2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Sep 6, 2021 at 8:50 AM
    Pac12AfterDark
    Pac12AfterDark New Member
    It goes without saying I will only step on a lot if there is inventory on the lot (probably 2024 and beyond).
    Will only be buying if it comes in a crew cab + 6 ft bed config.
    Otherwise.. probably time to step up to a 3/4 ton.
  2. Sep 6, 2021 at 9:01 AM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    Crew Cab or Crewmax?
  3. Sep 6, 2021 at 9:06 AM
    Pac12AfterDark
    Sorry "crew max" with a 6 foot bed. Looks like they are keeping the same cab and bed configs?
    That's too bad..
  4. Sep 6, 2021 at 9:09 AM
    BigArt
    BigArt New Member
    It will come with long bed.
    Ahab and MTRock like this.
  5. Sep 6, 2021 at 9:09 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    No, it's not. We do it all the time. And we also find logic to also be overrated.
  6. Sep 6, 2021 at 9:09 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    I agree for the most part. I think the new engine will be just fine. Mostly due to the fact that its boosted. It may not be a world beater, but I'm sure it will perform better than the outgoing V8. The Taco engine sucks because its NA. Boost can overcome a lack of displacement.
  7. Sep 6, 2021 at 9:10 AM
    Pac12AfterDark
    I dont know who you are, or how you got that.
    You just made my whe day.
    Ahab likes this.
  8. Sep 6, 2021 at 9:14 AM
    BigArt
    BigArt New Member
    It was posted in the 2022 thread.
    You’re welcome!
  9. Sep 6, 2021 at 9:14 AM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    It might be done at times on this forum but that never a strong position. Arguments always need to based on a data point.
  10. Sep 6, 2021 at 9:17 AM
    Xspurt
    Xspurt New Member
    At TIMES? LOL! The entire Internet is based on arguments without data! :rofl:
    RavingOx, GODZILLA, Larly5000 and 4 others like this.
  11. Sep 6, 2021 at 9:18 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Good luck driving that monster CM 6.5’ bed. It’s not build for SF for sure
  12. Sep 6, 2021 at 9:27 AM
    Jonross227
    Jonross227 New Member
    I don't know the big uproar about car engine vs truck engine. The heads, cam and tuning make all the difference. The knock on the Tacoma as a car engine is that it's tuned like a car engine. High rpms to make any power.
    An ls1 is a car engine. But if you put a new set of heads, a truck cam, and a tune for it all it makes one hell of a truck engine.
  13. Sep 6, 2021 at 9:35 AM
    Melikeymy beer
    Muscogee Nation
    I'll disagree. The reason some perceive that the Tacoma 3rd gen engine "sucks" is not because it's a "car engine" or because it's NA (first time I've heard that one). The real reason the haters hate it is because of how it's tuned to maximize economy.
    GODZILLA and Gray223 like this.
  14. Sep 6, 2021 at 9:37 AM
    JuicyJ
    JuicyJ New Member
    I signed up on here to learn about the new Tundra. Then I hear some Gen2 Tundra owners mentioning (rarely) engine problems, like "cam tower leak" TF is that? I had to look it up. Oh, seems pretty crappy to me.
    I have been on the Titan forums since 2004, and anecdotally, the VK56 doesn't have any engine issues, at all. True, we don't have million-milers, but we do have 300K-500K dudes, and I just can't imagine how much gas it took to do that many miles, let alone a million in a Tundra.
    And the reason I am looking at the new Tundra is Nissan totally hosed the Gen 2 of the VK56, those engines needed long-block replacements for cylinder 7 damage in the Titan, XD, Armada and QX. And that's where my brand loyalty ends.
  15. Sep 6, 2021 at 9:40 AM
    IsaiahCanada
    Isaiah
    Calgary, Alberta
    Does that long block cylinder replacement constitute a major reliability issue?
  16. Sep 6, 2021 at 9:41 AM
    JuicyJ
    JuicyJ New Member
    I hear people saying it's the 6AT that sucks.
    The 6MT is supposedly better, and it comes with lower final gears that helps. Problem is, the 6MT is only available in weird places in the Tacoma lineup.
  17. Sep 6, 2021 at 9:42 AM
    JuicyJ
    JuicyJ New Member
    To me, it does.
