35 tire in spare location
Discussion in 'Wheels & Tires' started by fisherman951, Sep 8, 2021.
  1. Sep 8, 2021 at 11:26 AM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    Yes I know it’s been done so here’s my question.
    How safe is it to do it? How Many have seen the chain Fail?
    Had a conversation with a guy a couple days and he insisted that he has seen so many chains fail due to the 35 inch tire being so heavy. He warned me that I could kill some one and so on and so on. Just want to get peoples opinion and real life story’s.
  2. Sep 8, 2021 at 11:38 AM
    AZBoatHauler
    So.Arizona
  3. Sep 8, 2021 at 11:40 AM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    On my first Tundra Gen 2, I had a 35 stuffed in there for several years while off roading, etc. ZERO ISSUES. I now run 37' and unfortunately they do not fit.
  4. Sep 8, 2021 at 11:51 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Dude's a moron. Do it.
  5. Sep 8, 2021 at 11:55 AM
    diablodalton
    Dalton
    Oregon
    Also... two things... proof of failure? Second... was he supposed to do the work for you and used the "failure" as an excuse not to? (I have run into this before).
    15whtrd and Rodtheviking like this.
  6. Sep 8, 2021 at 12:16 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    No he’s a tow truck driver and thinks he’s mister know it all. It was a conversation at a buddy’s house my tundra didn’t break down lol
  7. Sep 8, 2021 at 12:26 PM
    diablodalton
    Dalton
    Oregon
    I was questioning his "experience" or "research" regarding the "chain failure". Your truck breaking down wasn't even a consideration. What a knucklehead your tow truck driving buddy is. Now this would be an fun experiment to run... how many pounds per square inch of pressure would it take to break the chain... in a real world application! Ripping along in the desert hitting pot holes and bottoming out may rip it off... driving down the road during normal use... uh no.
  8. Sep 8, 2021 at 12:56 PM
    snivilous
    SW UT
    I commemorate the attempt, but it's psi or ksi (pounds per square inch) for pressure, foot pounds is a unit of energy (or torque in normal conversation). :rofl:
    fisherman951[OP] likes this.
  9. Sep 8, 2021 at 12:59 PM
    15whtrd
    15whtrd Mr. Blonde
    Just do it man. Bend or cut the locating tabs on the spare. Lube all the chain and crank assembly up while you have it down, and put a new tire on. Good to go. I can only fit a 33 inch due to my shackles being larger. But a 35 would’ve fit with the stock shackles or any other brand than the one I went with LOL.
    NewImprovedRon likes this.
  10. Sep 8, 2021 at 1:00 PM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    If your really concerned about the chain, upgrade to wire rope.
  11. Sep 8, 2021 at 1:12 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    I’m about to. I’m tired of that thing taking up space in my bed. Why you gotta be so fancy with your shackles lol.
    15whtrd[QUOTED] likes this.
  12. Sep 8, 2021 at 1:14 PM
    diablodalton
    Dalton
    Oregon
    15whtrd and TheBeast like this.
  13. Sep 8, 2021 at 1:15 PM
    15whtrd
    15whtrd Mr. Blonde
    Right!? Been contemplating upgrading the leaf pack or at least changing to another brand. The only reason it fits now is cause I Jerry rigged a spacer in between the trailer hitch and the tire to push it cab forward just a bit.
  14. Sep 8, 2021 at 1:16 PM
    diablodalton
    Dalton
    Oregon
    Ha! I am always willing to learn as long as it is constructive criticism. Thank you for the correction. I will correct my original post and watch everyone really scratch their heads! HA!
    snivilous[QUOTED] likes this.
  15. Sep 8, 2021 at 1:36 PM
    TheBeast
    TheBeast The Beach
  16. Sep 8, 2021 at 4:57 PM
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I put a used 35" on a 20" wheel under mine just to make sure it fits. Only thing you will need help with is guiding it up but other than that you will probably never ever even get to use it. Drove a Tacoma on KO2s for 5 years without a flat.
