  1. Sep 5, 2021 at 8:55 PM
    #7201
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Continuation from 7433. We had our electrical inspection last Monday, where we covered all of the options, but mainly the electrical. Found a few minor framing details, that would be easily corrected. We did notice they added a header above the two sliding windows. In further discussion, we decided to add additional support wood on that window and two others on the side to facilitate future curtain rods. Also the placement of the hand bar in the master shower and bath 2. We moved the placement of a floor electrical outlet. They did add electrical to the storage, and it looks like they will let it remain. Good. We noticed the siding was stacked outside and caulking inside. On Tuesday our future neighbor sent a photo showing them starting the siding. We had to drive up past the build on Friday for other business, and stopped at the house. The guys said they would be done with the siding. Also the septic system was delivered and installed since the last post. Next is sheet rock after the inspections are done at this point.
    FAA22FB6-5188-4F7A-BE5D-F89B9A16273E.jpgD797C372-786B-4609-86AC-343DA0506290.jpgA7F85ED9-344B-41E9-B50E-B5D4E9463CE2.jpg18726E0C-5187-4BB1-91A9-2190C5F943B1.jpg4E095575-769F-480E-A8E6-B47BE7273D70.jpg9F7EE401-4167-4E23-BDD0-2226787D3D84.jpg3C3191C8-6DD5-4324-8949-86F99F59CAF1.jpg8BF9202D-9291-43EA-AA38-E015D90413EF.jpg
    1UPPER, Yzed608, crewmaxlmt and 6 others like this.
  2. Sep 5, 2021 at 9:56 PM
    #7202
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    Went to visit my son up in WA state, and got worked like a rented mule. Hung a flag over the garage door, built a work bench, hung paddle boards from the garage wall, installed a combo light switch receptacle in a utility closet, replace the lights in the garage with the flat panel led's Costco sells and laid some horse mats in part of the garage for a home gym. Tomorrow over to my other son's house to build a fence in the back yard.93BC4090-DF03-43AF-898E-E58E9FE6C8D6.jpg4D567BDC-9C44-4F85-B53F-35E0D43FAC32.jpg37A45894-AB75-4D07-9D6E-12050B49BAC2.jpg
  3. Sep 5, 2021 at 11:45 PM
    #7203
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Wanna stop by my place before you leave the state?
  4. Sep 6, 2021 at 2:34 AM
    #7204
    mugzy
    mugzy New Member
    Utah
    2014 Platinum
    TRD CAI, TRD Front and Rear Sway Bars, TransferFlow 46 Gallon Fuel Tank, LED lighting
    I completed a solar project in early spring this year. It’s a 7kw system with a 16kwh battery. We are oversized by about 20% currently compared to our usage but we built in some flexibility for growth. We’ve since learned we can “almost” get through an entire night on battery alone with the A/C during peak summer temps. Sun rises and the battery is charged again by 10 A.M. The remainder of the day is sending back to the grid for the most part. While the tax incentives still apply in part, the primary driver for me was energy independence. With all the uncertainty in the world with weather, fluctuating energy prices and the increased practice of rolling black outs in the west(I haven’t experienced this personally but the ideology is spreading eastward) the peace of mind is well worth it to me. In the last 6 months my electric bill has been only the utility connection fee.
    I like the system so much I’m considering adding additional panels and a second battery, but I’ll wait another 6 months to make that decision. The Mrs. and I believe we are in our forever home and that factors in to the decision as well. I’ve always wanted to do solar but in this case it really just made sense for us.
  5. Sep 6, 2021 at 7:28 AM
    #7205
    BB Stacker
    So. Cal
    Probably going to stop at a lumber yard in Portland and pick up 30 or 40 2X4X8's for a project I a working on at home. 2X4X8's we almost $9 when we left San Diego. They were around $2.89 at the Home Depot in Portland. Plus no Sales Tax and a Military discount...
    If you see a white tundra loaded down with 2X4's headed south on the 5....
  6. Sep 6, 2021 at 7:36 AM
    #7206
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    2x4s are 4.28 CAD in Alberta.
    Outbound likes this.
  7. Sep 6, 2021 at 10:54 AM
    #7207
    WAtundra4x4
    Den
    Wet side WA
    I am In The process of moving in a couple months. Met my new neighbor who installs solar panels, so I might do it also if the numbers work out. The idea of energy independence sounds good. I will have propane but will add a heat pump for reducing costs. With solar and propane I could go a long time.
    mugzy[QUOTED] and TaquitoBandito like this.
  8. Sep 6, 2021 at 3:28 PM
    #7208
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Nice. But at least the mule's owner gets some $ :p
  9. Sep 6, 2021 at 10:08 PM
    #7209
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    You could hang a tennis ball from a string that will hit her windshield or rear window at desired park spot. $1
    WAtundra4x4 and CodyP like this.
  10. Sep 7, 2021 at 5:43 AM
    #7210
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Tried that years ago.
    She wouldn't stop when she hit the ball.
    She has no choice but to stop now.
    Besides that I didn't like the ball hanging in the middle of the garage when I'm working out there.
    Money really isn't an issue for me, but thanks..:thumbsup:
    RainMan_PNW and TaquitoBandito like this.
  11. Sep 7, 2021 at 6:52 AM
    #7211
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    well then buy a new caddy with front park sensors! :rofl:
    teamtlr, MS22 and CodyP like this.
