  1. Aug 29, 2021 at 4:27 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    97 T100 4wd, 03 T3, 06 4wd
    Excellent learning opportunity
  2. Aug 29, 2021 at 4:30 AM
    TRDGen
    TRDGen Schnooogins
    Travis
    I wanted those but iirc a set of 5 was well over $1k. I'm thinking over Level 8 now. A set of 5 is like $830 and I can order em from discount tire when I order tires and put em on my discount tire card. Maybe even get some rebates. Oh and I do have fender flares. Thanks for the advice.
    jImmegart[QUOTED] likes this.
  3. Aug 29, 2021 at 7:04 AM
    Getting caught up, buncha replies with a buncha topics here ....
    In my world, we call that stuff "DO NOT EAT". Literally everyone I've worked with over the years knows exactly what you mean when saying, "Hey, chuck me a pack of DO NOT EAT."
    There's some stuff you can buy at the store called 'Damp Rid' which is used in damp basements and crawlspaces. Comes in a tub. You put the tub where it's needed and leave it, it turns to thick liquid as it collects water. This is one of those times I'm super glad I have a dehumidifier though.
    Oh, and buttload is one word. Not many people know 'butt' is a legitimate historical measure, I think many think it's a lewd version of boatload. or something.
    Man, who could've possibly seen that coming? /s
    First thoughts are lubing any connection point, but also wonder if it could be making dry contact with a boot where it passes thru the fw? I don't remember how the linkage works, and you might've already tried all this.
    Actually on this point, I have a question for all of y'all.
    When I start my truck, then step on the brake to shift out of gear, I feel and hear a hard 'click' at the brake pedal and can't shift into gear until that happens. Every couple dozen times, I can't shift into gear at all until I release and depress the pedal again. Does anyone else have this happen too? I assume there's a safety mechanism somewhere under the dash. I just wonder if what I'm describing is common or not.
    RUSTYNUTS[QUOTED] likes this.
  4. Aug 29, 2021 at 9:50 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Never had my shifter do that…
  5. Aug 29, 2021 at 9:53 AM
    It's weird, like, I can literally feel something disengage the pedal and make a "click" noise under the dash when shifting out of P sometimes.
    I can replicate this every time if - with foot off brake pedal - I pull the lever towards me and hold pressure downward, then step on the pedal.
    Literally feel something releasing down there. Sometimes need to release the lever entirely, release the pedal, then press the pedal in fully and shift.
    Clearly there's a safety somewhere related to the brake pedal which won't let you shift unless you've fully depressed the brake pedal. Dunno what/where.
    Not super worried about it, but ... thought I'd ask about it.
  6. Aug 29, 2021 at 9:59 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Sitting on the parking pawl? See if it does it nose down, if you usually park nose up.
  7. Aug 29, 2021 at 10:01 AM
    empty_lord
    05 rollover special
    The shiftlock out is down by the brake pedal, maybe your feeling that?
    Parking paw can click too.
  8. Aug 29, 2021 at 10:10 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    My memory might be messing with me, but theres a lockout in the steering of some cars, where if you park with tension in the steering, the key wont turn, and you have to countersteer a tad? Im sure ive had to show people how to fix this, but never thought about the mechanism that would actuate it.
    am i crazy? Is that a thing?
  9. Aug 29, 2021 at 11:59 AM
    I park on flat land.
    I'd take a video of it, but it just wouldn't translate, you really need to be able to see/feel the brake pedal actuating in tandem with the click to understand, I think.
  10. Aug 29, 2021 at 12:03 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Try putting the truck in neutral, applying the parking brake and then put it in park. See if the click doesn't occur on the next start after. If it doesn't it's the parking pawl disengaging under load doing the click.
    shifty`[QUOTED] and CodyP like this.
  11. Aug 29, 2021 at 12:15 PM
    jImmegart
    Jonah
    California
    2003 Tundra TRD Sport
    I also have had some 8” with 0 offset and the fitment wasn’t bad either. im sure any 8-8.5” with 0 should be pretty good
    TRDGen[QUOTED] likes this.
  12. Aug 29, 2021 at 3:01 PM
    daveeasa
    So where are you right now mirror-wise? I’d like something bigger in that department myself but haven’t started messing with any of it yet.
  13. Aug 29, 2021 at 3:44 PM
    TRDGen
    TRDGen Schnooogins
    Travis
    Yeah my 16x8 have 0 offset 4.5bs and they fit ok with my 295/75s but rubbed frame on lock to lock so I got 1.25 spider trax. I'm still undecided on if I want 285/75r17 or 35x10.5 or 35x12.5 tires
  14. Aug 29, 2021 at 7:00 PM
    Cummins3500
    Logan
    Got a cv axle boot on the drivers side that’s torn and slinging grease. Went ahead and ordered a replacement 9550 TR from CVJRemans since I’m freaking up my front end . They specify that it doesn’t ship with axle nut or differential seal. Do I need to order new on those? Can anybody confirm part numbers?
