Coil spring on top of leaf?
Discussion in 'Suspension' started by BecauseRacecar, Aug 30, 2021.
  1. Aug 30, 2021 at 8:56 AM
    BecauseRacecar
    BecauseRacecar [OP] New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    I was at the racetrack this last weekend and saw a guy with large enclosed trailer and a Tundra. His sat nearly perfectly level and had what looked like a small coil spring laying lengthwise on top of the leaf spring. What are those called?
    That plus the weight distributing hitch seemed to really help the truck sit nice and level, even though he had a truck cap and a bunch of stuff in the bed, hooked up to at least a 24' long enclosed trailer with a car in it.
    Meanwhile, my little steel open trailer plus 2500lb car makes my truck do the Carolina squat!
  2. Aug 30, 2021 at 8:58 AM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
  3. Aug 30, 2021 at 8:59 AM
    BecauseRacecar
    Ohio
  4. Aug 30, 2021 at 9:00 AM
    3rdTundra
    Central Texas
  5. Aug 30, 2021 at 9:33 AM
    CallsignKodiak
    CallsignKodiak New Member
    Bear
    Iiawah
    2021 CrewMax 4x4
    I didn't see a visual of this, like an installed picture of this on the vendor website. I will look for one in the forums here before asking for one.
  6. Aug 30, 2021 at 9:36 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Here is how they look on a Tundra.
    Autom8ed and CallsignKodiak like this.
  7. Aug 30, 2021 at 9:43 AM
    CallsignKodiak
    Bear
    Iiawah
    2021 CrewMax 4x4
    Thank you so much. Makes sense now!
    Bikeric[QUOTED] likes this.
  8. Aug 30, 2021 at 9:51 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    So if I’m looking at this correctly, this would be instead of adding a leaf or airbags?
  9. Aug 30, 2021 at 10:05 AM
    BecauseRacecar
    Ohio
    Do you tow with this setup? Care to share any thoughts? Was thinking about what impact upgraded shocks might have for towing too, but I'm probably missing some fundamental understanding.
  10. Aug 30, 2021 at 10:36 AM
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    Yes, this can be done instead of adding a leaf.
    I do not tow. I installed these to give myself an easier 1" lift in the rear. You can adjust how much it raises the rear by adjusting how much tension you add to the coil spring. The coil spring basically takes the sagging leaf's back to a U shape. You might want to add +1" rear shocks depending on how much you pre-load.
  11. Aug 30, 2021 at 1:02 PM
    Autom8ed
    Autom8ed New Member
  12. Aug 30, 2021 at 1:36 PM
    art64
    art64 New Member
    I had this thing on my 07 RCSB. RCSB is gone and now it's on my 2010 Crewmax 4x4. I has a dampening effect both on compression and rebound. On my RCSB I also had Firestone Ride Rites installed along with this. Reduced pogo stick like bounce when loaded really heavy.
  13. Sep 3, 2021 at 7:33 AM
    OPSteel
    OPSteel New Member
    2017 White Tundra TRD Crewmax
    TRD grille, Bushwacker OEM flares, stereo system
    I have a 3/2 Ready Lift installed on my Tundra now but am about to get a 17’ Casita trailer. Can I install Ride Rites with cradles along with the Ready Lift setup I currently have? Sorry, probably a dumb question.
