Making 315/70R17 fit affordably?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SULLY4x4, Aug 31, 2021.
  1. Aug 31, 2021 at 8:29 AM
    SULLY4x4
    SULLY4x4 [OP] New Member
    2021 SR5 Tundra 4x4 5.7
    I ordered my SR5 5.7 tundra 4x4 and i should have it in 1 month. I have a dodge ram 1500 4x4 (threw a rod) with LT 315/70R17 tires that are almost new. Any chance i can modify the Tundra to make them fit without costing too much?
  2. Aug 31, 2021 at 8:31 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome to the Tundra Nation.
  3. Aug 31, 2021 at 8:31 AM
    AZBoatHauler
    So.Arizona
    What kind of wheels? Lots of 17”s wont clear the brakes…
  4. Aug 31, 2021 at 8:33 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    buy wheels from Icon or Method. buy shocks with AT LEAST 2" of front lift (2.5" is better). chop where it rubs. done!
    Also, welcome ;)
    t4r2tundra likes this.
  5. Aug 31, 2021 at 10:04 AM
    Welcome from NY.
  6. Aug 31, 2021 at 11:31 AM
    Elduder
    Elduder New Member
    Speaking from experience, get a +25 offset. So either Icons or a few of the Method wheels. Remove the mud flap and either push the front fender liner forward, remove it, or buy the coachbuilder bumper spacers.
    Lift isn't necessary, but it'll look pretty squatted with the front at the stock height. Lifts don't prevent rub on our trucks unless your talking 4"+, otherwise you keep the same range of motion and as soon as you compress the suspension you'll rub if the offset is too aggressive.
    Pro with +25 and 315s (2" front lift), didnt need CMC, did remove the front bumper liner.
    SR5 with 0 offset and 315s, have had it as low as 2" of lift and currently at 2.5" of lift. Changing height did not affect the rub, only moving the bumper and CMC. CMC done, bumper moved forward with a spacer, bumper liner removed.
    TundraTed likes this.
  7. Sep 2, 2021 at 2:43 AM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  8. Sep 2, 2021 at 10:29 AM
    king.cong.1119
    king.cong.1119 New Member
    +25mm offset and 8.5inch wide wheels are a must, then slight trim the front fender liner, remove both mud flaps up front, and you should be good to go. Also, keep in mind that for KO2 315/70r17 tires, their load range C is about 0.5-1 inch wider than load range E ones, I went with Load range E for this reason and that its sidewall strength.
