Fox pro shocks install
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Yota707, Sep 1, 2021.
  1. Sep 1, 2021 at 12:34 PM
    Yota707
    Yota707 [OP] New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    I need some help. I have a shop installing the fox pro shocks. They are saying that the fox shock revisor is hitting the front sway bar and front axle. Can someone take a picture on how there shocks are or how that can be resolved
  2. Sep 1, 2021 at 12:42 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  3. Sep 1, 2021 at 12:53 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Because my truck is a 2015 does the fox shocks not work on this year? Did they change something for the 2020/21 model?
  4. Sep 1, 2021 at 2:00 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    The shop sent me this photo of the axle hitting the shock
  5. Sep 1, 2021 at 2:07 PM
    frichco228
    Frank
    Virginia
    It may slightly rub if the suspension has no weight, is basically unloaded. Is the truck on the ground, weight on the suspension, or on a lift in the picture?
    Check vid at 1:33 for a shot that looks similar to yours, is tight clearance for sure.
    only other thing I can think of, there could be some difference side to side, so the coils are likely marked for which side of the truck they should be installed on.
    Black Wolf likes this.
  6. Sep 1, 2021 at 2:10 PM
    Elduder
    Elduder New Member
    They are side specific, it looks like the reservoir on yours is angled backward, swapping it to the other side would angle it forward and away from the axle.
  7. Sep 1, 2021 at 2:15 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    If that is true, and I believe it is, I would be worried about the "tech" :)
    avssuc, TheBubbaDude and Terndrerrr like this.
  8. Sep 1, 2021 at 2:16 PM
    Elduder
    Elduder New Member
    OP needs to get a picture of the top of the reservior, it says the side on it.
    TRDFerguson likes this.
  9. Sep 1, 2021 at 2:16 PM
    Elduder
    Elduder New Member
  10. Sep 1, 2021 at 2:17 PM
    Elduder
    Elduder New Member
    Yeah, I would triple check that boot afterward as well.
  11. Sep 1, 2021 at 2:23 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I don't know about the Fox shocks, but the previous version Bilstein Pro shocks had RF and LF in the part number to tell you which side they go on. Agreed with everyone else that the shop has them on the wrong sides.
    Edit, I see in @Eluder's post/photo that the PN is listed on the reservoir
  12. Sep 1, 2021 at 2:25 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    Ok I appreciate all this info you guys are a life saver! Thank you this is why I love this forum
    Kratos, French Avocado and Elduder like this.
  13. Sep 1, 2021 at 2:30 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    It does appear that the reservoir is facing the wrong way in the pic the shop sent you. It is supposed to face outward toward the tire. There is an R and an L at the top under the bolt. The L is directly under the bolt for the coilover that goes on the left side, and the R is directly under the bolt for the coilover that goes on the right side. Refer to pic...
    If that's all it is and if they can't figure that out, I would triple check their torque on every bolt they touch when they're done and never take anything to them again.
  14. Sep 1, 2021 at 7:27 PM
    Yota707
    Bay Area
    2015 Tundra TRD
    I can’t thank you guys enough! You are all a life saver to me! I been trying to get these shocks installed for months. All it was is they had them reversed. It’s strange because this shop only deals with Toyota but they mainly do tacoma and 4runner work. He is a well known Toyota repair guy in my area. I don’t want to put down the shop because they did make it right. Thank you again for all your input
    Allrsdup, avssuc, Hbjeff and 3 others like this.
  15. Sep 1, 2021 at 7:30 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Sorry to say if a shop couldn’t figure out Driver side to Passenger side I wouldn’t let them touch my truck at all. Sorry
    mattyd170, AggiePhil, avssuc and 3 others like this.
  16. Sep 1, 2021 at 8:02 PM
    Terndrerrr
    Music City
    6UR-FE
    OEM suspension on 4Runners and Tacomas are side-specific, just like the Tundra. The gas tank, battery, steering column, and driver are all on the left side of these vehicles, and Toyota compensates for the added weight so the vehicle doesn’t sag on the drivers side.
    Anyone who works on Toyotas should know that. I’m not trying to put the guy down or saying he doesn’t do good work; it is just a big red flag to me that he didn’t figure that out, especially since these coilovers are labeled L and R at the top. I’d avoid that shop in the future. No need to leave a bad review or anything. I just wouldn’t trust him. Just my personal opinion.
    AggiePhil likes this.
  17. Sep 1, 2021 at 9:40 PM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    Not trying to change this thread but is that true about all Tundra suspensions being side specific. If I install the Off Road Bilsteins are they labeled left and right and if so where will it say that
  18. Sep 1, 2021 at 9:50 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    For those you look at the springs - they are marked with paint dots to indicate which side. I think yellow is passenger and blue/red is passenger, but do your homework on your specific setup. The spring rate on the driver side coil is slightly more to compensate for the weight. https://www.tundras.com/threads/3rd-gen-coil-spring-color-code-id.84900/
  19. Sep 1, 2021 at 9:52 PM
    Terndrerrr
    Music City
    6UR-FE
    Yes. The shocks are the same part numbers, but the springs are different to account for the extra weight on the driver’s side. From a different thread:
  20. Apr 28, 2022 at 10:14 AM
    Slim Gym
    Slim Gym New Member
    2013 Tundra DC 4X4
    I am putting these shocks on my 2013. I have the speed sensor relocation bracket.
    Do I need a carrier bearing drop kit or diff drop kit or any other parts?
    New bump stops?
    I would hate to get into the install and have to go get parts.
  21. Apr 28, 2022 at 11:39 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    nope, just bolt on and go.
    Terndrerrr and Slim Gym like this.
