Airbags vs Weight Distribution Hitch
Discussion in 'Towing & Hauling' started by FirstGenTundra, May 5, 2017.
  1. May 5, 2017 at 11:59 AM
    FirstGenTundra
    FirstGenTundra [OP] R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Found an excellent video on airbags vs weight distribution hitch. In short, a weight distribution hitch works far better than airbags. This video was immensely helpful when I was trying to figure out what I needed to tow a 9300lb trailer. With a WHD i only squat 2 inches, without it I squat over 3.5 inches.
    https://youtu.be/XBZu39pQ8Gg
    @Sean266, @Bob, @csuviper Stickie material maybe for Towing and Hauling?
  2. May 5, 2017 at 12:04 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Stickied!
  3. May 5, 2017 at 12:07 PM
    FirstGenTundra
    Daniel
    Wyoming
    Thanks @Bob!
  4. May 5, 2017 at 4:39 PM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Damn good video. Very informative. Could have used a tiny bit of excitement or passion though :p
    Thanks for sharing!
    FirstGenTundra[OP] likes this.
  5. May 5, 2017 at 4:42 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    great video. equalizer hitch system is the best wd hitch you can get
    too tall and Y0TA PR0 like this.
  6. May 5, 2017 at 10:00 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    This is a great video! Really good information.
  7. May 6, 2017 at 12:54 PM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    Good info.
    Don't most people who have bags use weight distribution hitches in addition to the bags when towing?
    careyrob and Gman like this.
  8. May 6, 2017 at 5:53 PM
    FirstGenTundra
    Daniel
    Wyoming
    I assume nothing. Lol it would be nice to use both for major loads.
  9. May 6, 2017 at 7:13 PM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    Great video...Thanks!
  10. May 6, 2017 at 7:41 PM
    pats_fan
    pats_fan New Member
    2020 Midnight Black Metallic Tundra TRD Pro CM
    This is exactly what I plan on doing. I currently have an Equal-i-zer hitch, and plan on having my Firestone airbags installed in 2 weeks.
    3fafef1a91b38b2485b58a0dca502031_23a5bfcdc7cff4253395a152d74b98c7b50f52c9.jpgcbcc87735814846996b6473a4bbc1e82_4c694e2e7461d119394a5dcd3fa84bb3c8c3d12b.jpg
    D4x4TRD, Fundra2015, chphilo and 2 others like this.
  11. May 6, 2017 at 10:07 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Great info thanks
  12. May 7, 2017 at 8:54 AM
    chphilo
    Western PA
    Nice camper. Your truck doesn't seem to squat bad enough to need air bags. Maybe it's just the angle of the picture, but your set-up looks good. Which Equal-i-zer hitch do you have?
  13. May 7, 2017 at 10:12 AM
    jlee
    jlee New Member Vendor
    jerry
    Bay area CA
    2016 TRD Off Road on 35's supercharged and Kings and A 2002 SAS'ed supercharged Tacoma on 37's Linked front and rear
    Oh one or two.
    The Equal-i-zer hitch and the firestone ride right bags are a nice combo. I have the air bags for the boat and hauling. On those heavy loads I also pump up the bags with the WD hitch on just to level everything out.
  14. Aug 12, 2017 at 9:04 PM
    Only bad thing about using both WDH and AirBags in my eyes:
    - The violent rebound effect when the suspension cycles. Unless you have a set of aftermarket shock you can do a custom valve job on the rebound cycle to slow it down.
    - The systems seem to work against one another. The only time I can see using both is with multiple loads, and some just with the trucks payload.
    I personally like using one or the other. Personal preference. When I go full gooseneck trailers, tag aux tank, and whatever else I can add to the damn pin weight, airbags might be considered again if I am to much into the overloads.
  15. Oct 7, 2017 at 4:01 PM
    too tall
    too tall New Member
    What you said. I just got back from towing my new trailer 300 miles using the equalizer and maaaaan it is awesome.
  16. Oct 7, 2017 at 5:20 PM
    too tall
    too tall New Member
    My bad. WD hitches are religion and we just don't talk about. I'll drop for 20.
  17. Oct 7, 2017 at 5:23 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Yes get both. It will save your leaf springs...
  18. Oct 14, 2017 at 2:15 PM
    Flobrandx
    Flobrandx New Member
    Brandon
    2015 TRD PRO
    Working on them now...
    I use both for my almost 37' toy hauler and am very happy with it. The truck pulls and handles the 9000+ lbs no problem.
    CO_Native and wildbill2020 like this.
  19. Nov 4, 2017 at 5:17 PM
    Ksatter
    Ksatter New Member
    Greenback, TN
    2016 Tundra 4 x 4 5.7 DC LB
    Another vote for the Equalizer wd/anti sway hitch. I pull a lighter load in my TT than others are. Haven't felt a need for the air bags yet. Good video to support how to set the Equalizer up correctly to start with. Thanks
  20. Jun 24, 2018 at 7:07 PM
    galaxyflyer1
    galaxyflyer1 New Member
    Bob
    One thing to keep in mind for you light weight single axel trailer owners. The weight (basically at the hitch) is what we are wanting to redistribute. With a "weight distribution system" this weight gets distributed to the very front of your vehicle and the very rear (which is your trailer axle). If you have a single axel trailer like myself where the AXEL (look for the tag) is only rated at 3500 pounds max, you certainly do not want to add more weight to that. Which can easily happen when you have a truck full of motorcycles, generators etc. and chose to use a WDS. In my case, I use airbags to level out my truck. Therefore Not adding anymore weight to a low rated single axel trailer.
    Jamesd546 and BGoodiE like this.
  21. Jun 25, 2018 at 10:32 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    The two are not mutually exclusive. For example, a WDH does you no good when hauling a load of bricks. Right tool for the job and all that...
  22. Oct 10, 2021 at 1:14 PM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    This is a fantastic video, thanks for sharing and thanks to the mods for stickying it. It helped sway me into buying a WDH so I can tow as safely as possible.
  23. May 3, 2022 at 5:52 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I watched that video a couple of times before. Good information. I have a 29’ travel trailer. I have just a little squat. I need to fine tune the weight distribution hitch, but I’m close. I’ll tinker with it tomorrow before my camping trip. 97A4BEF5-7E46-4FFD-8154-64DBBADBB572.jpg
    TundySt0nk likes this.
