21 limited to trd pro grille bulge issues
Discussion in '2.5 Gen Tundras (2014-2021)' started by ArdnuT trd, Sep 6, 2021.
  1. Sep 6, 2021 at 4:26 PM
    ArdnuT trd
    ArdnuT trd [OP] New Member
    Blake
    2021 Tundra MGM TRD 4x4 CM limited
    hey tundra brothers and sisters, I have a 21 tundra and I purchased for my limited via my mains Toyota dealer part 76180-0c030-b1 and 53101-0c070-b0 and 53141-34010 magnetic gray metallic bulge pro grille and factory garnish. I replaced bumper ends with those from sparks painted at platinum spec those were alright quality fog lamp housings have play in them not solid parking sensors were difficult to install. My biggest problem is the bulge which says platinum doesn't line up to the pro grille, the lines don't anyway. Can anyone help ,e out with this? I also need a new center console armrest tray where it says sr5 or limited my wife's nails scratched mine all up thank you
    Blake
  2. Sep 6, 2021 at 4:29 PM
    ArdnuT trd
    Blake
  3. Sep 6, 2021 at 4:37 PM
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    The lines seem fine. All 3rd gen bulges are interchangeable
    JDR76 likes this.
  4. Sep 6, 2021 at 4:44 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I agree..
    What is not lining up @ArdnuT trd ?
  5. Sep 6, 2021 at 4:52 PM
    ArdnuT trd
    Blake
    The bulge and grille seem a 1/4 inch off from my father in laws white pro which is dead nuts even. The bulge to the grill.
  6. Sep 6, 2021 at 4:56 PM
    trucknut
    trucknut New Member
    Are you sure you pushed the clips in all the way and tightened the screws down? It does seem a little forward but not much
  7. Sep 6, 2021 at 5:26 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Definitely grill needs adjustment, check if you got grille's lower guide pins seated correctly
  8. Sep 7, 2021 at 7:04 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I replaced the hood bulge over a year ago, and all the lines were pretty straight. Just this summer I replaced the stock Limited grill with a Platinum grill to complete the chrome removal, and with the new grill the lines don't match up quite right. All parts are OEM.
    I will say that I'm not real happy with that but realize these parts are just molded plastic and don't always end up the same, part to part. Overall my truck looks much better now and I've just accepted the imperfection and don't dwell on it.