  12. Sep 7, 2021 at 10:41 AM
    #7212
    MEWaters
    MEWaters New Member
    Maine
    Apparently a 3" ball is more in the way than a 6' rubber stop at the feet , in front of the work bench. Lol
  13. Sep 7, 2021 at 11:43 AM
    #7213
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Finally had the roof replaced on the old farm house before winter, before my grandfather passed away he told me to always keep a good roof on the house and barn and that they would last forever.
    kparrow, YorkT, Refusuck and 9 others like this.
  14. Sep 7, 2021 at 11:53 AM
    #7214
    @PLC721 as someone who is currently dealing with a lack of step flashing on parts of my roof, I appreciate how they added that flashing around the chimney. Also, that's a lot more green than I was expecting for Arizona terrain. Is that farm in another state?
    TaquitoBandito and PLC721 like this.
  15. Sep 7, 2021 at 11:56 AM
    #7215
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Yes it's in NW Pennsylvania, much greener than AZ is :)
  16. Sep 7, 2021 at 12:51 PM
    #7216
    1lowlife
    DADA
    2014 MGM DC SR5
    Yes it is.
    I would explain it to you, but IDGAF.
    Perhaps you should stick with renewing His grace..
    Have a nice day..
  17. Sep 7, 2021 at 12:58 PM
    #7217
    1lowlife
    DADA
    2014 MGM DC SR5
    It's her car, not mine.
    She buys and pays for what she wants.
    The stop works fine, it isn't in my way..
    Not sure why any of you care so much about it..
    Hope you can find something better to do with your time..
    TaquitoBandito likes this.
  18. Sep 7, 2021 at 12:59 PM
    #7218
  19. Sep 7, 2021 at 1:40 PM
    #7219
    bobbilly
    bobbilly New Member
  20. Sep 7, 2021 at 1:46 PM
    #7220
    Danimal86
    Daniel
    Sacramento, CA
    we just :jellydance:
    1lowlife[QUOTED] likes this.
  21. Sep 7, 2021 at 1:54 PM
    #7221
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    I do one big project a year, and it's usually one that the better half has lobbied for. This year it was mine; tore out the old workspace, replaced the garage doors and fully insulated.
  22. Sep 7, 2021 at 2:05 PM
    #7222
    1lowlife
    DADA
    2014 MGM DC SR5
    That looks nice...
    Kratos[QUOTED] likes this.
  23. Sep 11, 2021 at 4:38 PM
    #7223
    Abrown3912
    Abrown3912 New Member
    2021 Crewmax
    Formed the concrete countertop in the garage. A few adjustments to the mesh and it’s ready for concrete.
  24. Sep 11, 2021 at 8:30 PM
    #7224
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Spent the day organizing and cleaning the basement storage and workshop. Not done yet, be we got through a lot. Moved five racks of shelving, loaded a ton of shit into the truck for the recycle/waste center, and chilled at least 30 gallons of old paint that we’ve held onto but no longer have anywhere in the house…
  25. Sep 11, 2021 at 8:52 PM
    #7225
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I’ve been wanting to do my three car garage project for years now. I moved everything out of the garage to give my epoxy flooring guys room to grind my floor and install an epoxy flake covered floor. I found a lot of unused space under my stairs and made room for my refrigerator to go under the stair landing.
    The epoxy flake floor after it was installed before they sealed it.
    Since my ceilings are so high I got a scissor lift to make painting and doing the electrical work safer. All of the walls and ceiling were all originally painted a flat beige color.
    Here’s my garage after painting the ceilings white , painting the walls gray and installing the high bay led light.
  26. Sep 12, 2021 at 6:06 AM
    #7226
    1UPPER
    TEXAS
    Flux capacitor!
    Thank you, Ron! I’ve been putting my garage on the back burner for years since I’m always working on everyone one else’s home first. Lol
    NewImprovedRon likes this.
  27. Sep 12, 2021 at 6:13 AM
    #7227
    1UPPER
    TEXAS
    Flux capacitor!
    Here is a little project I did in a day and half for a client of mine last week. I installed some old reclaimed long leaf pine and oak boards on their master bedroom coffered ceiling. I used 2”, 5, 6” and 8” wide boards. They were very happy!
    I painted the back of the ceiling a dark brown first. I snapped chalk lines for my ceiling rafters. I did this whole install by myself which wasn’t to bad but it took a lot of back and forth walking outside for all my cuts.
  28. Sep 12, 2021 at 5:31 PM
    #7228
    TaquitoBandito
    Joel (AKA Bif)
    I had to fix our pantry door - the screws stripped out of the frame. Bob Villa University to the rescue. I drilled out the holes, glued some 1 inch dowel rods in and then re-screwed.
    I've also been spending the last two weekends trimming trees.
    T-Rex266, xJuice, WAtundra4x4 and 4 others like this.
  29. Sep 12, 2021 at 7:37 PM
    #7229
    drobb
    drobb The Feral Snail
    2013 Tundra CrewMax 4x4
    BF4793D7-AF21-4496-B2E4-B12C316A2136.jpg 790E790D-631F-42C7-A2CF-78E708E0BB2C.jpg Added solar lights to the front yard areas.
    T-Rex266, 1UPPER, Fotnot and 5 others like this.
  30. Sep 12, 2021 at 8:09 PM
    #7230
    Yzed608
    Yzed608 New Member
    Wisconsin
    Washed the snowmobile trailer, then had some help leveling some of the bricks where it sits as the ones where the wheels sit were sinking a bit.
    T-Rex266, Fotnot and TaquitoBandito like this.
