1” bora spacers front only
Discussion in 'Wheels & Tires' started by ultra1988, Aug 12, 2021.
  1. Aug 12, 2021 at 9:33 AM
    ultra1988
    ultra1988 [OP] New Member
    2019 tundra
    I had to get spacers due to 295/70r18’s rubbing the sway bar hard, also couldn’t get my king coil over reservoir hose to stop rubbing the tire without it touching the spring.
    because of the nature of independent front suspension the 1” spacer up front makes it just barely wider than the back tires, I may actually end up running a 1.25” in the front and 1” in the back. IMO with the front leveled and stock wheels they were tucked in so far it looked ridiculous.
    picture is with the 1” spacers in the front.
  2. Aug 12, 2021 at 10:44 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
  3. Aug 12, 2021 at 10:51 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  4. Aug 14, 2021 at 7:23 PM
    paulbk
    paulbk New Member
    This is exactly what I’m planning on as well.
    1.25” front
    1.00” back.
    I test fitted 1.25” on the front and back. Fronts look great!! Rears poke out just a bit much. 1” will be perfect!
    here’s pics with the 1.25” on the driver’s side front and rear. Passenger side is stock.
    I’m running scs 18x9 et +25 35x12.5r18 all around btw.
    C12DDFD6-9803-4FEF-90DC-5E2805EBB60F.jpg EE58CC62-8D3B-4C28-BE38-9700455190CD.jpg A7312036-3E27-421F-BFAE-1FE46ACD9F95.jpg 0641AD8B-FCF4-42B7-842A-6AE5F30494A0.jpg
  5. Aug 24, 2021 at 3:28 AM
    Bigbird57
    Bigbird57 New Member
    I have the same issue. I have a 1.25" set coming. I am running the Ridge Grapplers in 295-70-18. Bilstein 6112 at 1.9". Body Amour winch bumper. Tire just touches the sway bar when turning left only. Weird
  6. Aug 29, 2021 at 1:40 PM
    ultra1988
    2019 tundra
    I think you can loosen the sway bar mounts and move the sway bar side to side a smidge to fix it. I was rubbing much worse on passenger side though. Now I just need to find aftermarket mud flaps. Don’t like driving around with hacked up mud flaps so my tires don’t rub.
