Help with New Headlights- Now LED running lights underneath won't work
Discussion in '2nd Gen Tundras (2007-2013)' started by 2013TundraGirl, Sep 8, 2021.
  1. Sep 8, 2021 at 5:05 PM
    2013TundraGirl
    2013TundraGirl [OP] New Member
    Cindy
    FL
    2013 Toyota Tundra Crewmax Xsp-X
    Lifted, Bigger Tires, Dual exhaust, Blacked out all emblems and grille
    I had these headlights installed and now the LED running lights won't work. The shop I took it to can't seem to figure it out! It's so frustrating!!! Any help? I realize the LED's are plug and play so to speak but something must have happened...they worked when I brought it in.
    Spec-D® 2LHP-TUN07JM-TM - Black Halo Projector Headlights with Parking LEDs
  2. Sep 8, 2021 at 6:14 PM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    Are all of the other lights functioning as expected? Check the connectors. Did you have to add a fuse for the LED’s to work? Pull the headlight out and hook it up to auxiliary power and see if it ignites.
  3. Sep 8, 2021 at 6:26 PM
    2013TundraGirl
    Cindy
    FL
    The LED's that were already there were factory installed and worked before I went in. The other lights are functioning.
  4. Sep 8, 2021 at 6:37 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    One very important note with how these trucks are wired. Stock, the DRL and blinkers are turned on with the same wire. Most aftermarket headlights will use a fuse tap to the ignition circuit to turn on a "new" DRL circuit. If you can trace some wires off the back of the headlights and snap some pictures of what is there I might be able to help more but there are a few things that can be going on.
    Nic146 likes this.
  5. Sep 9, 2021 at 6:08 AM
    2013TundraGirl
    Cindy
    FL
    Thank you, I will share your comments with the installers in hopes they can figure it out.
  6. Sep 12, 2021 at 10:09 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    Are you saying the DRL lights worked before the install and now don't? Do the turn signals still work? Do you get hyper flash while using turn signal or a solid arrow light?
    for some reason I'm playing my bets that it needs decoders plug in between the factory plug and DRL plug. If it was switched from a standard bulb to LED. (LED Decoder) is the term , fixes the issue with vehicles thinking low amp draw is a dead bulb and not sending power also stores power and acts as anti flicker. If the same DRL circuit is also the turn signals, don't be surprised if you also have to swap out the turn signal relay (underdash) for one rated for led's.
    Nic146 likes this.
