Baffled at what this is
Discussion in '2.5 Gen Tundras (2014-2021)' started by ryan2828, Sep 8, 2021.
  1. Sep 8, 2021 at 4:21 PM
    ryan2828
    ryan2828 [OP] New Member
    So i drove home from work, which is about 22 miles of highway, park truck in garage. Jump back in it an hour later to take daughter to bball practice and while leaving the neighborhood i hear a weird grinding noise under the truck when i am turning slightly left at 20 mph. Immediately goes away when I straighten wheels. It does the same thing 2 minutes later on another slightly left turn at 35 mph. After i drop kid off i drove all over the place making uturns and circles and i cant repeat it.
    i get the truck home look over everything i can think of and don’t find anything. Just had new tires put on that morning so i pull all wheels off and dont find anything except all center caps are loose. Put everything back on re-torque and make same left turn in neighborhood aggressively and hear it for a second and then never hear it again.
    this morning leave for work same bend dont hear a thing. I’m thinking its all good…..wrong. Get home from work truck sits for an hour and then i leave to pick kid up from practice. Hit that same left turn in neighborhood and its back…wtf. Go down the road some more another left turn hear it again. Start driving all over the damn place and the more i drove it the harder it was to make the noise appear. Hit the same turn in neighborhood after driving it for 20 minutes and it won’t do it now.
    my gut is telling me it is the right front cv joint but why no consistency? No boots are ripped and no grease leaking. Its headed to shop tomorrow (not under warranty) and wanted more solid information to give to the tech because I’m afraid they are gonna drive it and not hear it. Any ideas?
    2015 CM/68,000 miles, leveled and 34” tires
    HulkSmurf14 likes this.
  2. Sep 8, 2021 at 4:29 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    No new tires or alignment or anything done to the truck recently before you noticed this? Just started randomly?
  3. Sep 8, 2021 at 5:14 PM
    ryan2828
    So thats the kicker about this whole thing. I changed the front/rear diff last week and had new tires put on yesterday and noticed it last night. However, i have been driving with the windows up for awhile because of the heat and you wouldn’t hear it with the windows up. So I’m thinking having the tires put on is just a coincidence to be honest.
    i just let the truck sit for an hour and drove it and its doing it but drive it for 20 minutes and its gone. I did notice that you have to turn sharper and more aggressive to get it to do it the more you drive it until the point that it wont do it anymore.
    jewsNbrews likes this.
  4. Sep 8, 2021 at 5:39 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Check your skid plate and sway bar. My guess is you're rubbing when leaning into turns. Check inside of tires too.
    I_Am_Thee_Walrus likes this.
  5. Sep 8, 2021 at 5:40 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Can you describe the noise better? Grinding, growling, metal scraping?
  6. Sep 8, 2021 at 5:49 PM
    ryan2828
    Its not the tires rubbing anything. If that was the case it would do it all of the time and i’ve been running the same size tire for a long time. Breaks are all with in a year of being replaced so haven’t messed with them at all recently.
    What got me scratching my head is if the truck sits all night and then drive it, no noise. Park it after driving it for awhile and get back in it an hour later it does it but you will only get the noise for about ten minutes of driving before it is gone. If something like tire or break was the problem one would think it would be very consistent
  7. Sep 8, 2021 at 5:51 PM
    ryan2828
    Sounds like metal rubbing metal
  8. Sep 8, 2021 at 6:04 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Maybe the rotor backing plate is bent slightly.
    Rodtheviking and 15whtrd like this.
  9. Sep 8, 2021 at 6:05 PM
    Half Assed
    Heartland Florida
    Maybe the brake backing plate got bent when changing the tires and it's rubbing the rotor only during a slight left turn.
    15whtrd likes this.
  10. Sep 8, 2021 at 6:08 PM
    ryan2828
    I did check that but didn’t find anything. Good idea though. Again if it was something like that one would think it would rub constantly.
  11. Sep 8, 2021 at 6:10 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    recent brake rotor replacement? what your describing sounds like the typical rear rotor inner drum slightly rubbing the backing plate when turning.
  12. Sep 8, 2021 at 6:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s not the VSC kicking in, is it? The ABS / VSC modulator pump makes a pretty good grinding noise.
    Nic146 likes this.
  13. Sep 8, 2021 at 6:26 PM
    ryan2828
    Rotors have been on for about 8 months
  14. Sep 8, 2021 at 6:28 PM
    ryan2828
    I’ve heard the vsc modulator pump working and that’s definitely not what I’m hearing
  15. Sep 8, 2021 at 6:29 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    I typically don't believe in coincidences, more than likely it has something to do with the work that was done on it.
  16. Sep 9, 2021 at 5:25 AM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    Torque lug nuts?
  17. Sep 9, 2021 at 6:16 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    the same thing happened on my tacoma. it turned out to be the left front diff needle bearing going out. the dealer wouldn't replace just the bearing, they wanted to replace the entire front diff at $3k.
    many guys use the ECGS bushings that replace the needle bearing:
    TOYOTA 9" REVERSE CLAMSHELL CV AXLE BUSHING (eastcoastgearsupply.com)
    here is a discussion about the bearing on tacoma world:
    Front Diff Vibes ECGS bushing fix. | Tacoma World
    the labor to replace the bearing is way cheaper than the front diff replacement.
    Nic146 likes this.
  18. Sep 9, 2021 at 7:28 AM
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    If it only happens for a short time after being parked, the first thing I'd check is the parking brake. perhaps you have a sticky cable or something causing the brake to hang for a bit?
  19. Sep 9, 2021 at 1:38 PM
    ryan2828
    Truck is at the shop now, we will see whats up. Thank you for all the responses.
  20. Sep 9, 2021 at 1:39 PM
    ryan2828
    Looks like it was the backing plate hitting the rear rotor. Will see after i drive it.
  21. Sep 9, 2021 at 1:43 PM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Didn't see anyone mention wheel bearing...could that possibly be it?
    Edit: OP's reply came in while I was typing. My backing plate hits the rotor too. I can only hear it when I drive by a building or a wall for the sound to bounce off and come back to me. It annoys the crap out of me but I just leave it alone.
  22. Sep 9, 2021 at 1:50 PM
    JeffMac
    JeffMac 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    Something similar happened to me and turned out to be my Driver’s side cv axle. Put your truck in 4HI and you’ll find out immediately.
