Line X Bedliner / OEM Bed Lights
Discussion in 'General Tundra Discussion' started by boostedtrdpro, Aug 31, 2021.
  1. Aug 31, 2021 at 7:31 PM
    boostedtrdpro
    boostedtrdpro [OP] voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Hey guys, so I picked up my new truck and have an appointment to get the bedliner sprayed in this Thursday. I have a set of OEM bed lights I need to install and was curious if this should technically be done before or after the spray in liner? Thanks!
  2. Aug 31, 2021 at 7:39 PM
    I would drill the holes for the mounting and put the same size screws in.....not the actual light screws, leave them in and let them spray the bed. After it dries discard those screws and the mount the lights with the OEM screws.
  3. Sep 1, 2021 at 5:38 PM
    boostedtrdpro
    Jeremy
    Does anyone else have the OEM kit? The one I bought is part number 00016-34089 and it looks like it’s possibly meant for the Tacoma. Just looking to confirm before I drill holes in the bed that I have the right kit and the wiring will reach and the connectors will plug in the harness and dash. Thanks for any help!
  4. Sep 1, 2021 at 5:50 PM
    They could have changed the part #.
    Can you post a picture?
    2015 - 2020 Tundra, 2015-2018 Tacoma LED OEM SET Cargo Bed Lighting 00016-34187
  5. Sep 1, 2021 at 6:06 PM
    boostedtrdpro
    Jeremy
    For sure, what exactly do you want a picture of? When I looked up the part number for the install instructions (which oddly didn’t come in the box) I found 2 different pdf documents from Southeast Toyota Distributors LLC that shows the same part number being installed on a Tacoma and the second document is for the 2015 Tundra. Luckily the Tundra instructions come with a printable drill template. I’m guessing it’ll work, but let me know what you’d like a picture of and I’ll gladly upload it. Thanks
  6. Sep 1, 2021 at 6:10 PM
    boostedtrdpro
    Jeremy
  7. Sep 1, 2021 at 6:21 PM
    boostedtrdpro
    Jeremy
    For clarity, I bought these back in 2017 when I had my 2017 because they were available and I found several posts saying they’d work fine. I never got around to installing them and I’ve now traded in the 17 for a 19 TRD Pro and figured I’d get them installed before the bed cap comes in, right after the liner is installed. I just don’t want to proceed if I’m gonna have a problem. I’d rather catch it before there’s holes in my bed ha! Maybe I should just wait until after the bed liner is installed so I have more time to research this.
  8. Sep 1, 2021 at 8:53 PM
    Of the light itself.
    I'm sure they will fit since everything I've seen they use the lights in both trucks.
  9. Sep 1, 2021 at 10:00 PM
    boostedtrdpro
    Jeremy
  10. Sep 2, 2021 at 6:37 AM
    boostedtrdpro
    Jeremy
    Thanks! I was concerned the connectors would be wrong for the harness since mine is a 2019, but I think I’ll be fine. I just found out I have another problem anyhow…guess I have to choose between the OEM bed lock or the bed lights. I guess they must both use the same power source and plug in using the same connector on the harness.
  11. Sep 2, 2021 at 8:19 AM
    That's them, they will work.
  12. Oct 10, 2021 at 5:36 PM
    Dmull1023
    Dmull1023 New Member
    2020 White Tundra Limited TDR OR
    Thinking about adding bed lights like this, but do you know if the additional lights to the circuit will pull too much juice and not work? Thought I read that somewhere on another thread about bed lighting. Also, bed is already sprayed, so any additional difficulty with installation?
  13. Oct 11, 2021 at 9:10 AM
    Dmull1023
    Awesome, thanks.
    NewImprovedRon likes this.
  14. Nov 18, 2021 at 7:33 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Just wondering if you hooked up your lights, how it went and any pictures and if you could verfiy if the wire is still a dark gray one you used to power them?
  15. Nov 18, 2021 at 7:48 PM
    boostedtrdpro
    Jeremy
    Not sure if this was a question intended for me or not, but I have not installed them yet. Things have gotten more complicated for me now. After the bedliner was installed I decided I wanted a cap so I ordered a Smartcap from RSI and a Bedrug. So now I have all of the above installed and now it’s time to tackle lighting. I’m thinking I may go a different route now that I have the cap installed. Maybe something overhead triggered by a switch on the windows. I gotta take some time and draw up a schematic since I’d want it to work with all three windows.
