your "2021 crew max limited in the nightshade edition with the black 20inch wheels.". I'm waiting for mine to come in (Jan 18th). So few pics online I'd like to see more pics from actual buyers. Thanks.
  19. Jan 4, 2021 at 7:09 AM
    #109
    ThundaTundra4
    2021 Tundra Limited
  20. Jan 4, 2021 at 7:10 AM
    #110
    ThundaTundra4
    2021 Tundra Limited
  21. Jan 4, 2021 at 7:10 AM
    #111
    ThundaTundra4
    2021 Tundra Limited
  22. Jan 4, 2021 at 7:48 AM
    #112
    ThundaTundra4
    2021 Tundra Limited
    There are the couple I have. It’s a great looking truck for sure. I’m very happy with the wind chill pearl. Looks awesome. Hope you like yours too.
  23. Jan 4, 2021 at 10:39 AM
    #113
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Is the white paint no longer Super White?
  24. Jan 4, 2021 at 10:59 AM
    #114
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Bilstein 5100 2.3/1.5, TRD sway bars ft/rr, Cooper Tires Discoverer AT3 XLT 295.70.18, Vision Manx 2 18x9 +12, APS side armor steps, TRD-Pro Grill and Bulge, de-chromed, blackout emblems, OEM mirror caps and flares, TRD shift knob, Leather wrapped steering wheel, All weather mats
    Both my 2020 Tundra and 2012 Sequoia had no issues with the TSS after the lift/level in taller tires.
    My 12 Sequoia might have some issues due to icicles.
  25. Jan 4, 2021 at 11:20 AM
    #115
    ThundaTundra4
    2021 Tundra Limited
    Super white is still avail. Wind chill pearl is a special order that you can get in some models.
  26. Sep 10, 2021 at 2:34 PM
    #116
    Clyde17
    Clyde17 New Member
    2018 Tundra TRD Sport
    3/2 SST Readylift, 285/65R20 BFG KO2
    Was able to get them to fit with only bending the skid plate. Running 3/2 readylift. Only issue is it needs carrier bearing bushings for takeoff vibration. $20 fix, no issue.
  27. Nov 6, 2021 at 6:29 PM
    #117
    Trevornt
    Trevornt New Member
    Hey, old post but hopefully you're still active here. I see you are/were running 275/65/20 on a stock tundra. i am looking at 285/60/20. very similar i guess but curious of your take on this. base off you have .8'' height on this but then i have a .4" width added on mine. math behind it, im thinking itll be good but curious for yours or others opinions
  28. Dec 30, 2022 at 7:53 PM
    #118
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    I just purchased a set of Toyo ATIII in size 285/65/20. I also have the Bilstein 5100 setup on all four corners (middle setting up front). After install, I was rubbing on the skid plate, the front mud flaps, and the TRD sway bar. My brother has the same Bilstein setup and Nitto Ridge Grapplers in this same size, and he has no rubbing. For mine, I got rid of the mud flap rub by removing them, and fixed the skid plate rub by bending the corners up quite a bit. However, I still get occasional rub on the TRD sway bar. Has anyone come up with the cure for the sway bar rubbing and if left alone, will there be any longer term issues? Thanks guys!
  29. Jan 15, 2023 at 10:58 AM
    #119
    JT828
    JT828 New Member
    2019 Platinum
    Are you running those tires on stock 20” (60 offset) Limited wheels? Do you have spacers?
  30. Jan 15, 2023 at 11:18 AM
    #120
    lsumatt1514
    I am running later model OEM Toyota wheels that I believe came on Platinum model Tundras…bought them locally to modernize my Limited a bit.
    No wheel spacers.
