Spark Plugs
Discussion in '2.5 Gen Tundras (2014-2021)' started by rodl12, Aug 31, 2021.
  1. Aug 31, 2021 at 5:55 AM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I've read a few different opinions on how often spark plugs should be changed in the 5.7 Tundra. Some say every 60k but every 30k for best performance. Then there are those who say todays engines can go 100+k without being changed.
  2. Aug 31, 2021 at 5:58 AM
    The recommended iridium plug interval is 120K miles on the 4.6 and 5.7
    rodl12[OP] likes this.
  3. Aug 31, 2021 at 6:03 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    That kind of info is in the maintenance section of your owners manual.
    Black Wolf likes this.
  4. Aug 31, 2021 at 6:13 AM
    I changed out the plugs on my 07 at 98K. Plugs were still good. I changed out the plugs on my 14 at 105K. Still good. Actually my 07 manual stated 130K if I recall correctly.
  5. Aug 31, 2021 at 6:40 AM
    rodl12
    Rod
    South Jersey
    Maybe I don't have a manual.
  6. Aug 31, 2021 at 6:44 AM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    A good set of Denso Iridiums and your good to go for as long as you own it.
    If your bored or doing an engine mod, pull em check em and throw em back in.
    RdKing and rodl12[OP] like this.
  7. Aug 31, 2021 at 6:56 AM
    frichco228
    Frank
    Virginia
  8. Aug 31, 2021 at 8:05 AM
    rodl12
    Rod
    South Jersey
  9. Aug 31, 2021 at 8:15 AM
    frichco228
    Frank
    Virginia
  10. Aug 31, 2021 at 8:24 AM
    rodl12
    Rod
    South Jersey
  11. Aug 31, 2021 at 8:48 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The lower half of page 523 has spark plug specs, but not service intervals. ;)
