  1. Aug 28, 2021 at 6:47 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I really think your only fix is the t100 or sequoia master
    bmf4069, des2mtn and jImmegart like this.
  2. Aug 28, 2021 at 11:55 PM
    pm07
    pm07 New Member
    Shane
    2006 Black Tundra
    First roadtrip in the Tundra today. A short one to Chattanooga and back. Checked out the Aquarium and Medal Of Honor Memorial. No problems except my tire light is flashing on and off. Checked tires, everything okay. Just got new Bridgestones put on front before trip.
    NUDRAT likes this.
  3. Aug 29, 2021 at 7:09 AM
    IIRC, constant flashing (vs. solid light) usually means one of the TPM sensors is bad and/or not communicating (not paired, dead battery).
    I also seem to remember our tire system remembers the tire pressure it registered the last time you press and hold the 'reset' button about 10-12" below the key insertion on the dash, and it lights up when you get x# of psi away from that number. If your tires are at correct psi, try a reset. But if it's flashing I think it's probably TPMS not communicating.
    pm07[QUOTED] likes this.
  4. Aug 29, 2021 at 7:16 AM
    And tissues! How do you think those hands stay so soft?!!
    bmf4069 and FrenchToasty[QUOTED] like this.
  5. Aug 29, 2021 at 10:41 AM
    Anyone here know if I"ll need a 4x4 inch block of wood ready to jack up the rear frame rail for a rear shock install? My current floor jack goes to about 19" (20" with the aftermarket pad).
  6. Aug 29, 2021 at 11:05 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Shouldn't need anything. I replaced mine with the truck on the ground.
  7. Aug 29, 2021 at 12:41 PM
    So just compress it a few inches and bolt it in place? That should be easy as long as i can get the top nut off.
  8. Aug 29, 2021 at 12:58 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Yup there was just enough room to get at the top nuts on mine from the wheel wells with a ratcheting box end.
  9. Aug 29, 2021 at 4:20 PM
    Brinkerro
    Brinkerro Phew...that was close!
    VA Beach VA
    2002 Toyota Tundra
    Out with old, in with the new.
    jpink, RUSTYNUTS, alb1k and 11 others like this.
  10. Aug 30, 2021 at 9:16 AM
    Outbound
    Aaron
    Northern Alberta
    Anyone know what bulb type the fog lights on a '05 are? I'm at work and can't go check my truck right now. Looking for LED equivalents, but can't remember the bulb number/type.
  11. Aug 30, 2021 at 9:51 AM
    Quick look at Sylvania's bulb finder claims the fogs are 9006.
    And this reminds me ... I either need to swap my plastic fog lenses out for yellow, or take time to polish and re-clear mine. They're foggy as hell. I guess I should go look if the lenses are even replaceable.
    Outbound[QUOTED] likes this.
  12. Aug 30, 2021 at 10:00 AM
    daveeasa
    I vaguely remember @memario1214 saying something about wanting to build out an adapter for our oval fog spots to fit a modern fog pod light? I may be mis-remembering that. Seems like such an adapter would be a rather straightforward piece and could possibly even be plastic? Ideally something which adapts to the Tacoma 2nd/3rd gen style of bracket which then allows proper adjustment.
    shifty` likes this.
  13. Aug 30, 2021 at 10:13 AM
    Hell, I'd be stoked just to find some yellow lens covers. Sylvania makes yellow 9006 bulbs for the housing, which I may just end up getting. I've seen other members get there, I think it looks interesting, a little throwback to old style rally.
    @Lupe found replacements somewhere: https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-899#post-2161139
    @jImmegart tinted with Lamin-x: https://www.tundras.com/threads/wha...t-gen-tundra-today.2558/page-735#post-1907605
    Anyway, it looks like the lenses pop off in pictures I'm finding of the OEM part. But I can't seem to find just replacement lenses. OEM fog housings are just as much as replacement headlight housings, WTF!?? They come as just the foglight unit, or the entire assembly with bulbs and all. Tossing out the p/n for my '06 in case a future searcher finds this.