    That is why I said Gen 1 VK56 (PFI) is super reliable, and the Gen 2 VK56 (DI) is so bad I am now considering a Tundra.
    IsaiahCanada[QUOTED] likes this.
  18. Sep 6, 2021 at 9:43 AM
    Melikeymy beer
    Muscogee Nation
    And people that get the OV tune on the AT also overwhelmingly say it resolves the sluggish feel at low RPM.
    shellshock likes this.
  19. Sep 6, 2021 at 10:00 AM
    Markful
    Markful New Member
    Mark
    Puyallup, WA
    '21 DBL CAB PRO LR, '08 dbl cab (gone)
    Curious... I don't see the trd pro model on this list. Am I missing something? I'd do a pro with crew max long bed for sure if so.
  20. Sep 6, 2021 at 10:00 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    It sure wouldn't, but cities where driving a dually is ok won't be an issue for a CM 6.5' since it's a foot and a half shorter. One of those things that just takes getting used to, drive 8' bed crew cabs enough and 6.5' ones are no issue. It's only an extra foot over the 5.5', not like you're going from a tiny little Smart car to the full size
    JuicyJ and Cpl_Punishment like this.
  21. Sep 6, 2021 at 10:05 AM
    tttrdpro
    tttrdpro Former Naval Person
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I disagree. I still hated driving my ‘18 Taco even with OV Tune. It was still nutless.
    ColoradoTJ and JuicyJ like this.
  22. Sep 6, 2021 at 10:07 AM
    JuicyJ
    JuicyJ New Member
    I'd like the same config. Unfortunately, it seems most truck companies have justified limiting their off-road trims to short bed crew cabs.
    I think it's the same with the Tacoma, you can get a crew cab long bed 4x4 Tacoma, but I don't think it is offered in TRD Pro??
  23. Sep 6, 2021 at 10:10 AM
    Pac12AfterDark
    Yeah, SLC is only slightly better in sure. Luckily I'm in the burbs.
    Wife's TDI pulls duties when we go out.
  24. Sep 6, 2021 at 10:12 AM
    JuicyJ
    JuicyJ New Member
    I've had several tunes on my current truck (NA V8) and several tunes on my 2016 GTI (2.0T) and in my experience, "tunes" on NA engines are worthless. Even the ones that say they "improve" transmission shifting seem to rely on placebo effect.
    On a turbo car, totally different. I was able to get +80whp on a 3200lb car with a Stage 1 tune, and the car was a beast.
    I'm going to eventually get around to removing the tune from my current truck.
    tttrdpro[QUOTED] likes this.
  25. Sep 6, 2021 at 10:12 AM
    Melikeymy beer
    Muscogee Nation
    I'd still bet Toyota could have tuned that engine to make 90% of the owners happy with it's performance. But they would have complained (more) about the MPG.
  26. Sep 6, 2021 at 10:14 AM
    tttrdpro
    SWGA
    2024 GMC 2500 AT4
    In progress…
    I’m sure you’re right but IMO performance > mpg.
    JuicyJ likes this.
  27. Sep 6, 2021 at 10:14 AM
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Maximize economy??? Spent a week in a 2021 taco few months ago. Going 72 mph with a slight headwind I got 13.7 mpg. Also had a hard time keeping it at 72 mph. I averaged 15.6 for the week. Hate to see it without that maximized economy. Two people in the truck, with two suitcases.
    Westerntowboss and JuicyJ like this.
  28. Sep 6, 2021 at 10:15 AM
    JuicyJ
    JuicyJ New Member
    I live in the Seattle area. Possibly worse than SF.
    I actually am looking forward to something bigger than I currently drive (Titan Crew Cab Big Tow 5'7" bed) I don't understand why the parking spots are so small compared to other cities, so I love cramming too much truck into too small a spot. It's like my own little middle finger to those that try and force change through design.
  29. Sep 6, 2021 at 10:18 AM
    Melikeymy beer
    Muscogee Nation
    The MPG at interstate speeds of 75-80 on my 3rd gen Tacoma was about the same as my Tundra. On my commute to work at 60-65 I would get 22 MPG. Something was wrong with your truck.
  30. Sep 6, 2021 at 10:21 AM
    JuicyJ
    JuicyJ New Member
    That'd basically mean programming out the Atkinson cycle, the 3.5's main reason for existence.
Thread Status:
