2018 Bilstein level issue
Discussion in 'Suspension' started by Tundra_King1, Aug 27, 2021.
  1. Aug 27, 2021 at 3:27 AM
    Tundra_King1
    Tundra_King1 [OP] New Member
    2018 Tundra 4x4 5.7L Crewmax
    2.5" Level with Bilstein 5100s, 275/70R18 Nitto Ridge Grapplers, and JBA UCAs.
    So, took my truck to get it aligned and this little fuck up from another shop (the shop I took it to tonight tried to fix it) bent this preventing a correct alignment. Anybody know how to fix this? Also the level kit (Bilstein 5100) i had put on two years ago I discovered the drivers side sits about an inch lower than the passenger side. Is this a common issue? How do I fix that?
  2. Aug 27, 2021 at 4:44 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    1lowlife likes this.
  3. Aug 27, 2021 at 6:47 AM
    Tundra_King1
  4. Aug 27, 2021 at 6:54 AM
    I think Total Chaos has some weld on cam guides. Hell, they could just weld on some steel to make it work just fine. This shouldn’t be rocket science for them.
    BTBAKER, pvn.beluga and TheBeast like this.
  5. Aug 27, 2021 at 7:24 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  6. Aug 27, 2021 at 7:38 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Can you give more details on the Bilstein kit and how it was installed? Springs used, perch height, top spacers, etc. If you used the OEM springs, they may have been swapped from side to side and you’ll get more lean from that. If you used aftermarket springs, I think there is typically a half inch of lean. If you already have spacers, I would avoid throwing shims at this.
  7. Aug 27, 2021 at 8:32 AM
    Tundra_King1
    Thanks for everyone's help. I had Pungo Offroad do it in VA Beach. Used OEM springs. No spacers or shims.
  8. Aug 27, 2021 at 8:34 AM
    Tundra_King1
    I'm just going to buy this kit and have someone install it. Then no more fuckery...hopefully
  9. Aug 27, 2021 at 8:38 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Yeah, definitely those cam tabs are effed up. Possibly resulting in the issue. Check out @joonbug build thread!
    joonbug likes this.
  10. Aug 27, 2021 at 8:45 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Can you see the paint dots on the springs? That will let you verify the springs are on the correct sides and diagnose the lean issue, if it's not just due to the bad alignment and broken cam tabs.
  11. Aug 27, 2021 at 8:50 AM
    Tundra_King1
    Alignment is decent as of last night(when we found the issue) the tech got it to -.03 camber, 3.8 caster, and .13 toe
  12. Aug 27, 2021 at 8:52 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Good deal - so is the lean still there?
  13. Aug 27, 2021 at 8:54 AM
    Tundra_King1
    Yep, measured all 4 corners from middle of hubcap to bottom of fender
  14. Aug 27, 2021 at 11:01 AM
    Jhon
    Jhon New Member
    On the Oregon Trail
    2021 SR5 TRD OR
    You got the Toyota lean. Fuel tank and battery are on the driver side so they all lean. It’s more noticeable on lifted applications. Shim on the driver side is the solution.
  15. Aug 27, 2021 at 11:13 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    He needs to verify the springs are on the correct sides before throwing shims at it. 1" is a lot for the typical Tundra lean, and usually with OEM springs it's not an issue.
    https://www.tundras.com/threads/3rd-gen-coil-spring-color-code-id.84900/
    Yellow/grey = passenger side
    Red/blue = drivers side
    ColoradoTJ and JimboSlice413 like this.
  16. Aug 27, 2021 at 11:42 AM
    Tundra_King1
    If I need shims, is there a rear one as well? 1/2 inch shim should be plenty
  17. Aug 27, 2021 at 11:48 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Toytec makes a half inch shim to go under the leaf pack, but if you fix the front, it should fix the rear too.
  18. Aug 27, 2021 at 12:11 PM
    Tundra_King1
    Alright, I dont think I should need an alignment either
  19. Aug 27, 2021 at 12:17 PM
    Tundra_King1
    Should I need bump stop extensions also?
  20. Aug 27, 2021 at 12:19 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Can you back up to the first step and verify the springs are on the right sides? Past that, yes, you'll need a minor bump stop extension, which is just a thick fender washer that should have come with the 5100s.
  21. Aug 27, 2021 at 12:20 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    I agree. If stock coils were used, a lean issue would point to equipment failure. A shim would correct a lean but not the failure.
  22. Aug 27, 2021 at 1:04 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I have 5100's on the top setting with no lean. Stock springs were retained.
  23. Aug 27, 2021 at 1:21 PM
    Tundra_King1
    Sorry I was busy at work and couldn't verify. The springs ARE flipped. Blue/red sits on the passenger side right now
    JimboSlice413 likes this.
  24. Aug 27, 2021 at 1:29 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Well that'll do it! At least that's an easy fix. You'll probably want to do an alignment after swapping, so maybe wait until you have your alignment tab hardware in and get all 3 things done at once.
  25. Aug 27, 2021 at 2:46 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Tundra_King1[OP] likes this.
  26. Aug 27, 2021 at 3:12 PM
    Tundra_King1
    The truck shop (a different one) is going to look over the level and fix the issues including welding a new tab on or bead welding the current one
    JimboSlice413 and TRDFerguson like this.
  27. Sep 3, 2021 at 11:39 AM
    Tundra_King1
    Update: I ended up taking it back to the original shop that did the level and they switched the springs for free and would ya guess what? It fixed the issue. Its only off by maybe 1/4" now, which is nothing, I dont even think they make 1/4" shims lol thank you all for your help.
    TRDFerguson likes this.