  17. Sep 15, 2021 at 8:07 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    You just use a block of wood or what? Mine just barely rubs the driver side shackle bolt. I pushed it back while someone cranked but it wasn’t enough.
  18. Sep 15, 2021 at 9:22 PM
    15whtrd
    15whtrd Mr. Blonde
    :rofl:Yeah
    It still looks like it might rub the driver side slightly. But it doesn’t seem to be hurting anything. I had bigger grander ideas, but the block of wood has stayed in place for a while now.
  19. Sep 16, 2021 at 2:47 AM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Hahaha, great minds think alike. Yeah mine will probably just wear a notch I’m the lug it’s rubbing on but I’m too paranoid, was thinking maybe cut some old tire up for shim. Or just a block of wood if it’s worked for you. Thanks for the reply. :hattip:
    15whtrd likes this.
  20. Sep 16, 2021 at 4:02 AM
    War Machine
    War Machine SSEM # 5 3MW
    My solution was to just keep the stock spare under there and hope I didn’t get a flat. Never got a spare to match the others.
    Never had a flat, but always wondered how the stock spare would work with 35’s on the other three until I got to a tire shop. :notsure:
    Hightide and 15whtrd like this.
  21. Sep 16, 2021 at 5:02 AM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    I had a 295/70R18 matching spare under the bed for years. I have toytec shackles and had a little room on both sides of the tire, so a 35 could fit. I carry a 37" spare in the bed now and it saved me a few weeks ago when i had a flat on the highway. problem was i did not hav ea jack at the time that could lift the truck high enough, now have a pro eagle jack in the bed
    Hightide likes this.
  22. Sep 16, 2021 at 5:21 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    From what I read, you can limp to a tire shop as long as you put the spare on the front and are not in four-wheel-drive. Otherwise, the spare can jack you up in the rear because the wheels will be spinning at different speeds. I don’t remember how that jacks up the truck though.
  23. Sep 16, 2021 at 5:23 AM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Mine's been hanging there for going on 7 years now with no issues.
  24. Sep 16, 2021 at 5:26 AM
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    I tried mounting my 37 inch underneath but it didn’t fit. Even tried airing it down and putting a ratchet strap around it to compress it a little bit, but it still hit the leafs. Now I just chain it in the bed whenever I go on long drives (in the garage all other times). I have a tire patch kit if I pick up a nail, and have onboard air. Bout all you can do with 37s.
    Edit: as others have said, I don’t think a chain would fail either. Unless the tire wasn’t snug, or rust. It’s a freaking chain.
  25. Sep 16, 2021 at 5:29 AM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Sounds like a solid plan. I’m not that ballsy, even though I can’t remember last flat I’ve had I’m convinced it’ll happen 100 miles from any town, probably at dark.
  26. Sep 16, 2021 at 5:41 AM
    War Machine
    I’ll be sure to remember that. Thanks!
    Uhhhh....[QUOTED] likes this.
  27. Sep 16, 2021 at 5:42 AM
    War Machine
    Not ballsy, just not enough foresight and never got around to correcting it.
    Barrett50[QUOTED] likes this.
  28. Sep 16, 2021 at 9:41 AM
    empenaflor
    empenaflor New Member
    2014 TUNDRA 4X4 LTD - Black
    I just removed my stock spare...any buyers? Haha. I have a full size spare that I plan on tying down in my bed on my trip to Montana this weekend from San Diego. I'm thinking of going the Rigd Supply Megaswing route.
  29. Sep 22, 2021 at 5:59 PM
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Ended up using a hockey puck for a shim. Shaved a little off and was perfect thickness. :thumbsup:
    15whtrd[QUOTED] and biebs96 like this.
  30. Nov 13, 2021 at 2:14 PM
    Okierunner
    Okierunner New Member
    2020 TRD Offroad Crewmax
    Icon UCA Bilstein 6112/5100 Method 17s Ridge Grappler 35x12.50 Trd Dual exhaust
    Anybody have heat issues with a 35 under there? I just cut my guides out and sucked my 35x12.50 up under there. I have the TRD exhaust and its fairly close. Not sure how hot those rear pipes get but I don’t want a fire for sure.
