Airbag light ON, no Cruise Control, but Horn works - Clock Spring issue?
Discussion in '2nd Gen Tundras (2007-2013)' started by baraynavab, Sep 4, 2021.
  1. Sep 4, 2021 at 9:04 PM
    baraynavab
    baraynavab [OP] Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Hey folks,
    So trying to solve this problem on my new to me 2007 Tundra Crewmax SR5 4x4. The dashboard has the Airbag light ON (and ofcourse TPMS) at the same time the Cruise control (CC) does not work no matter how many times I press the on/off button on the side, I just do not see the green Cruise button on the dashboard. Being a bare bones truck, my steering wheel does not have any switches on it. Just the CC on/off stalk switch.
    Now my horn is working good. Looking at several post has not fully nailed down the root cause. Some replaced the Cruise control and it started working, some replaced the clock spring. T
    I tried looking for clock spring part number for my truck but I cannot find it. Is there any clock spring for my Truck?
    Any help in this matter would be invaluable. TIA
    ---------------------- POST FIX ---------------------------
    TLDR - It was the clockspring in my case that fixed both the issues. My horn always worked. Easy way to diagnose it is to pull the airbag light code and see if it has to do with front Drivers side airbag codes. This will confirm that at least you need to change clockspring to fix airbag light.
    - How to fix - Watch clockspring videos online 2-3 of them. Get an idea of how to fix them. Then DIY fix them after ordering clockspring. Usually take 45-60 min for first timer to fix this.
    - Where to ordered the clockspring and paid? - I ordered from ebay. My CS was only $14 bucks shipped. But worked great.
  2. Sep 4, 2021 at 9:35 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Sounds like clock spring. Easy to replace and cheap. Got mine off eBay, just search 2007 tundra clock spring and something like this should pop up:
  3. Sep 4, 2021 at 10:08 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    It could just be the clock spring, but it could also be the cruise control switch as well. I had cruise control issues, and it turned out to be both in my case. It was well worth the $$ to pay a shop to do the proper diagnosis. They showed me a flowchart like diagram of the pathway they used to diagnose.
    You could gamble and just throw parts at it and save the $$ on labor and come out ahead. I often have that inclination too lol.
  4. Sep 4, 2021 at 10:21 PM
    baraynavab
    Atlanta
    Could someone with access to Online Toyota Troubleshooting access please download the troubleshooting steps for diagnosing this problem so we dont just throw part to it? i.e. the flow chart...To me its likely the clock spring needs replacing. But its good T-shooting before knowing if its Clock spring or the Cruise switch itself that has gone bad. That would be great time saver for all of us.
    Thanks
    MT Madman likes this.
  5. Sep 5, 2021 at 9:31 AM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    You can have the SRS codes read with a moderately priced scan tool, and many auto parts stores will loan you one to do that. If the code points to the driver's front airbag and you have CC issues, that is the clock spring.
  6. Sep 6, 2021 at 6:09 AM
    baraynavab
    Atlanta
    Update 1 - Codes Scanned via Techstream - So I managed to get Toyota TIS Techstream attached to the Tundra and scan for codes. I get a code for "B1801 - Open in D Squib Circuit". Which when I looked it up is involved with swapping out the clock spring. So I know at least my airbag light is because of this issue. So I ordered the clock spring. I'll update when I swap out clock spring and report back if this fixes the SRS light and Cruise control as well.
    BTW if anyone in the Northern Atlanta area needs to use Techstream let me know.
  7. Sep 10, 2021 at 1:23 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    how easy is it really to replace the clock spring? I am having the same issue and, while I am mechanically inclined, messing with the steering wheel (airbag) kinda puts me off.
  8. Sep 10, 2021 at 1:47 PM
    audiowize
    Paul B.
    If you disconnect the battery and wait ten minutes, the airbag won't go off.
  9. Sep 10, 2021 at 2:15 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    you messin' with me?
    WILLINH likes this.
  10. Sep 10, 2021 at 2:37 PM
    audiowize
    Paul B.
    No, that's how you disable the SRS system.
  11. Sep 10, 2021 at 2:58 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    good to know! thanks
  12. Sep 10, 2021 at 4:36 PM
    baraynavab
    Atlanta
    I plan on replacing the clock spring tomorrow. Will report back. Thanks.
    grave likes this.
  13. Sep 10, 2021 at 8:30 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    Looking forward to it. My new-to-me ‘07 DC SR5 is giving me identical issues. My ‘06 4Runner’s airbag light is on but the CC works just fine ¯\_(°~°)_/¯
  14. Sep 11, 2021 at 8:07 PM
    baraynavab
    Atlanta
    Final Update - SUCCESS - The clock spring swap worked. The ABS light is gone i.e. Off and Cruise Control is now working. BTW you do have to swap out the steering wheel sensor from the old CS to the new one. But it was easy. This was the first time I am doing this so it took me like 45 min. But if you know what you are doing it takes probably 20-30 minutes tops. BTW I bought the cheaper CS off ebay. Mine cost me $14 shipped.
    Now I know the China quality and hopefully this will last for a while. Right now my truck has 276k miles. So we'll see how long it last's.
    grave likes this.
  15. Feb 27, 2025 at 8:38 AM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    3+ years later, i got an OEM clock spring last week. i have to install a hewitt bypass kit this weekend because i got a P2440 code, but if i finish that in time i will be moving on to the CS. will report back!
    Rph74 and baraynavab[OP] like this.
