Black Rhinos
Discussion in 'Wheels & Tires' started by Jeff@SR5, Jun 8, 2017.
  1. Sep 2, 2021 at 8:21 PM
    dso
    dso New Member
    Vancouver, Canada
    2017 grey Tundra SR5 TRD want to be PRO
    Lots of TRD parts
    Need some help. A guy is selling a set of 20” black rhino Glamis from his 2011 Tundra. Just wanted to confirm that it will fit on my 2017. I know that the bolt pattern is the same (5x150) but i have read that the hub size is different. 110.0 on a 2011 and 110.1 on a 2017. I dont want to assume that the .1 with or will not make a difference. I may be wrong and all the tundras are the same center bore diameter. Thanks
    Rica25 likes this.
  2. Sep 2, 2021 at 11:38 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I'm pretty sure those wheels are not hub centric for the Tundra and probably have a hub bore of 118 or 125.
    Edit: so I'm wrong and the 20x9 5x150 Glamis have a hub bore of 110..
    2090GLA125150M10 is the part number. Unsure about the difference I'm hub size. Sorry for my misleading comment.
  3. Sep 3, 2021 at 12:01 AM
    One thing to look up on these black rhino wheels is weight. I was shocked when comparing them to other makes. Just an FYI
  4. Sep 3, 2021 at 5:42 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    They are heavy?
    My Stadium 18x8.5 are 29lbs.
    https://www.blackrhinowheels.com/off-road-wheels-rims-stadium.php
    Similar Fuel were 31-40lbs with a couple coming in at the same weight of 29lbs.
  5. Sep 3, 2021 at 5:44 AM
  6. Sep 3, 2021 at 5:48 AM
  7. Sep 3, 2021 at 6:19 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    @ColoradoTJ
    After looking now, I see a lot of variation too.
    Rica25 and ColoradoTJ like this.
  8. Sep 3, 2021 at 6:48 AM
    It’s not just BR either. I decided to stay with factory wheels on my truck since they were weight rated and 33 lbs. I did find some wheels that were 30 lbs, but they were spendy.
  9. Sep 3, 2021 at 12:48 PM
    bosscib
    bosscib New Member
    PA
    2023 TRD Pro
    My Overlands are slightly different so I can't say for sure. I will say that if your truck picture is current, you'll likely need to do some additional mods to get them to fit.
  10. Sep 10, 2021 at 2:17 AM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
  11. Sep 10, 2021 at 2:18 AM
    Brettstation37
    Brett
    Catskills NY
    All black though
    Jerry311SD likes this.
