Noise at 5MPH
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dillusion, Sep 7, 2021.
  1. Sep 7, 2021 at 1:19 PM
    Dillusion
    Dillusion [OP] New Member
    Kyle
    2019 SR5
    Need help.
    My Tundra makes a noise around 5mph. Its not like a thump if there is driveline slack. Its also not a belt slip. It sounds like its coming from the front but I'm inside so I could be wrong.
    But only on happens when I start it up and move for the first time. Will not do it again until I park.
    Happens in 2WD and 4WD cold hot. Etc
    Could it be my parking brake just needing adjustment? I do engage it all the time when I park. Now that I post this I never did try to park without the brake and try.
  2. Sep 7, 2021 at 1:20 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    ABS self check. All is well with your truck.
    TRDFett, 15whtrd, THinTX and 3 others like this.
  3. Sep 7, 2021 at 1:21 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome
  4. Sep 7, 2021 at 1:30 PM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    Welcome from Delaware @Dillusion
    Your all good, it is an ABS brake unit self test.
  5. Sep 7, 2021 at 1:47 PM
    Dillusion
    Kyle
    2019 SR5
    Good to know. My 2010 didn't do it thats why I was worried.
    JDR76 likes this.
  6. Sep 7, 2021 at 2:53 PM
    Mr Badwrench
    Mr Badwrench New Member
    Did the 1st gens do this?
  7. Sep 7, 2021 at 3:46 PM
    15whtrd
    15whtrd Mr. Blonde
    If you set the door locks to lock at speed instead of when you put it into Drive, it will cover up the noise.
    1lowlife likes this.
  8. Sep 7, 2021 at 3:50 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
