Is rear end seeping
Discussion in '2.5 Gen Tundras (2014-2021)' started by mundra, Aug 9, 2021.
  1. Aug 9, 2021 at 5:41 PM
    mundra
    mundra [OP] New Member
    Ormond Beach, Florida
    2019 platinum 4x4
    315/70/17 Ridge Grapplers on Rock Warrior Wheels, Tinted windows,remote start,tech12volts audio upgrade w/2-10" subs, console charger, more to come soon.
    Is this a leak around the rear end? Or is this normal?
  2. Aug 9, 2021 at 5:45 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Normal-ish. It happens to a lot of our trucks but it’s nothing to worry about. Just keep an eye on it.
    Elduder, AZBoatHauler and 15whtrd like this.
  3. Aug 10, 2021 at 5:12 AM
    mundra
    2019 platinum 4x4
    I am glad to hear that. I only have 35,000 miles on it so I wanted to make sure.
  4. Aug 10, 2021 at 5:17 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    You are inside your warranty. I’d suggest taking it in to the dealer. They can inspect it and most importantly document it just in case it becomes a bigger issue down the road.
    Barrett50 and Cpl_Punishment like this.
  5. Aug 10, 2021 at 5:28 AM
    mundra
    2019 platinum 4x4
    I think I will and also have the fuel pump recall done while I am in there as well. Any issues from the fuel pump recall? I ask because I had a Ram back in 2012 have a recall and they did it but it killed my mileage. LOL
  6. Aug 10, 2021 at 5:37 AM
    Abrown3912
    Abrown3912 New Member
    2021 Crewmax
    My rear end leaks after taco bell
  7. Aug 10, 2021 at 5:46 AM
    mundra
    2019 platinum 4x4
    they make a special plug you should use for that.
  8. Aug 10, 2021 at 7:56 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Mine looked similar at about 30k; took it to dealer to have a look and get it documented. They cleaned it and I have no signs of seeping - at 60k now.
    mundra[OP] likes this.
  9. Aug 10, 2021 at 8:50 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Darkness likes this.
  10. Aug 10, 2021 at 8:57 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Yeash... it is called "cheese".
    Or, for those of you whom enjoy Tim & Eric's Awesome Show: Great Job! you can opt for the Diarrheaphragm by Cinco Corporation.
    trucknut, TRDFerguson and Darkness like this.
  11. Aug 10, 2021 at 10:12 AM
    mundra
    2019 platinum 4x4
    Goes in to Dr. Toyota to get the fuel pump recall and have the rear end looked at for precaution later this week. I hate others touching my truck but that's what warranty is for! :thumbsup:
  12. Aug 13, 2021 at 3:08 PM
    mundra
    2019 platinum 4x4
    After dealer viewing it’s all ok. I had the fuel pump recall done and they wanted to do the rear diff and transfer case oil changes for $400. I guess I’ll be doing those myself. Synthetics?
  13. Aug 15, 2021 at 4:55 PM
    PNWTunrda
    PNWTunrda New Member
    Dean
    2016 Tundra
  14. Sep 6, 2021 at 6:31 PM
    mundra
    2019 platinum 4x4
