OEM Rigid Fog light, repurpose bracket?
Discussion in 'Lighting' started by TonyNCo, May 15, 2021.
  1. May 15, 2021 at 11:20 PM
    TonyNCo
    TonyNCo [OP] New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    I put the amber/yellow Rigid fogs in, now the OEM white rigid need a new use. Does anyone know of a bracket that will bolt up to them?
    Tony
  2. May 21, 2021 at 7:03 PM
    Gr3asy
    Gr3asy New Member
    How did you mount the yellows? Did you use the factory mount or a new bracket?
  3. May 21, 2021 at 7:06 PM
    Depends on where you are trying to mount them.
  4. May 21, 2021 at 7:06 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Do you have a pic of the OE Rigids? I’ve never seen them in person so don’t know if they have the same mount points for the bracket like aftermarket models.
  5. May 21, 2021 at 7:07 PM
    Gr3asy
    Gr3asy New Member
    I’m wanting to swap the OEM fogs on a TRD Pro for real Rigid D2.
  6. May 21, 2021 at 7:09 PM
    Gr3asy
    Gr3asy New Member
    I’m getting into that front bumper tomorrow. Just wanted to see if anybody knew tonight. Seems like up to 2020 guys were having to find brackets with OEM housings. I’ll follow up on this post with pics if we don’t figure it out before then.
  7. May 21, 2021 at 7:11 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The OP is wanting to do the opposite, mounting the Pro fogs in an aftermarket setting. If you’re wanting to put aftermarket pods in your Pro housing, then yes you’ll need a bracket. It works pretty well, though.
  8. Aug 29, 2021 at 11:20 AM
    TonyNCo
    Tony
    I mounted the new yellow ones using off the shelf L brackets from Home Depot.
    The OEM white Rigid ones, I am hoping to bolt up in another location. I will try to find them soon and post a pic, I just moved. I am still trying to figure out if I should drill into them to mount them, or make up a cheap bracket. Wished there was an aftermarket bracket or outer enclosure to allow them to be retrofit easily.
