  1. Aug 30, 2021 at 5:43 PM
    Man, if you were going to Gainesville I'd have a laundry list for you. I'd stab someone in the eye right now for Reggae Shack.
    CodyP and Jack McCarthy like this.
  2. Aug 30, 2021 at 5:44 PM
    What's that?
  3. Aug 30, 2021 at 5:48 PM
    People who grew up there rather than transplants.
  4. Aug 30, 2021 at 5:54 PM
    Florida is a state supported by snowbird migration and tourism. Natives are unicorns. I guess the closest you may find to 'native' cuisine is cracker cuisine? But I can't name any places. There was one spot we went to as kids near Sumter County, maybe in Panasofkee?
    But yeah that yearly people surge and industry of tourism is ultimately what keeps that state nuts.
    Exactly. What he said ^^
  5. Aug 30, 2021 at 6:08 PM
    At work, When I see guys in the metal shop without hearing or even eye protection, I’ll gently hint to put some shit on, usually they take the advice.
    At home, usually one of the boys steals the muffs at some point during the project, but I’ll track them down before I use the grinder or whatever
  6. Aug 30, 2021 at 10:06 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
  7. Aug 31, 2021 at 5:14 AM
    TRDGen[QUOTED] and Jack McCarthy like this.
  8. Aug 31, 2021 at 5:17 AM
    I rode at interstate speeds once without hearing protection. Once. Now I always have my headphones in when I ride. I have a modular helmet too so it's even noisier than a regular helmet.
  9. Aug 31, 2021 at 5:30 AM
    Yep. Only snorkeling for me.
    One other area is loud bass. I used to be able to tolerate it turned up to almost full volume. Now only about 1/2 that before my ear hurts.
  10. Aug 31, 2021 at 6:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Let me ask yall a question about an idea I had. Anyone feel free to chime I'm open to any suggestions, or advice.
    So as anyone who's been following my RCLB thread would know, the radiator is just super fucked on this truck. Pic below.
    I'm assuming the rest of the cooling loop looks similar. So what are your thoughts on buying the cheapest autozone radiator I can to do some coolant flushes with cleaner?
    Sacrifice the cheap ass radiator as my strainer for particles from the rest of the loop.
    @empty_lord @FrenchToasty @FirstGenVol @Darkness @NickB_01TRD @Festerw
  11. Aug 31, 2021 at 6:31 AM
    Why use a radiator at all? Maybe there's an alternative method with a tank or tub of some kind.
    FrenchToasty and chrisb like this.
  12. Aug 31, 2021 at 6:51 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    AFAIK, the passages in the heater core are generally tighter than the passages in the radiator.
    Your thinking is on track, but IDK that it'll yield the results you're after.
    Flush as much as you can before hooking up the radiator and then maybe flush some more after install if you're worried. See if you can't hook a garden hose to the bottom hose (lots of duct tape) and crank up the hose. That will certainly keep the truck from overheating while you dump all the dirt out the top hose.
    Or clean your old rad with CLR until it's clean enough and then flush with is.
    Tundra2[QUOTED], Darkness and Festerw like this.
  13. Aug 31, 2021 at 7:13 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I'd try to backflush both the radiator and heater core as @chrisb suggested. Since you have another vehicle and can let this one sit, disconnect the hoses on both radiator and heater core back flush, then fill with cleaner (IIRC CLR isn't safe for aluminum so I'd probably go with radiator flush) and let it set overnight then backflush again. Then I'd fill the system with another bottle of cleaner and run it up to temp for awhile and drain.
    Refill it with clear water after than and see how it looks.
    NUDRAT[OP], bmf4069, Tundra2 and 3 others like this.
  14. Aug 31, 2021 at 7:28 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    2 cups of draino and half a sprig of lemon. Add ice to taste. Swoosh but don't swallow, wine style.
    I don't know really buddy, wish I could help.
    bmf4069, Tundra2 and chrisb like this.
  15. Aug 31, 2021 at 7:42 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Just flush it with the current rad
    bmf4069, shifty` and Tundra2[QUOTED] like this.
  16. Aug 31, 2021 at 7:43 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I'll have to get real savvy with all these suggestions throughout the week at work. Spose to rain here for the next week basically, and the tent of pain is occupied by an even bigger shitbox than the RCLB.
