Rear sway bar...never saw one mounted this way
Discussion in 'Suspension' started by Tundra234, Sep 6, 2021.
  1. Sep 6, 2021 at 8:31 AM
    Tundra234 [OP] New Member
    Never saw one mounted this way...I was behind him at a light. I wish that I was able to see the whole thing. Curious as to how the end links fit or if they were shortened.
  2. Sep 7, 2021 at 6:43 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    looks like a lot of lift in the rear on that truck, which is why they mounted it as such. Looks like maybe a 5 or 6 inch rear lift. I
    ve seen plenty of them set at the middle mounting rather than mounted under per the instructions, but the middle mount was on truck with about 2-3 inches of lift. If the truck has 3+ inches lift, mounting on top like this may be needed so the end links are long enough to function.
