BD S8 hood bulge install...couple of issues/questions
Discussion in 'Lighting' started by Tundra234, Aug 28, 2021.
  1. Aug 28, 2021 at 6:16 PM
    Tundra234 [OP] New Member
    Installed the BD S8 in the hood bulge. What a PITA to adjust.. Have any of you that installed it been able to have the reflectors centered between the top and bottom of the opening? @AZ Red Nek @Baja Mike @dlouly76 @smslavin @so_juanderful @azTony @DexterL @SpeshulED @Larmand @PLC721
    I had to remove the two end clips on the bulge completely because they would not clear the bar no matter what I did. I have a slight gap between the hood and the bulge on the passenger side. I'll try messing with it again tomorrow....any ideas For? For the SDHQ mounts, I used the factory hole for the forward bolts. I don't like the gap between the bottom of the bar and the edge of the bulge but I guess there is no way around it.
    Ty_Gets_Rekt likes this.
  2. Aug 28, 2021 at 10:00 PM
    pandapro
    pandapro New Member
    I encountered the same fitment issue and also had to completely remove the two plastic clips on the bulge. Have you tried drilling the holes under the hood where the mounts go to push the bar back a little bit? Looks like 1/8” or 1/4” will do the trick to have it sit flush.
    BTW, careful driving above 75-80 mph with it like that. The plastic clips will come loose on the freeway and the bulge will feel like it’s going to fly away. Ask me how I know…
  3. Aug 28, 2021 at 10:17 PM
    I used the factory hole for the front and elongated it some to slide the bar back. It doesn't appear to be touching the bezel at all. The clips are all replaced with the nut plates. It still comes loose with those or was that an update to installation instructions at some point?
  4. Aug 28, 2021 at 11:00 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    First, never listen to that AZ Rednek guy. When I did mine after mounting the bar and putting on the bezel it was off from where I wanted it. I'm in the city so I removed the bezel drove to middle of nowhere and proceeded to adjust where I wanted the light to shine. Then made small adjustments until the bezel fit and everything looked good. I also used the nut plates when it felt tight it still moved, was able to tighten it more and then was fine.
  5. Aug 28, 2021 at 11:24 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I had to buy a new hood bulge this week.
    One of the bolt mounts broke and I tried 6 times to glue/epoxy it back in place.
    It would hold a couple months then the entire bugle would pop out of place on the highway..
    My point;
    The new hood bulge doesn't look that much different on the passenger's side than this..
    Driver's side sits flush..
  6. Aug 29, 2021 at 4:14 AM
    dlouly76
    dlouly76 New Member
    Is some tabs blocking the clearance to bring the bulge flush? Make sure you can press it down flush first with no obstructions.. if you cant then either lower or angle the led a bit and trim more if so. If it can sit flush, then when you go to secure the side bolts you will need to press down from the top to ensure it's flush and tighten it down to hold its position. That's how i got mine to seat perfect.
  7. Aug 29, 2021 at 10:33 AM
    I think it's done finally....I'll run the harness later in the week. 20210829_132611.jpg 20210829_132603.jpg 20210829_132600.jpg 20210829_113908.jpg 20210829_113917.jpg
    Black Wolf and coldcanuk like this.
  8. Aug 29, 2021 at 1:32 PM
    AZ Red Nek
    Chuck
    Looks great
    Tundra234[QUOTED][OP] likes this.
  9. Aug 29, 2021 at 1:34 PM
    Nice:thumbsup:
    Tundra234[OP] likes this.
