Crackhead resurrection
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra2, Aug 23, 2021.
  1. Sep 6, 2021 at 9:24 PM
    #361
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    No wonder there's not many Toyota people from your area ... No dealers means no trucks. They're everywhere in TX
  2. Sep 6, 2021 at 9:24 PM
    #362
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Hard to say currently. 3-4 month lead time on a frame last we did
  3. Sep 6, 2021 at 9:25 PM
    #363
    TRDGen
    TRDGen Schnooogins
    Travis
    Damn.
  4. Sep 6, 2021 at 9:25 PM
    #364
    empty_lord
    05 rollover special
    At this point they’re hand made when ordered for 1st gens
    TRDGen[QUOTED] and FrenchToasty like this.
  5. Sep 6, 2021 at 10:16 PM
    #365
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Mine was inspected near the end of March and frame was done in the middle of July at the same dealership.
  6. Sep 7, 2021 at 12:08 AM
    #366
    TRDGen
    TRDGen Schnooogins
    Travis
    Fuckin @Tundra2 will be getting the Bentley of Toyota then. Nice :monocle:
    bmf4069 and Tundra2[OP] like this.
  7. Sep 7, 2021 at 3:00 AM
    #367
    Tundra2
    Tundra2 [OP] Zoinked
    Noah
    Western Kentucky
    Carter is loaded down at McGeorge
    Unsure if I need just the body mounts, or all the hardware... given the rust it might not be a bad idea to replace it all, but that's a price tag already.
    Curious on what @empty_lord would do, or @shifty` or @BubbaW !
  8. Sep 7, 2021 at 3:06 AM
    #368
    NickB_01TRD
    KY
    Can the body mounts be inspected without removing anything? Never really have tried to take a close look at mine honestly. I know the trans mount is visible.
    Tundra2[OP] likes this.
  9. Sep 7, 2021 at 3:10 AM
    #369
    Tundra2
    Noah
    Western Kentucky
    Unsure. I'll have to look this coming Friday. I'm off this Thurs-Sunday. Won't feel like doing shit as I'm getting wisdom teeth pulled early in the AM Thursday...
    I found those solid motor mounts on TW that @empty_lord was talking about. Below is a link, and a quote.
    https://www.tacomaworld.com/threads/4-7l-v8-solid-motor-mounts-ready-to-go.447581/
    Unsure if they are truly worth the$470 bucks for a little bit of lost energy... thoughts?
  10. Sep 7, 2021 at 5:14 AM
    #370
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Nope.
    Even slightly stiffer mounts suck unless the vehicle is an all out performance build.
  11. Sep 7, 2021 at 6:36 AM
    #371
    You could loosen all the bolts on one side and jack the body up slightly to get a look at the body mounts. Could even remove them one at a time and inspect.
  12. Sep 7, 2021 at 11:57 AM
    #372
    I'll agree with this. I have Al subframe bushings and solid motor mounts in one of my SHOs. I can feel it when I run over the damn lines painted on the road.
  13. Sep 7, 2021 at 12:01 PM
    #373
    So one big question I have is this:
    There's a metric fuck ton of suggestions for shit to replace and we all like spending Noah's money, but the truck will be in the shop. He won't have access to it to do all this shit. So all this adds up to a ton of labor charges from Toyota, correct?
  14. Sep 7, 2021 at 12:53 PM
    #374
    Tundra2
    Noah
    Western Kentucky
    Some of it will be included. Body mounts, rear shocks, LSPV, Brake Bleed, lower control arms, cam sleeves...
    I'm trying to capitalize on the work that toyota will already be doing. Most bang for my buck.
  15. Sep 7, 2021 at 12:58 PM
    #375
    Tundra2
    Noah
    Western Kentucky
    So @TundraGirl2 and I moved the truck back into the yard. Pulled off the upper radiator hose to see how bad everything looks.
    Yeah, that's a big pile of rust right on the water outlet coming from the engine.
    Shame I don't have enough water pressure to hook a garden hose up to the water inlet at the bottom, and pump water through while I'm running the engine to flush out all the big particles.
    What's the smallest diameter pass through the coolant flows through inside the engine? Anyway to get to that easily?
    w666 likes this.
  16. Sep 7, 2021 at 1:02 PM
    #376
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Those are purpose-built parts, so it depends on what your purpose of the truck will be. That and ego/bragging rights. I would pass and use the $$$ elsewhere on practical parts for the trucks reliability and longevity of service and use.
  17. Sep 7, 2021 at 1:04 PM
    #377
    Tundra2
    Noah
    Western Kentucky
    True on the purpose built. Long term plan is a tow rig. You're 100% right through. I think I will pass on the solid mounts.
    Desert Dog[QUOTED] likes this.
