Exhaust bracket repair
Discussion in '1st Gen Tundras (2000-2006)' started by breeko, Aug 30, 2021.
  1. Aug 30, 2021 at 6:21 AM
    breeko
    breeko [OP] New Member
    2005 Tundra V-8 4WD
    Recently noticed one of the hangers on the front exhaust pipe of my 2005 Tundra has rusted through, just behind the driver side door (see pic).
    Since the pipe looks like it has another few years in it, I'd like to fix the hanger. But this is tricky, because in the original the supporting rod is welded to the pipe and extends horizontally from there to the rubber hanger.
    The "universal" aftermarket brackets that I've seen are designed to hang down from above, not extend to the side. So I'm trying to figure out an aftermarket bracket or clamp/rod combination that can extend to the side and remain rigid so as to support the pipe.
    Anyone have any suggestions?
    Edit: Looking for a solution that doesn't require welding.
  2. Aug 30, 2021 at 6:48 AM
    Take it to an exhaust shop. Let them know you are contemplating a new exhaust system but need to keep this one working for a little while longer. They will likely fix your broken hanger on the cheap. If that happens, you know a good place to do business with in the future.
    bmf4069, N84434, w666 and 1 other person like this.
  3. Aug 30, 2021 at 8:47 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    If you don't want to take it to a shop and can't weld it get something like this.
    https://www.oreillyauto.com/detail/...c844/dynomax-exhaust-hanger/dmx0/36405?pos=32
    If it's not long enough to slip through the mount get something like this
    https://www.oreillyauto.com/detail/...a5cfe226c844/walker-exhaust-hanger/wal0/35411
    and clamp the two together with these in the correct size to slip over the rods.
    https://www.tractorsupply.com/tsc/product/national-hardware-3230bc-3-8-in-wire-cable-clamp-zinc
    tvpierce likes this.
  4. Sep 2, 2021 at 4:36 AM
    breeko
    2005 Tundra V-8 4WD
    Thanks. That's essentially what I ended up doing. Took it to a local mechanic who added some metal and welded.
    KNABORES and bmf4069 like this.