    Looking at prestone products for cleaning.
    Prestone AS110 Radiator Flush and Degreaser, 32 oz https://www.amazon.com/dp/B075RKHC4G
    I used two of these below on my V6, and didn't really get anything out of it. I just assumed that meant my system was mostly clean. All my drain captures are on the build thread on one of the later pages.
    Prestone AS105 Radiator Flush and Cleaner - 22 oz. - 2 Pack https://www.amazon.com/dp/B07L9JNHWM
  17. Aug 31, 2021 at 7:58 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    When you need some vamanos pest action but you still need cable TV
    NUDRAT[OP], bmf4069, chrisb and 2 others like this.
  18. Aug 31, 2021 at 8:00 AM
    Casper421
    In the woods
    06 DC
    Priorities!
    Darkness[QUOTED] likes this.
  19. Aug 31, 2021 at 9:05 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    My old wired headphones worked great, easy on/off. My new wireless headphones suck balls. Buells vibration either messes with the cone or noise cancelation or something. They’re jbl endurance sprint. My icon airflite is excellent at speed, but i cant hear people wearing masks and i have to wear a do-rag so my ears dont fold over.
    bmf4069[QUOTED] likes this.
  20. Aug 31, 2021 at 9:50 AM
    That's ugly as sin, the red one with the tiny tires. However, the white one is basically like an Avalanche with those plastics on the back. NO THANKS!
    :yes:
    AS105 6pk is what I typically buy for a job that big. As much as I hate Chris Fix, he has a decent video on it. I found a better video online than his shit a few years ago, but can't seem to find it now. That guy made some custom hose jobbyfor final flush.
  21. Aug 31, 2021 at 10:18 AM
    So I am making a parts order and wanted to throw in new hard lines that connect the caliper to the rubber hose. Apparently there are two different size calipers. This is what McGeorge told me when I asked. Anyone ever heard of this?
  22. Aug 31, 2021 at 10:40 AM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Is that a Chinese beer or an illiterate texan?
    bmf4069 likes this.
  23. Aug 31, 2021 at 10:41 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    This may or may not help....proof reading now !
    Hard to find Specs, Info & Measurements on 231mm 13WL Tundra Calipers & Rotors (archive) – ADVENTURETACO
  24. Aug 31, 2021 at 10:44 AM
    That actually makes sense. I didn't think they moved up to the 13WL's until 2003 though. I wonder why there would be two options for my 02. Interesting that I was able to use the same hard lines for my 14WA's.
  25. Aug 31, 2021 at 10:44 AM
    wandering_boy
    California
    2005 AC SR5 TRD
    I don't want to hear that shit. My text books this year are $100-200 and I need like 6. Plus they are being super weird and making us buy our own lab equipment so thats another $100. Maybe my wallets asshole won't hurt so bad after being raped by college for the next four years. Not going to be able to pay for mods for a looong time. :(:(:help:
    des2mtn likes this.
  26. Aug 31, 2021 at 10:51 AM
    Well, if it makes you feel any better, minimum wage was around $4-5/hr at the time and professional engineering books I used to buy at Borders (before they closed) in 2010 was around $120-$150 each.
    NUDRAT[OP], daveeasa and Darkness like this.
  27. Aug 31, 2021 at 10:51 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    It's incredible that they haven't shifted from publishing new editions annually (for the sake of making old books useless) to creating pdfs. They charge enough for admission, reading material should be free.
  28. Aug 31, 2021 at 10:52 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I was a cheap bastard. Someone in every class would let me copy their book for $20. I bet i got through all 4 years with $200 worth of supplies.
    But that was community college, so it wasnt really book oriented learning. All the worksheets and tests were on blackboard.
  29. Aug 31, 2021 at 10:54 AM
    Nobody got suspicious with you hanging around at the copy machine for 2 hours making copies? :rofl:
    NWPirate and CodyP like this.
  30. Aug 31, 2021 at 10:55 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    I had a scanner/copier at home. I rode my bmx bike to and from. About 3 miles. With a snowcone place in the middle.
    chrisb, NUDRAT[OP], CodyP and 2 others like this.