    R unit - 81211-0C021
    L unit - 81221-0C021
    R assembly - 81210-0C021
    L Assembly - 81220-0C021
    jImmegart likes this.
  14. Aug 30, 2021 at 11:18 AM
    empty_lord
    05 rollover special
    ~2k lbs in the bed. Stock leafs with the AAL handle it well. Also again, vibration completely gone when loaded
  15. Aug 30, 2021 at 11:40 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Heard back from Toyota today. They will be replacing the frame on my RCLB when it comes in among other little items.
    jpink, bmf4069, tacoguybill and 11 others like this.
  16. Aug 30, 2021 at 11:40 AM
    Outbound
    Aaron
    Northern Alberta
    Much obliged
  17. Aug 30, 2021 at 11:54 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Whoa a whole new roof?
    RUSTYNUTS and jpink[QUOTED] like this.
  18. Aug 30, 2021 at 12:02 PM
    This qualifies for an epic approval meme. Not my area of expertise, I leave that up to you master Noah.
    RUSTYNUTS, jpink and Darkness like this.
  19. Aug 30, 2021 at 12:12 PM
    empty_lord
    05 rollover special
    Hell yea!
    be sure to give them new body mounts and if you want suspension. Labor cost should be nothing on body mounts and probably a tiny bit on suspension if your swapping springs
    bmf4069, NUDRAT, daveeasa and 2 others like this.
  20. Aug 30, 2021 at 1:38 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Just got back from a trip to Mammoth Lakes and she handled everything well. Long drive, some trails and back.
    Also got a new accessory today. Been waiting for it since January …
  21. Aug 30, 2021 at 1:39 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    You got a pool table that doubles as a tent?! :eek:
    JODOOR, pm07, bmf4069 and 5 others like this.
  22. Aug 30, 2021 at 1:42 PM
    Voss
    Valod
    2003 AC TRD 4x4
    lol. Truck bed pool table swap, it’s the latest style
  23. Aug 30, 2021 at 1:48 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    We joke but....
    bmf4069, tacoguybill, NUDRAT and 8 others like this.
  24. Aug 30, 2021 at 2:53 PM
    Cummins3500
    Logan
    Not a tundra but close, finally got a good video of the lights on the wife’s sequoia. Comes on with the the door unlock and anytime a door opens. (is there a way to upload a video here without having to post a link to somewhere else?)
    RUSTYNUTS and NWPirate like this.
  25. Aug 30, 2021 at 5:10 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Played with the Tundra suspension a bit. Made some minor tweaks to the coilovers and got frustrated chasing ideal up travel and droop, so walked away from that.
    Decided to revisit some pedal bling for the boy’s 4R. Had some covers sitting around that mostly fit. Brake and gas all good. No e brake and the foot rest was too tall and too narrow. Cut that piece down and set it horizontal. Used the scrap for the e brake. All good.
    bmf4069, oscardog86, Legender and 5 others like this.
  26. Aug 30, 2021 at 5:13 PM
    Casper421
    In the woods
    06 DC
    What trails did you run? I was just down there 2 weekends ago.
    oscardog86, Darkness and Voss[QUOTED] like this.
  27. Aug 30, 2021 at 5:14 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    In the middle of cleaning and reoiling the aFe air filter...still unsure if it's any better than the stock filter but I already have it and so I'll use it.
    bmf4069 and Darkness like this.
  28. Aug 30, 2021 at 5:17 PM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black V8 DC SR5 (RWD)
    Yeah, no more noisy air leak on the highway and no more water leak when it rains.
    bmf4069, NUDRAT, FirstGenVol and 2 others like this.
  29. Aug 30, 2021 at 5:19 PM
    The asymmetry of the circles not being centered on the parking brake would drive me crazy.
    Good job though.
  30. Aug 30, 2021 at 5:29 PM
    alb1k
    Left Coast
    It's good
    I get that for sure. I had to decide how big and where to drill with the layout on hand. I spun that scrap around a lot looking - I don't think symmetry was coming from that piece I had.
