Transmission fluid change
Discussion in '2.5 Gen Tundras (2014-2021)' started by kcaustin66, Aug 31, 2021.
  1. Aug 31, 2021 at 2:35 PM
    kcaustin66
    kcaustin66 [OP] New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    I have not changed my Transmission fluid yet, I have herd that I shouldn’t now to late. My tundra is a 2015 1794 4x4 with 95k miles I don’t use it to tow anything. Has anyone had any problems with changing it late.
  2. Aug 31, 2021 at 4:23 PM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    do you want the world to spin backwards, the oceans to empty, Toyota to admit they should have installed a transmission cooler on the 2019 and newer trucks? very dangerous question.
    batman900 and Mike59 like this.
  3. Aug 31, 2021 at 4:30 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I had 15 quarts swapped out via the trans cooler on my 2013 with 105k without any problems. Transmission didn’t shift roughly before but seems to shift even smother now.
    kcaustin66[OP] and Mike59 like this.
  4. Aug 31, 2021 at 6:19 PM
    kcaustin66
    kevin
    Was that the first fluid change at 105k
  5. Aug 31, 2021 at 6:22 PM
    Shanet421
    San Diego,CA
    Yes it was
  6. Aug 31, 2021 at 6:52 PM
    Yota707
    Yota707 New Member
    Bay Area
    2015 Tundra TRD
    Auto detail, vinyl wrap specialist. Truck has a 300gal fresh water tank for spot free water while detailing and a Honda pressure washer
    I just had mine done at dealer. Never had it changed before had 120k on the 15 crewmax. I tow a lot! A lot of guys said only do a drain and fill. Dealer said todo a full flush. Went with full flush no problem!
    Former-Ford-Owner likes this.
  7. Aug 31, 2021 at 6:53 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I’ll be doing a drain/flush every 25K miles.