  18. Sep 7, 2021 at 1:12 PM
    Desert Dog
    BTW, I was out in the middle of BF once with no medical services or dentist to be found and had to pull my own wisdom tooth out. It took me 3 hours with nothing for the pain using pliers and a cotton washcloth. I was almost in tears but when I was done I felt relief. When I got back home and told the dentist and his staff my story they stood there slack-jawed in disbelief at what I had done and how. Pussies. Lol
    Tundra2[QUOTED][OP] and bmf4069 like this.
  19. Sep 7, 2021 at 1:20 PM
    #379
    If PHM was here he would post that Ric Flair GIF for those rust/coolant pics. That is crazy.
  20. Sep 7, 2021 at 1:47 PM
    #380
    Tundra2
    Noah
    Western Kentucky
    FrenchToasty, bmf4069 and FirstGenVol like this.
  21. Sep 7, 2021 at 3:03 PM
    #381
  22. Sep 7, 2021 at 3:09 PM
    #382
  23. Sep 7, 2021 at 3:19 PM
    #383
    Tundra2
    Noah
    Western Kentucky
    I love Ernest! I forgot all about him. Lol
    bmf4069[QUOTED] and TRDGen like this.
  24. Sep 7, 2021 at 6:33 PM
    #384
    Tundra2
    Noah
    Western Kentucky
    After seeing the rusty randy inside the engine, I'm considering changing as many parts as possible that are easy to get to. Obviously, I can't change the block.
    Suggestions?
    As of right now, I have the TB/WP, Hyd. Tensioner, and radiator with hoses, and thermostat. Will be reusing spring clamps.
    Any other ideas on the cooling loop?
  25. Sep 7, 2021 at 6:51 PM
    #385
    Just to be clear, are you asking for advice on which codpiece to order?
  26. Sep 7, 2021 at 7:05 PM
    #386
    NickB_01TRD
    KY
    Will the cooling system ever be 100 percent again? Probably not. After changing as much stuff as you can get to and running the flush chemicals through it it'll probably cool just fine. You may just want to do a couple or few coolant flushes periodically for as long as you own it to keep it as good as possible.
    If it wasnt such a risk driving it due to TB I'd say drain as much of that out as you can and then run it with water and the cleaning juice and put some miles on it and just keep flushing but without doing the TB/WP first that might be a bad idea.
    FirstGenVol and Tundra2[OP] like this.
  27. Sep 7, 2021 at 7:06 PM
    #387
    Tundra2
    Noah
    Western Kentucky
    And how far to go with parts changing. I'm fine ordering OEM for the engine, but there are two different part numbers, and I can't tell the difference on mobile device.
    shifty`[QUOTED] likes this.
  28. Sep 7, 2021 at 7:12 PM
    #388
    These trucks and the 4.7L can take a lot of abuse. I agree with Nick and wouldn't worry too much about it. I think after a thorough flush(or 3) it will be ok. Maybe replace the radiator hoses.
    Sirfive and shifty` like this.
  29. Sep 8, 2021 at 2:05 AM
    #389
    Tundra2
    Noah
    Western Kentucky
    As of today, here's the things I've ordered with part numbers from where they came from
    1. THP108 (THP-108) Aisin Thermostat seal (RockAuto) $ 2.10
    2. THT015 (THT-015) Aisin Thermostat (RockAuto) $ 14.30
    3. BTT502 Aisin Hyd. Tensioner (RockAuto) $ 25.99
    4. TKT001 Aisin TB/WP component kit (RockAuto) $ 163.99
    5. 2210517 (221-0517) Denso Radiator (RockAuto) $ 116.79
    6. 62614 Continental Lower Rad Hose (RockAuto) $ 12.90
    7. 62680 Continental Upper Rad Hose (RockAuto) $ 11.52
    8. K060908HD Gates Serp. Belt (RockAuto) $ 29.79
    9. 810104R (8.10104R) Energy suspension Steering Rack Bushings (RockAuto) $ 26.79
    10. 33055-0C030 Shift Lever (McGeorge) $42.22
    11. 86212-0C010 Radio Mount Bracket (McGeorge) $10.59
    12. 86211-0C010 Radio Mount Bracket (McGeorge) $10.59
    13. 74451-0C010 Battery Hold Down Stud (McGeorge) $7.47
    14. 74404-0C010 Battery Hold Down Frame (McGeorge) $20.45
    15. 82821-35020 Battery Terminal Cover X2 (McGeorge) $21.72
    16. 16401-20353 Radiator Cap (McGeorge) $12.41
    17. 77310-48020 Fuel Tank Cap (McGeorge) $21.90
    18. 00295-00103 FIPG Oil Pan Sealer (McGeorge) $11.97
    There's still a lot left to be ordered...
  30. Sep 8, 2021 at 5:17 AM
    #390
    Tundra2
    Noah
    Western Kentucky
    Radiator in hand as well, but no pics. Mostly undamaged. Very few bent fins. No biggie for me. All nipples are unbroken... good situation.
    RainMan_PNW, NUDRAT and shifty` like this.