  15. Aug 29, 2021 at 7:25 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    I went back to the oem ones and raptor lined the chrome mirror cover. I would like my buddy to design (on his uncles CBC machine) an aluminum or plastic base adapter from the 2nd gen towing mirrors to fit our base but he doesn’t have the time for that kinda thing.
    daveeasa[QUOTED] likes this.
  16. Aug 29, 2021 at 7:46 PM
    18" TRD Off Road Wheels
  17. Aug 29, 2021 at 8:25 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    Was at the grocery store, saw these & thought "somebody on Tundra's mentioned these - have one for them".
    So they followed me home.
    Festerw, bmf4069, CodyP and 1 other person like this.
  18. Aug 30, 2021 at 3:10 AM
    It wouldn't hurt to replace those.
  19. Aug 30, 2021 at 5:44 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Welp, bit the bullet and ordered a CSF radiator this weekend. TB kit, 150a alt, thermostat and a few other goodies are up next. Leaving for a week or so this Friday so it'll be a little bit before I tackle the work.
  20. Aug 30, 2021 at 6:44 AM
    There is a safety lock mechanism on all modern cars that prevents you from shifting out of park without pressing the brake. If you are pulling down slightly on the shift lever before pressing the brake pedal the shifter may be holding the release mechanism closed preventing you from shifting out of park. Be sure to completely depress the brake pedal before trying to shift out of park. Several threads in here from days past about someone trying the force the shift out of park and breaking the release mechanism. You could also experience an intermittent issue with this if the brake switch or release mechanism is failing.
    NUDRAT[OP] and shifty`[QUOTED] like this.
  21. Aug 30, 2021 at 6:47 AM
    TBinky
    TBinky Wassup weirdos
    2000 black tundra
    Have any of you modified your stock intake to hold a k&n filter? If so could you post pics
  22. Aug 30, 2021 at 6:47 AM
    TBinky
    2000 black tundra
    And/or links to people who did it thanks in advance
  23. Aug 30, 2021 at 6:50 AM
    Proceed with caution on the K&N filter. One of the worst mods you can make to any car. Those filters are for racing. The oil can gum up MAF sensors and they do not filter out the finer silica particles in the air. Silica = sandpaper = faster engine wear. Race cars don't care, the engines will likely be replaced or rebuilt at short intervals. My $0.02
  24. Aug 30, 2021 at 7:00 AM
    If nobody else is experiencing hearing the lock/unlock of the mechanism, and the occasional difficulty shifting out of park, I probably need to dig on this to figure out what the part number is and where it's installed. It's totally possible the mechanism on mine was impacted by something stupid one of the previous two owners did.
  25. Aug 30, 2021 at 7:41 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  26. Aug 30, 2021 at 7:52 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    I have one that came with my plastic intake tube setup (also from K&N).
    I'm typically terrible at taking pics...but I drove my truck to work today, so I can try to snap a pic at lunch.
    Over-oiled filters gum up MAFs. And they all come over oiled. Just have to soak out some of the oil and they work just fine.
    I've used K&Ns for years and years and years without issue.
    I've also found the oiled K&Ns outlast the dry filters like AFe. The oil is integral to the operation of the filter, but too much is a bad thing.
    I hate stomping pedals, and oft don't push my brake very hard in the AM when I shift from park. The damned shifter won't move, so I release both and start over...pressing the pedal a bit further. It's not quite annoying enough for me to look further into it, but I have wondered if the interlock has a cable that's stretched.
    Darkness likes this.
  27. Aug 30, 2021 at 7:56 AM
    empty_lord
    05 rollover special
  28. Aug 30, 2021 at 8:06 AM
    Well shit, I'm just glad I'm not the only one. I swear I've felt (and heard) similar on previous trucks. The click sound I hear on mine when shifting out of Park is strangely similar to a milder version of the click you hear when stepping in on the parking brake and pulling the release lever. Maybe I can catch that on video. Not sure if I'll be driving anywhere today, though.
    That makes two of us.
    empty_lord[QUOTED] likes this.
  29. Aug 30, 2021 at 8:12 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I tried it as an experiment long ago, it really isn't worth the trouble. You have to make an adapter pipe for the maf to sit on and add a cone after. My truck ran weird with it for the day that I tried it so I threw that in the trash and went back to stock. It was a waste of a Sunday morning but the parts were free.
    Save the hassle and either get a drop in lifetime filter or stick with the paper filters. The stock intake on these trucks is pretty well suited for the motor.
  30. Aug 30, 2021 at 8:23 AM
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    The K&N I have is technically a drop-in...but it did require some trimming of the ribs in the bottom to fit. Picture a cone stuck to a panel.
